  3. Ping Pong with ESP8266 results in !TSM:FPAR:NO REPLY [solved]
29 Posts 3 Posters 7.5k Views 4 Watching
    https://forum.mysensors.org/topic/838/windows-gui-controller-for-mysensors
    I'd start from the ethernet gateway and work it out from there, myscontroller works with ethernet gateway. In openhab I don't know how to enable auto id, but there must be something in documentation. To be honest assigning manually ID has to be done only once because it is saved in eeprom and read at every boot, so I don't see it so mandatory to have the controller handling it.
    mppM
    mppM
    mpp
    @gohan, do you mean http://www.mycontroller.org? I can't find any project page with downloads on the link you provided. There is a download link to a zip file somewhere in the comments but impossible to say if that is still up to date as it dates from 2015.
    MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
      yes, it's the zip file. It is a windows app. Mycontroller it is actually a controller like Domoticz or Openhab. I know it is a little old, but it works.
      • mppM
        mppM
        mpp
        wrote on last edited by mpp
        @gohan, I switched over to mycontroller (from OpenHab) and I'm using Arduino's nodes and I'm still getting errors not finding the parent.
        I'm using the Mock sketch and tested with setting the ID manually but no luck.
        4 TSM:INIT
        4 TSF:WUR:MS=0
        108 TSM:INIT:TSP OK
        110 TSM:INIT:STATID=99
        112 TSF:SID:OK,ID=99
        114 TSM:FPAR
        3241 TSF:MSG:SEND,99-99-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        5249 !TSM:FPAR:NO REPLY
        5251 TSM:FPAR
        8378 TSF:MSG:SEND,99-99-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        10385 !TSM:FPAR:NO REPLY
        10387 TSM:FPAR
        13514 TSF:MSG:SEND,99-99-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        15521 !TSM:FPAR:NO REPLY
        15523 TSM:FPAR
        Edit: adding a 4.7 capacitor didn't change this. Neither did downgrading to 2.0.
        Starting sensor (RRNNA-, 2.0.0)
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=254)
        TSM:FPAR
        TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        Any idea?
          On the gateway do you see any message received? Can you post the gateway log when nodes are registering?
          mppM 1 Reply Last reply
            mppM
            mppM
            mpp
            @gohan, when using the WemosD1 (without capacitor!) and a static ID, I get the following:
            0;255;3;0;9;TSF:MSG:READ,253-253-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            0;255;3;0;9;TSF:MSG:BC
            0;255;3;0;9;TSF:MSG:FPAR REQ,ID=253
            0;255;3;0;9;TSF:PNG:SEND,TO=0
            0;255;3;0;9;TSF:CKU:OK
            0;255;3;0;9;TSF:MSG:GWL OK
            0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
            0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            0;255;3;0;9;TSF:MSG:PINGED,ID=253,HP=1
            0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
            0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
            0;255;3;0;9;Sending message on topic: mpp-mygateway1-out/253/255/0/0/17
            When I do the same for the Pro Mini, there is nothing to see. When I flash a Moteino test sketch it works properly.
            gohanG 1 Reply Last reply
            • mppM mpp
              @mpp the gateway is getting the message and it replies so you could either have a power issue on gateway or range problem. How far are the gw and node?
                mppM
                mppM
                mpp
                @gohan tested with less than a meter up to 10 meters. In fact the Wemos Node now is working as it shows up in mycontroller but the Pro Mini doesn't receive a response from the GW.
                  wrote on last edited by gohan
                  #24
                  Do you have other radio modules to try? If not, if you swap the radios do you see any changes? Are the radio rfm69 right?
                    mppM
                    mppM
                    mpp
                    @gohan I have several RFM69 radio's and they're all working (with the Moteino sketch) on a Pro Mini.
                    Here's my config:
                    #define MY_RADIO_RFM69
                    #define MY_IS_RFM69HW
                    #define MY_RF69_IRQ_PIN 4
                    #define MY_RF69_SPI_CS 15
                    #define MY_RFM69_NETWORKID 99
                    #define MY_NODE_ID 123
                    • mppM mpp
                      Here's my config:
                      mppM
                      mppM
                      mpp
                      Removing some of the config lines seems to have an effect:
                      4 TSM:INIT
                      4 TSF:WUR:MS=0
                      8 TSM:INIT:TSP OK
                      10 TSF:SID:OK,ID=254
                      12 TSM:FPAR
                      143 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      1232 TSF:MSG:READ,0-0-254,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      1239 TSF:MSG:FPAR OK,ID=0,D=1
                      2150 TSM:FPAR:OK
                      2150 TSM:ID
                      2152 TSM:ID:OK
                      2154 TSM:UPL
                      2285 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      2314 TSF:MSG:READ,0-0-254,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      2320 !TSF:MSG:LEN,0!=8
                      2435 TSF:MSG:READ,0-0-254,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      2441 TSF:MSG:PONG RECV,HP=1
                      2443 TSM:UPL:OK
                      2445 TSM:READY:ID=254,PAR=0,DIS=1
                      2580 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                      2717 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=1,l=1,sg=0:1
                      2723 !TSF:MSG:LEN,0!=8
                      2795 TSF:MSG:READ,0-0-254,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      2936 !TSF:MSG:SEND,254-254-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=NACK:2.1.1
                      3076 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=2,st=NACK:0
                      3110 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=6,l=2,sg=0:0100
                      3117 !TSF:MSG:LEN,0!=9
                      Send Sketch Info: 5197 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=11,pt=0,l=14,sg=0,ft=3,st=OK:MockMySensors
                      5341 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=NACK:v0.5
                      MockMySensors v0.5
                      5480 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=6,l=2,sg=0:0100
                      5486 !TSF:MSG:LEN,0!=9
                      Get Config: Metric
                      Presenting Nodes
                      ________________
                        S_DOOR
                      6375 TSF:MSG:SEND,254-254-0-0,s=1,c=0,t=0,pt=0,l=12,sg=0,ft=1,st=OK:Outside Door
                      ________________
                      6434 MCO:REG:REQ
                      6567 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
                      6664 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=6,l=2,sg=0:0100
                      6670 !TSF:MSG:LEN,0!=9
                      6744 TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      6750 MCO:PIM:NODE REG=1
                      6752 MCO:BGN:STP
                      GW Started
                      7254 MCO:BGN:INIT OK,TSP=1
                      RandomNumber:36
                      Send Battery Level
                      7290 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:36
                      Request Time
                      7929 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
                      Door is: Open
                      8509 TSF:MSG:SEND,254-254-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                      System is: Armed
                      8646 !TSF:MSG:SEND,254-254-0-0,s=1,c=1,t=15,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      8783 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=NACK:36
                      8792 TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      8798 !TSF:MSG:LEN,0!=8
                      So now the node is sending data but there's no ack/Invalid message length.
                        Are they RFM69HW? What antenna are you using on them?
                          mppM
                          mppM
                          mpp
                          @gohan they're all HW, yes. I tested with single wire and coil antenna's. Atm I'm testing with authentic Moteino's with single wire. They all result in !TSM:FPAR:FAIL.
                          • O
                            O
                            Omemanti
                            wrote on last edited by Omemanti
                            #29
                            @mpp said in Ping Pong with ESP8266 results in !TSM:FPAR:NO REPLY [solved]:
                            So now the node is sending data but there's no ack/Invalid message length..
                            Any progress on this front? I got the exact same things as the log you posted; loads of NACK's.
                            Checked/replaced radios, antennes and caps ..
