  3. ๐Ÿ’ฌ MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 86.7k Views 18 Watching
  • ileneken3I
    ileneken3I
    ileneken3
    Congratulations on winning the contest. That convinces me to give it a try.
    Even though this has been available for months, I'm not seeing much discussion on:
    • Improvements on range.
    • The best module to purchase for the simplest nodes - like temperature.
    • Battery performance.
    Anyone have feedback on those yet?
    Thanks ahead of time
    d00616D 1 Reply Last reply
    • scalzS
      scalzS
      wrote on last edited by scalz
      #22
      @ileneken3
      I'm having some fun with @d00616 work :) And it's working fine so far (thx again).
      I have not tested battery performance for the moment.. NRF52 is capable of very low power but i think the low power is not enabled yet in the porting, it's explained in the project prez if i remember
      Regarding range, sure NRF52 is an improved chip compared to NRF24 for instance, but the most important part is the antenna. That's the case for all mcu though. Take a long range capable mcu and a bad antenna choice, or a bad antenna design (bad gnd plane, bad clearance for antenna etc) and you'll never get the long range (example: miniaturized chip antenna, or some pcb antennas too).
      For the simplest devices to buy, no idea as i'm making custom boards.
      • ileneken3I ileneken3
        d00616D
        d00616D
        d00616
        @ileneken3 Thank you.
        Like @scalz has written, the range depending mostly on the antenna. With the same antenna the nRF52 series are more efficient.
        If you need a simple module to start with, a RedBear BLE Nano 2 or Nano is a good module. It's a small module with integrated voltage regulator and 2.54mm pins. This module is available in the second generation with compatible pin layout.
        If you need an cheap module, there are some starting at 3-6โ‚ฌ with an nRF51. I don't know how long these modules are sold. If possible, use nRF52 based modules. The nRF52 is faster (https://github.com/mysensors/MySensors/pull/845), more flexible and less current consuming then nRF51. The interrupt vector of the nRF52 can be moved into RAM. This reduces the interrupt latency and allows to implement OTA updates in an simple way.
        Most peripherals (e.g. expect ADC) can be assigned to any IO pin. So you can change the role in arduinos board definition.
        You can find detailed information about the current consumption in the datasheets. The MySensors sleep function consumes 3ยตA until you want to wait for an Interrupt (1mA). To fix this cores/nRF5/WInterrupts.c needs an partitial rewrite. I have no time at the moment to fix this issue. The discussion about how to fix is sleeping: https://github.com/sandeepmistry/arduino-nRF5/issues/153
        Another point to save some energy is to manage the DCDC converter (not available on all boards) in the radio or sleep code. -> https://devzone.nordicsemi.com/question/685/ldo-vs-dcdc-nrf51822/
        More energy savings, requires breaking the compatibility to NRF24 radios and implementing an additional communication protocol. This allows to implement battery powered nodes which can receive packages.
        When issue 153 is fixed, I think the nRF5 platform is a good choice to start new developments of sensors without the CPU and memory limitations of ATMEGA or maybe in the future the limitations of NRF24 radio. When its not fixed this is a good platform for main powered components and sensors which are only waking up by time.
        • scalzS scalz
          @ileneken3
          d00616D
          d00616D
          d00616
          wrote on last edited by d00616
          #24
          @scalz said in ๐Ÿ’ฌ MySensors NRF5 Platform:
          Low power in implemented at the MySensors side. There is an issue at the Arduino side -> ๐Ÿ’ฌ MySensors NRF5 Platform
          Edit: The radio is saving power in some states. There is a little room for improvments like fast rampup for nRF52. With an NRF24 incompatible protocol there is room for improvements.
          • d00616D d00616
            d00616D
            d00616D
            d00616
            @d00616 I found the current issue is a problem only with older nRF51 hardware. I can't measure the current on with newer nRF51 or nRF52 chips. But a fix is documented in http://infocenter.nordicsemi.com/pdf/nRF51822-pan_v3.0.pdf (s. PAN #39)
            • scalzS
              scalzS
              #26
              @d00616 thx for the info :+1:
              I'll try to measure power consumption asap
              • NeverDieN
                NeverDieN
                #27
                FWIW, you may want to delete this passage in your overview, as it's not really accurate:
                Don't buy an nRF5 development kit to program other nRF5 modules. The programmer is hard wired to the nRF5 chip on most DK boards.
                In fact, Nordic has this video that I just now came across on how to do it:
                https://www.youtube.com/watch?v=n6sNDnRA6BY
                IMHO, I think the DK is a good way for noobs to get started, because the setup is well supported for the onboard nRF52 and "just works." The fact that it can later be used to program external nRF5 devices is a nice (and very poorly advertised) bonus. The DK has a real Segger J-Link on the DK board.
                That being said, the DK is not the cheapest option, so noobs may need to weigh "easy" vs "cheap" in their purchase decision.
                rmtuckerR 1 Reply Last reply
                • NeverDieN NeverDie
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                  I am having problems compiling the Mockmysensors example on the waveshare board.
                  If you comment out all sensors and uncomment
                  #define ID_S_MULTIMETER 28
                  I get the following error:
                  exit status 1
                  call of overloaded 'set(int&)' is ambiguous
                  NeverDieN 1 Reply Last reply
                  • rmtuckerR rmtucker
                    exit status 1
                    NeverDieN
                    NeverDieN
                    @rmtucker said in ๐Ÿ’ฌ MySensors NRF5 Platform:
                    exit status 1
                    Did you remember to do this?
                    //#define MY_RADIO_NRF24
                    #define MY_RADIO_NRF5_ESB
                      exit status 1
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      @NeverDie
                      Yes did that.
                      Strange though if you run the sketch with just the first 2 sensors uncommented it compiles fine.
                      It must me something to do with multimeter?
                      • NeverDieN
                        NeverDieN
                        #31
                        At least on my system, if I don't uncomment anything (other than the passage I just indicated), it at least compiles. Haven't actually tried to see if it works yet....
                        • NeverDieN
                          NeverDieN
                          Well, I just tried what you queried about, and it compiles fine on my system:
                          * MockMySensors
                          * This skecth is intended to crate fake sensors which register and respond to the controller
                          * Barduino 2015, GizMoCuz 2015
                          //#define MY_RADIO_RFM95
                          #define MY_NODE_ID 254
                          #define RADIO_ERROR_LED_PIN 4  // Error led pin
                          #define RADIO_RX_LED_PIN    6  // Receive led pin
                          #define RADIO_TX_LED_PIN    5  // the PCB, on board LED
                          // Wait times
                          #define LONG_WAIT 500
                          #define SHORT_WAIT 50
                          #define SKETCH_NAME "MockMySensors "
                          #define SKETCH_VERSION "v0.5"
                          // Define Sensors ids
                          /*      S_DOOR, S_MOTION, S_SMOKE, S_LIGHT, S_DIMMER, S_COVER, S_TEMP, S_HUM, S_BARO, S_WIND,
                          	S_RAIN, S_UV, S_WEIGHT, S_POWER, S_HEATER, S_DISTANCE, S_LIGHT_LEVEL, S_ARDUINO_NODE,
                          	S_ARDUINO_REPEATER_NODE, S_LOCK, S_IR, S_WATER, S_AIR_QUALITY, S_CUSTOM, S_DUST,
                          	S_SCENE_CONTROLLER
                          ////#define ID_S_ARDUINO_NODE            //auto defined in initialization
                          ////#define ID_S_ARDUINO_REPEATER_NODE   //auto defined in initialization
                          // Some of these ID's have not been updated for v1.5.  Uncommenting too many of them
                          // will make the sketch too large for a pro mini's memory so it's probably best to try
                          // one at a time.
                          //#define ID_S_ARMED             0  // dummy to controll armed stated for several sensors
                          //#define ID_S_DOOR              1
                          //#define ID_S_MOTION            2
                          //#define ID_S_SMOKE             3
                          //#define ID_S_LIGHT             4
                          //#define ID_S_DIMMER            5
                          //#define ID_S_COVER             6
                          //#define ID_S_TEMP              7
                          //#define ID_S_HUM               8
                          //#define ID_S_BARO              9
                          //#define ID_S_WIND              10
                          //#define ID_S_RAIN              11
                          //#define ID_S_UV                12
                          //#define ID_S_WEIGHT            13
                          //#define ID_S_POWER             14
                          //#define ID_S_HEATER            15
                          //#define ID_S_DISTANCE          16
                          //#define ID_S_LIGHT_LEVEL       17
                          //#define ID_S_LOCK              18
                          //#define ID_S_IR                19
                          //#define ID_S_WATER             20
                          //#define ID_S_AIR_QUALITY       21
                          //#define ID_S_DUST              22
                          //#define ID_S_SCENE_CONTROLLER  23
                          //// Lib 1.5 sensors
                          //#define ID_S_RGB_LIGHT         24
                          //#define ID_S_RGBW_LIGHT        25
                          //#define ID_S_COLOR_SENSOR      26
                          //#define ID_S_HVAC              27
                          //#define ID_S_MULTIMETER        28
                          #define ID_S_SPRINKLER         29
                          //#define ID_S_WATER_LEAK        30
                          //#define ID_S_SOUND             31
                          //#define ID_S_VIBRATION         32
                          //#define ID_S_MOISTURE          33
                          //#define ID_S_CUSTOM            99
                          // Global Vars
                          unsigned long SLEEP_TIME = 900000; // Sleep time between reads (in milliseconds)
                          bool metric = true;
                          long randNumber;
                          //Instanciate Messages objects
                          #ifdef ID_S_ARMED
                          bool isArmed;
                          #ifdef ID_S_DOOR // V_TRIPPED, V_ARMED
                          MyMessage msg_S_DOOR_T(ID_S_DOOR,V_TRIPPED);
                          MyMessage msg_S_DOOR_A(ID_S_DOOR,V_ARMED);
                          #ifdef ID_S_MOTION // V_TRIPPED, V_ARMED
                          MyMessage msg_S_MOTION_A(ID_S_MOTION,V_ARMED);
                          MyMessage msg_S_MOTION_T(ID_S_MOTION,V_TRIPPED);
                          #ifdef ID_S_SMOKE  // V_TRIPPED, V_ARMED
                          MyMessage msg_S_SMOKE_T(ID_S_SMOKE,V_TRIPPED);
                          MyMessage msg_S_SMOKE_A(ID_S_SMOKE,V_ARMED);
                          #ifdef ID_S_LIGHT
                          MyMessage msg_S_LIGHT(ID_S_LIGHT,V_LIGHT);
                          bool isLightOn=0;
                          #ifdef ID_S_DIMMER
                          MyMessage msg_S_DIMMER(ID_S_DIMMER,V_DIMMER);
                          int dimmerVal=100;
                          #ifdef ID_S_COVER
                          MyMessage msg_S_COVER_U(ID_S_COVER,V_UP);
                          MyMessage msg_S_COVER_D(ID_S_COVER,V_DOWN);
                          MyMessage msg_S_COVER_S(ID_S_COVER,V_STOP);
                          MyMessage msg_S_COVER_V(ID_S_COVER,V_VAR1);
                          int coverState=0; //0=Stop; 1=up; -1=down
                          #ifdef ID_S_TEMP
                          MyMessage msg_S_TEMP(ID_S_TEMP,V_TEMP);
                          #ifdef ID_S_HUM
                          MyMessage msg_S_HUM(ID_S_HUM,V_HUM);
                          #ifdef ID_S_BARO
                          MyMessage msg_S_BARO_P(ID_S_BARO,V_PRESSURE);
                          MyMessage msg_S_BARO_F(ID_S_BARO,V_FORECAST);
                          #ifdef ID_S_WIND
                          MyMessage msg_S_WIND_S(ID_S_WIND,V_WIND);
                          MyMessage msg_S_WIND_G(ID_S_WIND,V_GUST);
                          MyMessage msg_S_WIND_D(ID_S_WIND,V_DIRECTION);
                          #ifdef ID_S_RAIN
                          MyMessage msg_S_RAIN_A(ID_S_RAIN,V_RAIN);
                          MyMessage msg_S_RAIN_R(ID_S_RAIN,V_RAINRATE);
                          #ifdef ID_S_UV
                          MyMessage msg_S_UV(ID_S_UV,V_UV);
                          #ifdef ID_S_WEIGHT
                          MyMessage msg_S_WEIGHT(ID_S_WEIGHT,V_WEIGHT);
                          #ifdef ID_S_POWER
                          MyMessage msg_S_POWER_W(ID_S_POWER,V_WATT);
                          MyMessage msg_S_POWER_K(ID_S_POWER,V_KWH);
                          #ifdef ID_S_HEATER
                          //////// REVIEW IMPLEMENTATION ////////////
                          MyMessage msg_S_HEATER_SET_POINT(ID_S_HEATER,
                                                           V_HVAC_SETPOINT_HEAT);  // HVAC/Heater setpoint (Integer between 0-100). S_HEATER, S_HVAC
                          MyMessage msg_S_HEATER_FLOW_STATE(ID_S_HEATER,
                                                            V_HVAC_FLOW_STATE);     // Mode of header. One of "Off", "HeatOn", "CoolOn", or "AutoChangeOver" // S_HVAC, S_HEATER
                          //MyMessage msg_S_HEATER_STATUS(ID_S_HEATER,V_STATUS);
                          //MyMessage msg_S_HEATER_TEMP(ID_S_HEATER,V_TEMP);
                          float heater_setpoint=21.5;
                          String heater_flow_state="Off";
                          //  float heater_temp=23.5;
                          //  bool heater_status=false;
                          // V_TEMP                // Temperature
                          // V_STATUS              // Binary status. 0=off 1=on
                          // V_HVAC_FLOW_STATE     // Mode of header. One of "Off", "HeatOn", "CoolOn", or "AutoChangeOver"
                          // V_HVAC_SPEED          // HVAC/Heater fan speed ("Min", "Normal", "Max", "Auto")
                          // V_HVAC_SETPOINT_HEAT  // HVAC/Heater setpoint
                          #ifdef ID_S_DISTANCE
                          MyMessage msg_S_DISTANCE(ID_S_DISTANCE,V_DISTANCE);
                          #ifdef ID_S_LIGHT_LEVEL
                          MyMessage msg_S_LIGHT_LEVEL(ID_S_LIGHT_LEVEL,V_LIGHT_LEVEL);
                          #ifdef ID_S_LOCK
                          MyMessage msg_S_LOCK(ID_S_LOCK,V_LOCK_STATUS);
                          bool isLocked = 0;
                          #ifdef ID_S_IR
                          MyMessage msg_S_IR_S(ID_S_IR,V_IR_SEND);
                          MyMessage msg_S_IR_R(ID_S_IR,V_IR_RECEIVE);
                          long irVal = 0;
                          #ifdef ID_S_WATER
                          MyMessage msg_S_WATER_F(ID_S_WATER,V_FLOW);
                          MyMessage msg_S_WATER_V(ID_S_WATER,V_VOLUME);
                          #ifdef ID_S_AIR_QUALITY
                          MyMessage msg_S_AIR_QUALITY(ID_S_AIR_QUALITY,V_LEVEL);
                          #ifdef ID_S_DUST
                          MyMessage msg_S_DUST(ID_S_DUST,V_LEVEL);
                          #ifdef ID_S_SCENE_CONTROLLER
                          MyMessage msg_S_SCENE_CONTROLLER_ON(ID_S_SCENE_CONTROLLER,V_SCENE_ON);
                          MyMessage msg_S_SCENE_CONTROLLER_OF(ID_S_SCENE_CONTROLLER,V_SCENE_OFF);
                          // not sure if scene controller sends int or chars
                          // betting on ints as Touch Display Scen by Hek // compiler warnings
                          char *scenes[] = {
                          	(char *)"Good Morning",
                          	(char *)"Clean Up!",
                          	(char *)"All Lights Off",
                          	(char *)"Music On/Off"
                          int sceneVal=0;
                          int sceneValPrevious=0;
                          #ifdef ID_S_RGB_LIGHT
                          MyMessage msg_S_RGB_LIGHT_V_RGB(ID_S_RGB_LIGHT,V_RGB);
                          MyMessage msg_S_RGB_LIGHT_V_WATT(ID_S_RGB_LIGHT,V_WATT);
                          String rgbState="000000";
                          //RGB light V_RGB, V_WATT
                          //RGB value transmitted as ASCII hex string (I.e "ff0000" for red)
                          #ifdef ID_S_RGBW_LIGHT
                          MyMessage msg_S_RGBW_LIGHT_V_RGBW(ID_S_RGBW_LIGHT,V_RGBW);
                          MyMessage msg_S_RGBW_LIGHT_V_WATT(ID_S_RGBW_LIGHT,V_WATT);
                          String rgbwState="00000000";
                          //RGBW light (with separate white component)	V_RGBW, V_WATT
                          //RGBW value transmitted as ASCII hex string (I.e "ff0000ff" for red + full white)	S_RGBW_LIGHT
                          #ifdef ID_S_COLOR_SENSOR
                          MyMessage msg_S_COLOR_SENSOR_V_RGB(ID_S_COLOR_SENSOR,V_RGB);
                          //Color sensor	V_RGB
                          //RGB value transmitted as ASCII hex string (I.e "ff0000" for red)	S_RGB_LIGHT, S_COLOR_SENSOR
                          #ifdef ID_S_HVAC
                          MyMessage msg_S_HVAC_V_HVAC_SETPOINT_HEAT(ID_S_HVAC,V_HVAC_SETPOINT_HEAT);
                          MyMessage msg_S_HVAC_V_HVAC_SETPOINT_COOL(ID_S_HVAC,V_HVAC_SETPOINT_COOL);
                          MyMessage msg_S_HVAC_V_HVAC_FLOW_STATET(ID_S_HVAC,V_HVAC_FLOW_STATE);
                          MyMessage msg_S_HVAC_V_HVAC_FLOW_MODE(ID_S_HVAC,V_HVAC_FLOW_MODE);
                          MyMessage msg_S_HVAC_V_HVAC_SPEED(ID_S_HVAC,V_HVAC_SPEED);
                          float hvac_SetPointHeat = 16.5;
                          float hvac_SetPointCool = 25.5;
                          String hvac_FlowState   = "AutoChangeOver";
                          String hvac_FlowMode    = "Auto";
                          String hvac_Speed       = "Normal";
                          //Thermostat/HVAC device
                          //V_HVAC_SETPOINT_HEAT,  // HVAC/Heater setpoint
                          //V_HVAC_SETPOINT_COOL,  // HVAC cold setpoint
                          //V_HVAC_FLOW_STATE,     // Mode of header. One of "Off", "HeatOn", "CoolOn", or "AutoChangeOver"
                          //V_HVAC_FLOW_MODE,      // Flow mode for HVAC ("Auto", "ContinuousOn", "PeriodicOn")
                          //V_HVAC_SPEED           // HVAC/Heater fan speed ("Min", "Normal", "Max", "Auto")
                          // NOT IMPLEMENTED YET
                          //V_TEMP                 // Temperature
                          //V_STATUS               // Binary status. 0=off 1=on
                          #ifdef ID_S_MULTIMETER
                          MyMessage msg_S_MULTIMETER_V_IMPEDANCE(ID_S_MULTIMETER,V_IMPEDANCE);
                          MyMessage msg_S_MULTIMETER_V_VOLTAGE(ID_S_MULTIMETER,V_VOLTAGE);
                          MyMessage msg_S_MULTIMETER_V_CURRENT(ID_S_MULTIMETER,V_CURRENT);
                          // Multimeter device	V_VOLTAGE, V_CURRENT, V_IMPEDANCE
                          // V_IMPEDANCE	14	Impedance value
                          // V_VOLTAGE	38	Voltage level
                          // V_CURRENT	39	Current level
                          #ifdef ID_S_SPRINKLER
                          // S_SPRINKLER	31	Sprinkler device	V_STATUS (turn on/off), V_TRIPPED (if fire detecting device)
                          // V_STATUS	2	Binary status. 0=off 1=on
                          // V_ARMED	15	Armed status of a security sensor. 1=Armed, 0=Bypassed
                          // V_TRIPPED	16	Tripped status of a security sensor. 1=Tripped, 0=Untripped
                          #ifdef ID_S_WATER_LEAK
                          #ifdef ID_S_SOUND
                          #ifdef ID_S_VIBRATION
                          #ifdef ID_S_MOISTURE
                          MyMessage msg_S_MOISTURE(ID_S_MOISTURE,V_LEVEL);
                          #ifdef ID_S_CUSTOM
                          MyMessage msg_S_CUSTOM_1(ID_S_CUSTOM,V_VAR1);
                          MyMessage msg_S_CUSTOM_2(ID_S_CUSTOM,V_VAR2);
                          MyMessage msg_S_CUSTOM_3(ID_S_CUSTOM,V_VAR3);
                          MyMessage msg_S_CUSTOM_4(ID_S_CUSTOM,V_VAR4);
                          MyMessage msg_S_CUSTOM_5(ID_S_CUSTOM,V_VAR5);
                          	// Random SEED
                          	randomSeed(analogRead(0));
                          	wait(LONG_WAIT);
                          	Serial.println("GW Started");
                          	Serial.print("Send Sketch Info: ");
                          	Serial.print(SKETCH_NAME);
                          	Serial.println(SKETCH_VERSION);
                          	wait(LONG_WAIT);
                          	// Get controller configuration
                          	Serial.print("Get Config: ");
                          	Serial.println(metric ? "Metric":"Imperial");
                          	wait(LONG_WAIT);
                          	// Init Armed
                          #ifdef ID_S_ARMED
                          	isArmed = true;
                          	Serial.println("Presenting Nodes");
                          	Serial.println("________________");
                          #ifdef ID_S_DOOR
                          	Serial.println("  S_DOOR");
                          	present(ID_S_DOOR,S_DOOR,"Outside Door");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_MOTION
                          	Serial.println("  S_MOTION");
                          	present(ID_S_MOTION,S_MOTION,"Outside Motion");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_SMOKE
                          	Serial.println("  S_SMOKE");
                          	present(ID_S_SMOKE,S_SMOKE,"Kitchen Smoke");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_LIGHT
                          	Serial.println("  S_LIGHT");
                          	present(ID_S_LIGHT,S_LIGHT,"Hall Light");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_DIMMER
                          	Serial.println("  S_DIMMER");
                          	present(ID_S_DIMMER,S_DIMMER,"Living room dimmer");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_COVER
                          	Serial.println("  S_COVER");
                          	present(ID_S_COVER,S_COVER,"Window cover");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_TEMP
                          	Serial.println("  S_TEMP");
                          	present(ID_S_TEMP,S_TEMP,"House Temperarue");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_HUM
                          	Serial.println("  S_HUM");
                          	present(ID_S_HUM,S_HUM,"Current Humidity");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_BARO
                          	Serial.println("  S_BARO");
                          	present(ID_S_BARO,S_BARO," Air pressure");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_WIND
                          	Serial.println("  S_WIND");
                          	present(ID_S_WIND,S_WIND,"Wind Station");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_RAIN
                          	Serial.println("  S_RAIN");
                          	present(ID_S_RAIN,S_RAIN,"Rain Station");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_UV
                          	Serial.println("  S_UV");
                          	present(ID_S_UV,S_UV,"Ultra Violet");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_WEIGHT
                          	Serial.println("  S_WEIGHT");
                          	present(ID_S_WEIGHT,S_WEIGHT,"Outdoor Scale");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_POWER
                          	Serial.println("  S_POWER");
                          	present(ID_S_POWER,S_POWER,"Power Metric");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_HEATER
                          	Serial.println("  S_HEATER");
                          	present(ID_S_HEATER,S_HEATER,"Garage Heater");
                          	wait(SHORT_WAIT);
                          	Serial.println("  S_DISTANCE");
                          	present(ID_S_DISTANCE,S_DISTANCE,"Distance Measure");
                          	wait(SHORT_WAIT);
                          	Serial.println("  S_LIGHT_LEVEL");
                          	present(ID_S_LIGHT_LEVEL,S_LIGHT_LEVEL,"Outside Light Level");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_LOCK
                          	Serial.println("  S_LOCK");
                          	present(ID_S_LOCK,S_LOCK,"Front Door Lock");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_IR
                          	Serial.println("  S_IR");
                          	present(ID_S_IR,S_IR,"Univeral Command");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_WATER
                          	Serial.println("  S_WATER");
                          	present(ID_S_WATER,S_WATER,"Water Level");
                          	wait(SHORT_WAIT);
                          	Serial.println("  S_AIR_QUALITY");
                          	present(ID_S_AIR_QUALITY,S_AIR_QUALITY,"Air Station");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_DUST
                          	Serial.println("  S_DUST");
                          	present(ID_S_DUST,S_DUST,"Dust Level");
                          	wait(SHORT_WAIT);
                          	Serial.println("  S_SCENE_CONTROLLER");
                          	present(ID_S_SCENE_CONTROLLER,S_SCENE_CONTROLLER,"Scene Controller");
                          	wait(SHORT_WAIT);
                          	Serial.println("  RGB_LIGHT");
                          	present(ID_S_RGB_LIGHT,S_RGB_LIGHT,"Mood Light");
                          	wait(SHORT_WAIT);
                          	Serial.println("  RGBW_LIGHT");
                          	present(ID_S_RGBW_LIGHT,S_RGBW_LIGHT,"Mood Light 2");
                          	wait(SHORT_WAIT);
                          	Serial.println("  COLOR_SENSOR");
                          	present(ID_S_COLOR_SENSOR,S_COLOR_SENSOR,"Hall Painting");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_HVAC
                          	Serial.println("  HVAC");
                          	present(ID_S_HVAC,S_HVAC,"HVAC");
                          	wait(SHORT_WAIT);
                          	Serial.println("  MULTIMETER");
                          	present(ID_S_MULTIMETER,S_MULTIMETER,"Electric Staion");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_SOUND
                          	Serial.println("  S_MOISTURE");
                          	present(ID_S_MOISTURE,S_MOISTURE,"Basement Sensor");
                          	wait(SHORT_WAIT);
                          #ifdef ID_S_CUSTOM
                          	Serial.println("  S_CUSTOM");
                          	present(ID_S_CUSTOM,S_CUSTOM,"Other Stuff");
                          	wait(SHORT_WAIT);
                          	Serial.println("");
                          	Serial.println("");
                          	Serial.println("");
                          	Serial.println("#########################");
                          	randNumber=random(0,101);
                          	Serial.print("RandomNumber:");
                          	Serial.println(randNumber);
                          	// Send fake battery level
                          	Serial.println("Send Battery Level");
                          	sendBatteryLevel(randNumber);
                          	wait(LONG_WAIT);
                          	// Request time
                          	Serial.println("Request Time");
                          	requestTime();
                          	wait(LONG_WAIT);
                          	//Read Sensors
                          #ifdef ID_S_DOOR
                          	door();
                          #ifdef ID_S_MOTION
                          	motion();
                          #ifdef ID_S_SMOKE
                          	smoke();
                          #ifdef ID_S_LIGHT
                          	light();
                          #ifdef ID_S_DIMMER
                          	dimmer();
                          #ifdef ID_S_COVER
                          	cover();
                          #ifdef ID_S_TEMP
                          	temp();
                          #ifdef ID_S_HUM
                          	hum();
                          #ifdef ID_S_BARO
                          	baro();
                          #ifdef ID_S_WIND
                          	wind();
                          #ifdef ID_S_RAIN
                          	rain();
                          #ifdef ID_S_UV
                          	uv();
                          #ifdef ID_S_WEIGHT
                          	weight();
                          #ifdef ID_S_POWER
                          	power();
                          #ifdef ID_S_HEATER
                          	heater();
                          	distance();
                          	light_level();
                          #ifdef ID_S_LOCK
                          	lock();
                          #ifdef ID_S_IR
                          	ir();
                          #ifdef ID_S_WATER
                          	water();
                          	air();
                          #ifdef ID_S_DUST
                          	dust();
                          	scene();
                          	rgbLight();
                          	rgbwLight();
                          	color();
                          #ifdef ID_S_HVAC
                          	hvac();
                          	multimeter();
                          #ifdef ID_S_SOUND
                          	moisture();
                          #ifdef ID_S_CUSTOM
                          	custom();
                          	wait(SHORT_WAIT);
                          	wait(SLEEP_TIME); //sleep a bit
                          // This is called when a new time value was received
                          void receiveTime(unsigned long controllerTime)
                          	Serial.print("Time value received: ");
                          	Serial.println(controllerTime);
                          //void door(){}
                          #ifdef ID_S_DOOR
                          void door()
                          	Serial.print("Door is: " );
                          	if (randNumber <= 50) {
                          		Serial.println("Open");
                          		send(msg_S_DOOR_T.set((int16_t)1));
                          	} else {
                          		Serial.println("Closed");
                          		send(msg_S_DOOR_T.set((int16_t)0));
                          #ifdef ID_S_ARMED
                          	Serial.print("System is: " );
                          	Serial.println((isArmed ? "Armed":"Disarmed"));
                          	send(msg_S_DOOR_A.set(isArmed));
                          #ifdef ID_S_MOTION
                          void motion()
                          	Serial.print("Motion is: " );
                          		Serial.println("Active");
                          		send(msg_S_MOTION_T.set(1));
                          	} else {
                          		Serial.println("Quiet");
                          		send(msg_S_MOTION_T.set(0));
                          #ifdef ID_S_ARMED
                          	send(msg_S_MOTION_A.set(isArmed));
                          #ifdef ID_S_SMOKE
                          void smoke()
                          	Serial.print("Smoke is: " );
                          		send(msg_S_SMOKE_T.set(1));
                          	} else {
                          		send(msg_S_SMOKE_T.set(0));
                          #ifdef ID_S_ARMED
                          	send(msg_S_SMOKE_A.set(isArmed));
                          #ifdef ID_S_LIGHT
                          void light()
                          	Serial.print("Light is: " );
                          	Serial.println((isLightOn ? "On":"Off"));
                          	send(msg_S_LIGHT.set(isLightOn));
                          #ifdef ID_S_DIMMER
                          void dimmer()
                          	Serial.print("Dimmer is set to: " );
                          	Serial.println(dimmerVal);
                          	send(msg_S_DIMMER.set(dimmerVal));
                          #ifdef ID_S_COVER
                          void cover()
                          	Serial.print("Cover is : " );
                          	if (coverState == 1) {
                          		Serial.println("Opening");
                          		send(msg_S_COVER_U.set(1));
                          	} else if (coverState == -1) {
                          		Serial.println("Closing");
                          		send(msg_S_COVER_D.set(0));
                          	} else {
                          		Serial.println("Idle");
                          		send(msg_S_COVER_S.set(-1));
                          	send(msg_S_COVER_V.set(coverState));
                          #ifdef ID_S_TEMP
                          void temp()
                          	Serial.print("Temperature is: " );
                          	Serial.println(map(randNumber,1,100,0,45));
                          	send(msg_S_TEMP.set(map(randNumber,1,100,0,45)));
                          #ifdef ID_S_HUM
                          void hum()
                          	Serial.print("Humitidty is: " );
                          	send(msg_S_HUM.set(randNumber));
                          #ifdef ID_S_BARO
                          void baro()
                          	const char *weather[] = {"stable","sunny","cloudy","unstable","thunderstorm","unknown"};
                          	long pressure = map(randNumber,1,100,870,1086);// hPa?
                          	int forecast = map(randNumber,1,100,0,5);
                          	Serial.print("Atmosferic Pressure is: " );
                          	Serial.println(pressure);
                          	send(msg_S_BARO_P.set(pressure));
                          	Serial.print("Weather forecast: " );
                          	Serial.println(weather[forecast]);
                          	send(msg_S_BARO_F.set(weather[forecast]));
                          #ifdef ID_S_WIND
                          void wind()
                          	Serial.print("Wind Speed is: " );
                          	send(msg_S_WIND_S.set(randNumber));
                          	Serial.print("Wind Gust is: " );
                          	Serial.println(randNumber+10);
                          	send(msg_S_WIND_G.set(randNumber+10));
                          	Serial.print("Wind Direction is: " );
                          	Serial.println(map(randNumber,1,100,0,360));
                          	send(msg_S_WIND_D.set(map(randNumber,1,100,0,360)));
                          #ifdef ID_S_RAIN
                          void rain()
                          	Serial.print("Rain ammount  is: " );
                          	send(msg_S_RAIN_A.set(randNumber));
                          	Serial.print("Rain rate  is: " );
                          	Serial.println(randNumber/60);
                          	send(msg_S_RAIN_R.set(randNumber/60,1));
                          #ifdef ID_S_UV
                          void uv()
                          	Serial.print("Ultra Violet level is: " );
                          	Serial.println(map(randNumber,1,100,0,15));
                          	send(msg_S_UV.set(map(randNumber,1,100,0,15)));
                          #ifdef ID_S_WEIGHT
                          void weight()
                          	Serial.print("Weight is: " );
                          	Serial.println(map(randNumber,1,100,0,150));
                          	send(msg_S_WEIGHT.set(map(randNumber,1,100,0,150)));
                          #ifdef ID_S_POWER
                          void power()
                          	Serial.print("Watt is: " );
                          	send(msg_S_POWER_W.set(map(randNumber,1,100,0,150)));
                          	Serial.print("KWH is: " );
                          	send(msg_S_POWER_K.set(map(randNumber,1,100,0,150)));
                          #ifdef ID_S_HEATER
                          void heater()
                          	//  float heater_setpoint=21.5;
                          	//  String heatState="Off";
                          	Serial.print("Heater flow state is: " );
                          	Serial.println(heater_flow_state);
                          	send(msg_S_HEATER_FLOW_STATE.set(heater_flow_state.c_str()));
                          	//  Serial.print("Heater on/off is: " );
                          	//  Serial.println((heater_status==true)?"On":"Off");
                          	//  send(msg_S_HEATER_STATUS.set(heater_status));
                          	//  Serial.print("Heater Temperature is: " );
                          	//  Serial.println(heater_temp,1);
                          	//  send(msg_S_HEATER_TEMP.set(heater_temp,1));
                          	Serial.print("Heater Setpoint: " );
                          	Serial.println(heater_setpoint,1);
                          	send(msg_S_HEATER_SET_POINT.set(heater_setpoint,1));
                          void distance()
                          	Serial.print("Distance is: " );
                          	send(msg_S_DISTANCE.set(map(randNumber,1,100,0,150)));
                          void light_level()
                          	send(msg_S_LIGHT_LEVEL.set(map(randNumber,1,100,0,150)));
                          #ifdef ID_S_LOCK
                          void lock()
                          	Serial.print("Lock is: " );
                          	Serial.println((isLocked ? "Locked":"Unlocked"));
                          	send(msg_S_LOCK.set(isLocked));
                          #ifdef ID_S_IR
                          void ir()
                          	Serial.print("Infrared is: " );
                          	Serial.println(irVal);
                          	send(msg_S_IR_S.set(irVal));
                          	send(msg_S_IR_R.set(irVal));
                          #ifdef ID_S_WATER
                          void water()
                          	Serial.print("Water flow is: " );
                          	send(msg_S_WATER_F.set(map(randNumber,1,100,0,150)));
                          	Serial.print("Water volume is: " );
                          	send(msg_S_WATER_V.set(map(randNumber,1,100,0,150)));
                          void air()
                          	Serial.print("Air Quality is: " );
                          	send(msg_S_AIR_QUALITY.set(randNumber));
                          #ifdef ID_S_DUST
                          void dust()
                          	Serial.print("Dust level is: " );
                          	send(msg_S_DUST.set(randNumber));
                          void scene()
                          	Serial.print("Scene is: " );
                          	Serial.println(scenes[sceneVal]);
                          	if(sceneValPrevious != sceneVal) {
                          		send(msg_S_SCENE_CONTROLLER_OF.set(sceneValPrevious));
                          		send(msg_S_SCENE_CONTROLLER_ON.set(sceneVal));
                          		sceneValPrevious=sceneVal;
                          void rgbLight()
                          	Serial.print("RGB Light state is: " );
                          	Serial.println(rgbState);
                          	send(msg_S_RGB_LIGHT_V_RGB.set(rgbState.c_str()));
                          	Serial.print("RGB Light Watt is: " );
                          	send(msg_S_RGB_LIGHT_V_WATT.set(map(randNumber,1,100,0,150)));
                          void rgbwLight()
                          	Serial.print("RGBW Light state is: " );
                          	Serial.println(rgbwState);
                          	send(msg_S_RGBW_LIGHT_V_RGBW.set(rgbwState.c_str()));
                          	Serial.print("RGBW Light Watt is: " );
                          	send(msg_S_RGBW_LIGHT_V_WATT.set(map(randNumber,1,100,0,150)));
                          void color()
                          	String colorState;
                          	String red   = String(random(0,256),HEX);
                          	String green = String(random(0,256),HEX);
                          	String blue  = String(random(0,256),HEX);
                          	colorState=String(red + green + blue);
                          	Serial.print("Color state is: " );
                          	Serial.println(colorState);
                          	send(msg_S_COLOR_SENSOR_V_RGB.set(colorState.c_str()));
                          #ifdef ID_S_HVAC
                          void hvac()
                          	//  float hvac_SetPointHeat = 16.5;
                          	//  float hvac_SetPointCool = 25.5;
                          	//  String hvac_FlowState   = "AutoChangeOver";
                          	//  String hvac_FlowMode    = "Auto";
                          	//  String hvac_Speed       = "Normal";
                          	Serial.print("HVAC Set Point Heat is: " );
                          	Serial.println(hvac_SetPointHeat);
                          	send(msg_S_HVAC_V_HVAC_SETPOINT_HEAT.set(hvac_SetPointHeat,1));
                          	Serial.print("HVAC Set Point Cool is: " );
                          	Serial.println(hvac_SetPointCool);
                          	send(msg_S_HVAC_V_HVAC_SETPOINT_COOL.set(hvac_SetPointCool,1));
                          	Serial.print("HVAC Flow State is: " );
                          	Serial.println(hvac_FlowState);
                          	send(msg_S_HVAC_V_HVAC_FLOW_STATET.set(hvac_FlowState.c_str()));
                          	Serial.print("HVAC Flow Mode is: " );
                          	Serial.println(hvac_FlowMode);
                          	send(msg_S_HVAC_V_HVAC_FLOW_MODE.set(hvac_FlowMode.c_str()));
                          	Serial.print("HVAC Speed is: " );
                          	Serial.println(hvac_Speed);
                          	send(msg_S_HVAC_V_HVAC_SPEED.set(hvac_Speed.c_str()));
                          void multimeter()
                          	int impedance=map(randNumber,1,100,0,15000);
                          	int volt=map(randNumber,1,100,0,380);
                          	int amps=map(randNumber,1,100,0,16);
                          	Serial.print("Impedance is: " );
                          	Serial.println(impedance);
                          	send(msg_S_MULTIMETER_V_IMPEDANCE.set(impedance));
                          	Serial.print("Voltage is: " );
                          	Serial.println(volt);
                          	send(msg_S_MULTIMETER_V_VOLTAGE.set(volt));
                          	Serial.print("Current is: " );
                          	Serial.println(amps);
                          	send(msg_S_MULTIMETER_V_CURRENT.set(amps));
                          #ifdef ID_S_SOUND
                          void moisture()
                          	Serial.print("Moisture level is: " );
                          	send(msg_S_MOISTURE.set(randNumber));
                          #ifdef ID_S_CUSTOM
                          void custom()
                          	Serial.print("Custom value is: " );
                          	send(msg_S_CUSTOM_1.set(randNumber));
                          	send(msg_S_CUSTOM_2.set(randNumber));
                          	send(msg_S_CUSTOM_3.set(randNumber));
                          	send(msg_S_CUSTOM_4.set(randNumber));
                          	send(msg_S_CUSTOM_5.set(randNumber));
                          	switch (message.type) {
                          #ifdef ID_S_ARMED
                          	case V_ARMED:
                          		isArmed = message.getBool();
                          		Serial.print("Incoming change for ID_S_ARMED:");
                          		Serial.print(message.sensor);
                          		Serial.println((isArmed ? "Armed":"Disarmed" ));
                          #ifdef ID_S_DOOR
                          		door();//temp ack for door
                          #ifdef ID_S_MOTION
                          		motion();//temp ack
                          #ifdef ID_S_SMOKE
                          		smoke();//temp ack
                          		break;
                          	case V_STATUS: // V_LIGHT:
                          #ifdef ID_S_LIGHT
                          		if(message.sensor==ID_S_LIGHT) {
                          			isLightOn =  message.getBool();
                          			Serial.print("Incoming change for ID_S_LIGHT:");
                          			light(); // temp ack
                          		//    #ifdef ID_S_HEATER
                          		//        if(message.sensor == ID_S_HEATER){
                          		//          heater_status = message.getBool();
                          		//          Serial.print("Incoming change for ID_S_HEATER:");
                          		//          Serial.print(message.sensor);
                          		//          Serial.print(", New status: ");
                          		//          Serial.println(heater_status);
                          		//          heater();//temp ack
                          		//    #endif
                          		break;
                          #ifdef ID_S_DIMMER
                          	case V_DIMMER:
                          		if ((message.getInt()<0)||(message.getInt()>100)) {
                          			Serial.println( "V_DIMMER data invalid (should be 0..100)" );
                          			break;
                          		dimmerVal= message.getInt();
                          		Serial.print("Incoming change for ID_S_DIMMER:");
                          		Serial.println(message.getInt());
                          		dimmer();// temp ack
                          		break;
                          #ifdef ID_S_COVER
                          	case V_UP:
                          		coverState=1;
                          		Serial.print("Incoming change for ID_S_COVER:");
                          		Serial.println("V_UP");
                          		cover(); // temp ack
                          		break;
                          	case V_DOWN:
                          		coverState=-1;
                          		Serial.println("V_DOWN");
                          		cover(); //temp ack
                          		break;
                          	case V_STOP:
                          		coverState=0;
                          		Serial.println("V_STOP");
                          		cover(); //temp ack
                          		break;
                          	case V_HVAC_SETPOINT_HEAT:
                          #ifdef ID_S_HEATER
                          		if(message.sensor == ID_S_HEATER) {
                          			heater_setpoint=message.getFloat();
                          			Serial.print("Incoming set point for ID_S_HEATER:");
                          			heater();//temp ack
                          #ifdef ID_S_HVAC
                          		if(message.sensor == ID_S_HVAC) {
                          			hvac_SetPointHeat=message.getFloat();
                          			Serial.print("Incoming set point for ID_S_HVAC:");
                          			Serial.println(hvac_SetPointHeat,1);
                          			hvac();//temp ack
                          		break;
                          	case V_HVAC_FLOW_STATE:
                          #ifdef ID_S_HEATER
                          			heater_flow_state=message.getString();
                          			Serial.print("Incoming flow state change for ID_S_HEATER:");
                          			heater();//temp ack
                          #ifdef ID_S_HVAC
                          			hvac_FlowState=message.getString();
                          			hvac();//temp ack
                          		break;
                          #ifdef ID_S_LOCK
                          	case V_LOCK_STATUS:
                          		isLocked =  message.getBool();
                          		Serial.print("Incoming change for ID_S_LOCK:");
                          		Serial.println(message.getBool()?"Locked":"Unlocked");
                          		lock(); //temp ack
                          		break;
                          #ifdef ID_S_IR
                          	case V_IR_SEND:
                          		irVal = message.getLong();
                          		Serial.print("Incoming change for ID_S_IR:");
                          		ir(); // temp ack
                          		break;
                          	case V_IR_RECEIVE:
                          		ir(); // temp ack
                          		break;
                          	case V_SCENE_ON:
                          		sceneVal = message.getInt();
                          		Serial.print("Incoming change for ID_S_SCENE_CONTROLLER:");
                          		Serial.print(scenes[sceneVal]);
                          		Serial.println(" On");
                          		scene();// temp ack
                          		break;
                          	case V_SCENE_OFF:
                          		Serial.println(" Off");
                          		scene();// temp ack
                          		break;
                          	case V_RGB:
                          		rgbState=message.getString();
                          		Serial.print("Incoming flow state change for ID_S_RGB_LIGHT:");
                          		rgbLight(); // temp ack
                          		break;
                          	case V_RGBW:
                          		rgbwState=message.getString();
                          		Serial.print("Incoming flow state change for ID_S_RGBW_LIGHT:");
                          		rgbwLight();
                          		break;
                          #ifdef ID_S_HVAC
                          	//  hvac_SetPointHeat
                          	//  hvac_SetPointCool
                          	//  hvac_FlowState
                          	//  hvac_FlowMode
                          	//  hvac_Speed
                          	case V_HVAC_SETPOINT_COOL:
                          		hvac_SetPointCool=message.getFloat();
                          		Serial.println(hvac_SetPointCool,1);
                          		hvac();//temp ack
                          		break;
                          	case V_HVAC_FLOW_MODE:
                          		hvac_Speed=message.getString();
                          		hvac();//temp ack
                          		break;
                          	case V_HVAC_SPEED:
                          		hvac_FlowMode=message.getString();
                          		hvac();//temp ack
                          		break;
                          	default:
                          		Serial.print("Unknown/UnImplemented message type: ");
                          		Serial.println(message.type);
                            * MockMySensors
                            // Wait times
                            	S_SCENE_CONTROLLER
                            // one at a time.
                            // Global Vars
                            bool metric = true;
                            long randNumber;
                            #ifdef ID_S_ARMED
                            bool isArmed;
                            #ifdef ID_S_LIGHT
                            bool isLightOn=0;
                            #ifdef ID_S_DIMMER
                            int dimmerVal=100;
                            #ifdef ID_S_COVER
                            #ifdef ID_S_TEMP
                            #ifdef ID_S_HUM
                            #ifdef ID_S_BARO
                            #ifdef ID_S_WIND
                            #ifdef ID_S_RAIN
                            #ifdef ID_S_UV
                            #ifdef ID_S_WEIGHT
                            #ifdef ID_S_POWER
                            #ifdef ID_S_HEATER
                            #ifdef ID_S_LOCK
                            bool isLocked = 0;
                            #ifdef ID_S_IR
                            long irVal = 0;
                            #ifdef ID_S_WATER
                            #ifdef ID_S_DUST
                            char *scenes[] = {
                            int sceneVal=0;
                            #ifdef ID_S_HVAC
                            #ifdef ID_S_SOUND
                            #ifdef ID_S_CUSTOM
                            	// Random SEED
                            	wait(LONG_WAIT);
                            	wait(LONG_WAIT);
                            	wait(LONG_WAIT);
                            	// Init Armed
                            #ifdef ID_S_ARMED
                            	isArmed = true;
                            #ifdef ID_S_DOOR
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_MOTION
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_SMOKE
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_LIGHT
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_DIMMER
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_COVER
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_TEMP
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_HUM
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_BARO
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_WIND
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_RAIN
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_UV
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_WEIGHT
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_POWER
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_HEATER
                            	wait(SHORT_WAIT);
                            	wait(SHORT_WAIT);
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_LOCK
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_IR
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_WATER
                            	wait(SHORT_WAIT);
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_DUST
                            	wait(SHORT_WAIT);
                            	wait(SHORT_WAIT);
                            	wait(SHORT_WAIT);
                            	wait(SHORT_WAIT);
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_HVAC
                            	wait(SHORT_WAIT);
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_SOUND
                            	wait(SHORT_WAIT);
                            #ifdef ID_S_CUSTOM
                            	wait(SHORT_WAIT);
                            	Serial.println("");
                            	Serial.println("");
                            	Serial.println("");
                            	wait(LONG_WAIT);
                            	// Request time
                            	requestTime();
                            	wait(LONG_WAIT);
                            	//Read Sensors
                            #ifdef ID_S_DOOR
                            	door();
                            #ifdef ID_S_MOTION
                            	motion();
                            #ifdef ID_S_SMOKE
                            	smoke();
                            #ifdef ID_S_LIGHT
                            	light();
                            #ifdef ID_S_DIMMER
                            	dimmer();
                            #ifdef ID_S_COVER
                            	cover();
                            #ifdef ID_S_TEMP
                            	temp();
                            #ifdef ID_S_HUM
                            	hum();
                            #ifdef ID_S_BARO
                            	baro();
                            #ifdef ID_S_WIND
                            	wind();
                            #ifdef ID_S_RAIN
                            	rain();
                            #ifdef ID_S_UV
                            	uv();
                            #ifdef ID_S_WEIGHT
                            	weight();
                            #ifdef ID_S_POWER
                            	power();
                            #ifdef ID_S_HEATER
                            	heater();
                            	distance();
                            	light_level();
                            #ifdef ID_S_LOCK
                            	lock();
                            #ifdef ID_S_IR
                            	ir();
                            #ifdef ID_S_WATER
                            	water();
                            	air();
                            #ifdef ID_S_DUST
                            	dust();
                            	scene();
                            	rgbLight();
                            	rgbwLight();
                            	color();
                            #ifdef ID_S_HVAC
                            	hvac();
                            	multimeter();
                            #ifdef ID_S_SOUND
                            	moisture();
                            #ifdef ID_S_CUSTOM
                            	custom();
                            	wait(SHORT_WAIT);
                            //void door(){}
                            #ifdef ID_S_DOOR
                            void door()
                            	} else {
                            #ifdef ID_S_ARMED
                            #ifdef ID_S_MOTION
                            void motion()
                            	} else {
                            #ifdef ID_S_ARMED
                            #ifdef ID_S_SMOKE
                            void smoke()
                            	} else {
                            #ifdef ID_S_ARMED
                            #ifdef ID_S_LIGHT
                            void light()
                            #ifdef ID_S_DIMMER
                            void dimmer()
                            #ifdef ID_S_COVER
                            void cover()
                            	} else {
                            #ifdef ID_S_TEMP
                            void temp()
                            #ifdef ID_S_HUM
                            void hum()
                            #ifdef ID_S_BARO
                            void baro()
                            #ifdef ID_S_WIND
                            void wind()
                            #ifdef ID_S_RAIN
                            void rain()
                            #ifdef ID_S_UV
                            void uv()
                            #ifdef ID_S_WEIGHT
                            void weight()
                            #ifdef ID_S_POWER
                            void power()
                            #ifdef ID_S_HEATER
                            void heater()
                            void distance()
                            void light_level()
                            #ifdef ID_S_LOCK
                            void lock()
                            #ifdef ID_S_IR
                            void ir()
                            #ifdef ID_S_WATER
                            void water()
                            void air()
                            #ifdef ID_S_DUST
                            void dust()
                            void scene()
                            void rgbLight()
                            void rgbwLight()
                            void color()
                            	String colorState;
                            #ifdef ID_S_HVAC
                            void hvac()
                            void multimeter()
                            #ifdef ID_S_SOUND
                            void moisture()
                            #ifdef ID_S_CUSTOM
                            void custom()
                            #ifdef ID_S_ARMED
                            	case V_ARMED:
                            #ifdef ID_S_DOOR
                            #ifdef ID_S_MOTION
                            		motion();//temp ack
                            #ifdef ID_S_SMOKE
                            		smoke();//temp ack
                            		break;
                            #ifdef ID_S_LIGHT
                            		//    #endif
                            		break;
                            #ifdef ID_S_DIMMER
                            	case V_DIMMER:
                            			break;
                            		break;
                            #ifdef ID_S_COVER
                            	case V_UP:
                            		coverState=1;
                            		break;
                            	case V_DOWN:
                            		coverState=-1;
                            		cover(); //temp ack
                            		break;
                            	case V_STOP:
                            		coverState=0;
                            		cover(); //temp ack
                            		break;
                            #ifdef ID_S_HEATER
                            			heater();//temp ack
                            #ifdef ID_S_HVAC
                            			hvac();//temp ack
                            		break;
                            #ifdef ID_S_HEATER
                            			heater();//temp ack
                            #ifdef ID_S_HVAC
                            			hvac();//temp ack
                            		break;
                            #ifdef ID_S_LOCK
                            	case V_LOCK_STATUS:
                            		lock(); //temp ack
                            		break;
                            #ifdef ID_S_IR
                            	case V_IR_SEND:
                            		ir(); // temp ack
                            		break;
                            	case V_IR_RECEIVE:
                            		ir(); // temp ack
                            		break;
                            	case V_SCENE_ON:
                            		scene();// temp ack
                            		break;
                            	case V_SCENE_OFF:
                            		scene();// temp ack
                            		break;
                            	case V_RGB:
                            		break;
                            	case V_RGBW:
                            		rgbwLight();
                            		break;
                            #ifdef ID_S_HVAC
                            	//  hvac_FlowState
                            	//  hvac_FlowMode
                            	//  hvac_Speed
                            		hvac();//temp ack
                            		break;
                            		hvac();//temp ack
                            		break;
                            	case V_HVAC_SPEED:
                            		hvac();//temp ack
                            		break;
                            	default:
                            NeverDieN
                            NeverDieN
                            Oops. Uncommented the wrong thing. I'll try again.
                            • NeverDieN
                              NeverDieN
                              OK, confirmed. The full error message is:
                              Build options changed, rebuilding all
                              C:\Users\CoolerMaster\Documents\Arduino\mysensors sketches\mockmysensors\MockMySensors_v002\MockMySensors_v002.ino: In function 'void multimeter()':
                              MockMySensors_v002:1183: error: call of overloaded 'set(int&)' is ambiguous
                              In file included from C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/MySensors.h:364:0,
                                               from C:\Users\CoolerMaster\Documents\Arduino\mysensors sketches\mockmysensors\MockMySensors_v002\MockMySensors_v002.ino:20:
                              C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:269:12: note: candidate: MyMessage& MyMessage::set(bool)
                               MyMessage& MyMessage::set(bool value)
                              C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:277:12: note: candidate: MyMessage& MyMessage::set(uint8_t)
                               MyMessage& MyMessage::set(uint8_t value)
                              C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:294:12: note: candidate: MyMessage& MyMessage::set(uint32_t)
                               MyMessage& MyMessage::set(uint32_t value)
                              C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:302:12: note: candidate: MyMessage& MyMessage::set(int32_t)
                               MyMessage& MyMessage::set(int32_t value)
                              C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:310:12: note: candidate: MyMessage& MyMessage::set(uint16_t)
                               MyMessage& MyMessage::set(uint16_t value)
                              C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:318:12: note: candidate: MyMessage& MyMessage::set(int16_t)
                               MyMessage& MyMessage::set(int16_t value)
                              MockMySensors_v002:1187: error: call of overloaded 'set(int&)' is ambiguous
                              MockMySensors_v002:1191: error: call of overloaded 'set(int&)' is ambiguous
                              exit status 1
                                rmtuckerR
                                rmtuckerR
                                rmtucker
                                @NeverDie
                                Ha Yes Sprinkler works fine.
                                  exit status 1
                                  rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  @NeverDie
                                  So after running through all the sensors in the mockmysensors sketch there are quite a few that have the same problem.
                                  I have done the same tests on my standard setup ATmega328 and all compile ok.
                                  I also tried some of my own small sketches on both platforms and had problems on the nrf5 platform with the same error.
                                  So is this a mySensors problem or is it something deeper?.
                                  Why should it not work on both as far as the syntax is concerned.
                                  Who if anybody do i report the problem too?
                                  I took the plunge and ordered a jlink/v2 programmer and a waveshare BLE400 motherboard and core module (I know it is nrf51822 but it is a start) but i hope the above problem can be sorted out.
                                    @NeverDie
                                    NeverDieN
                                    NeverDieN
                                    #37
                                    Yes, the ones I noticed that seem to have the problem are: motion, smoke, dimmer, cover, scene controller, and, of course, multimeter. The rest compiled.
                                    I don't know the answers to your other good questions, but AFAIK @d00616 appears to be the point man. Perhaps @d00616 can comment?
                                    Also, if you're not already aware of it, @rmtucker I invite you to join in on the constantly evolving discussion at: https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/498
                                    rmtuckerR 3 Replies Last reply
                                      rmtuckerR
                                      rmtuckerR
                                      rmtucker
                                      @NeverDie
                                      After trawling through posts on the forum the following changes compile ok.
                                      Altered int to uint16_t
                                      void multimeter()
                                      	uint16_t impedance=map(randNumber,1,100,0,15000);
                                      	uint16_t volt=map(randNumber,1,100,0,380);
                                      	uint16_t amps=map(randNumber,1,100,0,16);
                                      #endif```
                                        rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        @NeverDie
                                        After adding a Few uint16_t the whole sketch now compiles with all the sensors turned on and only uses 19% of available memory space :smiley: ,could never have done that on the ATmega platform.
                                        Just wish we could work out why it had to be changed
                                        * MockMySensors
                                        // Wait times
                                        	S_SCENE_CONTROLLER
                                        // one at a time.
                                        #define ID_S_DOOR              1
                                        #define ID_S_TEMP              7
                                        #define ID_S_HUM               8
                                        #define ID_S_BARO              9
                                        #define ID_S_UV                12
                                        #define ID_S_IR                19
                                        // Global Vars
                                        bool metric = true;
                                        long randNumber;
                                        #ifdef ID_S_ARMED
                                        bool isArmed;
                                        #ifdef ID_S_LIGHT
                                        bool isLightOn=0;
                                        #ifdef ID_S_DIMMER
                                        uint16_t dimmerVal=100;
                                        #ifdef ID_S_COVER
                                        #ifdef ID_S_TEMP
                                        #ifdef ID_S_HUM
                                        #ifdef ID_S_BARO
                                        #ifdef ID_S_WIND
                                        #ifdef ID_S_RAIN
                                        #ifdef ID_S_UV
                                        #ifdef ID_S_WEIGHT
                                        #ifdef ID_S_POWER
                                        #ifdef ID_S_HEATER
                                        #ifdef ID_S_LOCK
                                        bool isLocked = 0;
                                        #ifdef ID_S_IR
                                        long irVal = 0;
                                        #ifdef ID_S_WATER
                                        #ifdef ID_S_DUST
                                        char *scenes[] = {
                                        int sceneVal=0;
                                        #ifdef ID_S_HVAC
                                        #ifdef ID_S_SOUND
                                        #ifdef ID_S_CUSTOM
                                        	// Random SEED
                                        	wait(LONG_WAIT);
                                        	wait(LONG_WAIT);
                                        	wait(LONG_WAIT);
                                        	// Init Armed
                                        #ifdef ID_S_ARMED
                                        	isArmed = true;
                                        #ifdef ID_S_DOOR
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_MOTION
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_SMOKE
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_LIGHT
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_DIMMER
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_COVER
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_TEMP
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_HUM
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_BARO
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_WIND
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_RAIN
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_UV
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_WEIGHT
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_POWER
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_HEATER
                                        	wait(SHORT_WAIT);
                                        	wait(SHORT_WAIT);
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_LOCK
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_IR
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_WATER
                                        	wait(SHORT_WAIT);
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_DUST
                                        	wait(SHORT_WAIT);
                                        	wait(SHORT_WAIT);
                                        	wait(SHORT_WAIT);
                                        	wait(SHORT_WAIT);
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_HVAC
                                        	wait(SHORT_WAIT);
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_SOUND
                                        	wait(SHORT_WAIT);
                                        #ifdef ID_S_CUSTOM
                                        	wait(SHORT_WAIT);
                                        	Serial.println("");
                                        	Serial.println("");
                                        	Serial.println("");
                                        	wait(LONG_WAIT);
                                        	// Request time
                                        	requestTime();
                                        	wait(LONG_WAIT);
                                        	//Read Sensors
                                        #ifdef ID_S_DOOR
                                        	door();
                                        #ifdef ID_S_MOTION
                                        	motion();
                                        #ifdef ID_S_SMOKE
                                        	smoke();
                                        #ifdef ID_S_LIGHT
                                        	light();
                                        #ifdef ID_S_DIMMER
                                        	dimmer();
                                        #ifdef ID_S_COVER
                                        	cover();
                                        #ifdef ID_S_TEMP
                                        	temp();
                                        #ifdef ID_S_HUM
                                        	hum();
                                        #ifdef ID_S_BARO
                                        	baro();
                                        #ifdef ID_S_WIND
                                        	wind();
                                        #ifdef ID_S_RAIN
                                        	rain();
                                        #ifdef ID_S_UV
                                        	uv();
                                        #ifdef ID_S_WEIGHT
                                        	weight();
                                        #ifdef ID_S_POWER
                                        	power();
                                        #ifdef ID_S_HEATER
                                        	heater();
                                        	distance();
                                        	light_level();
                                        #ifdef ID_S_LOCK
                                        	lock();
                                        #ifdef ID_S_IR
                                        	ir();
                                        #ifdef ID_S_WATER
                                        	water();
                                        	air();
                                        #ifdef ID_S_DUST
                                        	dust();
                                        	scene();
                                        	rgbLight();
                                        	rgbwLight();
                                        	color();
                                        #ifdef ID_S_HVAC
                                        	hvac();
                                        	multimeter();
                                        #ifdef ID_S_SOUND
                                        	moisture();
                                        #ifdef ID_S_CUSTOM
                                        	custom();
                                        	wait(SHORT_WAIT);
                                        //void door(){}
                                        #ifdef ID_S_DOOR
                                        void door()
                                        	} else {
                                        #ifdef ID_S_ARMED
                                        #ifdef ID_S_MOTION
                                        void motion()
                                        		send(msg_S_MOTION_T.set((uint16_t) 1));
                                        	} else {
                                        		send(msg_S_MOTION_T.set((uint16_t) 0));
                                        #ifdef ID_S_ARMED
                                        #ifdef ID_S_SMOKE
                                        void smoke()
                                        		send(msg_S_SMOKE_T.set((uint16_t) 1));
                                        	} else {
                                        		send(msg_S_SMOKE_T.set((uint16_t) 0));
                                        #ifdef ID_S_ARMED
                                        #ifdef ID_S_LIGHT
                                        void light()
                                        #ifdef ID_S_DIMMER
                                        void dimmer()
                                        #ifdef ID_S_COVER
                                        void cover()
                                        		send(msg_S_COVER_U.set((uint16_t) 1));
                                        		send(msg_S_COVER_D.set((uint16_t) 0));
                                        	} else {
                                        		send(msg_S_COVER_S.set((uint16_t) -1));
                                        	send(msg_S_COVER_V.set((uint16_t) coverState));
                                        #ifdef ID_S_TEMP
                                        void temp()
                                        #ifdef ID_S_HUM
                                        void hum()
                                        #ifdef ID_S_BARO
                                        void baro()
                                        #ifdef ID_S_WIND
                                        void wind()
                                        #ifdef ID_S_RAIN
                                        void rain()
                                        #ifdef ID_S_UV
                                        void uv()
                                        #ifdef ID_S_WEIGHT
                                        void weight()
                                        #ifdef ID_S_POWER
                                        void power()
                                        #ifdef ID_S_HEATER
                                        void heater()
                                        void distance()
                                        void light_level()
                                        #ifdef ID_S_LOCK
                                        void lock()
                                        #ifdef ID_S_IR
                                        void ir()
                                        #ifdef ID_S_WATER
                                        void water()
                                        void air()
                                        #ifdef ID_S_DUST
                                        void dust()
                                        void scene()
                                        		send(msg_S_SCENE_CONTROLLER_OF.set((uint16_t) sceneValPrevious));
                                        		send(msg_S_SCENE_CONTROLLER_ON.set((uint16_t) sceneVal));
                                        void rgbLight()
                                        void rgbwLight()
                                        void color()
                                        	String colorState;
                                        #ifdef ID_S_HVAC
                                        void hvac()
                                        void multimeter()
                                        #ifdef ID_S_SOUND
                                        void moisture()
                                        #ifdef ID_S_CUSTOM
                                        void custom()
                                        #ifdef ID_S_ARMED
                                        	case V_ARMED:
                                        #ifdef ID_S_DOOR
                                        #ifdef ID_S_MOTION
                                        		motion();//temp ack
                                        #ifdef ID_S_SMOKE
                                        		smoke();//temp ack
                                        		break;
                                        #ifdef ID_S_LIGHT
                                        		//    #endif
                                        		break;
                                        #ifdef ID_S_DIMMER
                                        	case V_DIMMER:
                                        			break;
                                        		break;
                                        #ifdef ID_S_COVER
                                        	case V_UP:
                                        		coverState=1;
                                        		break;
                                        	case V_DOWN:
                                        		coverState=-1;
                                        		cover(); //temp ack
                                        		break;
                                        	case V_STOP:
                                        		coverState=0;
                                        		cover(); //temp ack
                                        		break;
                                        #ifdef ID_S_HEATER
                                        			heater();//temp ack
                                        #ifdef ID_S_HVAC
                                        			hvac();//temp ack
                                        		break;
                                        #ifdef ID_S_HEATER
                                        			heater();//temp ack
                                        #ifdef ID_S_HVAC
                                        			hvac();//temp ack
                                        		break;
                                        #ifdef ID_S_LOCK
                                        	case V_LOCK_STATUS:
                                        		lock(); //temp ack
                                        		break;
                                        #ifdef ID_S_IR
                                        	case V_IR_SEND:
                                        		ir(); // temp ack
                                        		break;
                                        	case V_IR_RECEIVE:
                                        		ir(); // temp ack
                                        		break;
                                        	case V_SCENE_ON:
                                        		scene();// temp ack
                                        		break;
                                        	case V_SCENE_OFF:
                                        		scene();// temp ack
                                        		break;
                                        	case V_RGB:
                                        		break;
                                        	case V_RGBW:
                                        		rgbwLight();
                                        		break;
                                        #ifdef ID_S_HVAC
                                        	//  hvac_FlowState
                                        	//  hvac_FlowMode
                                        	//  hvac_Speed
                                        		hvac();//temp ack
                                        		break;
                                        		hvac();//temp ack
                                        		break;
                                        	case V_HVAC_SPEED:
                                        		hvac();//temp ack
                                        		break;
                                        	default:
                                          @NeverDie
                                          void multimeter()
                                          #endif```
                                          d00616D
                                          d00616D
                                          d00616
                                          This issue seems to be an 32 bit platform issue. With SAMD I see equal error messages. This needs fixing at message level.
                                          With your input, this post could be even better ๐Ÿ’—
