  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
  • d00616D
    d00616D
    d00616
    I have added a note at the end of the installation documentation. To make things easier, I have opened an issue to update the Arduino-nRF5 release.
    https://github.com/sandeepmistry/arduino-nRF5/issues/182
    d00616D 1 Reply Last reply
    • d00616D d00616
      d00616D
      d00616D
      d00616
      I2C should be fixed now. Version 0.4.0 is released!
      rmtuckerR NeverDieN 2 Replies Last reply
      • d00616D d00616
        rmtuckerR
        rmtuckerR
        rmtucker
        @d00616
        So should i be able to delete the hardware folder that the development version created from github and just update from boards manager?.
        • rmtuckerR rmtucker
          @d00616
          d00616D
          d00616D
          d00616
          @rmtucker said in 💬 MySensors NRF5 Platform:
          If this don't work, remove all folder created by hardware and boards manager, close Arduino IDE and reinstall it via Boards Manager.
          • F
            F
            Fabien
            Hi, I don't us nrf52 yet but as i'm a platformio supporter, There is a new release for nrf52 platform with initial arduino framework support ! Good news, i think I will test nrf52 in few weeks.
            https://github.com/platformio/platform-nordicnrf52/releases/tag/v1.2.0
            • d00616D d00616
              NeverDieN
              NeverDieN
              @d00616 said in 💬 MySensors NRF5 Platform:
              To help clarify for others who are reading this: the Arduino IDE board manager let me upgrade to 0.4.0 from 0.3.0 by just clicking on the board entry "Nordic Semiconductor NRF5 Boards by Sandeep Mistry", selecting the 0.4.0 version, and then clicking Install.
              • d00616D
                d00616D
                d00616
                1. I have updated the radio driver with fixes for some hardware errata.
                2. I have updated the https://github.com/mysensors/ArduinoHwNRF5 with an enhanced definition format. File name and contents are changed! The board description is compatible with the NRF5 variant provided by Arduino, but it's not possible to use this variant at the moment.
                NeverDieN 1 Reply Last reply
                • d00616D d00616
                  NeverDieN
                  NeverDieN
                  Where do we find the update? i.e. is it baked into the regular MySensors development code thread, or is it elsewhere?
                  • NeverDieN
                    NeverDieN
                    I'm guessing it's this one? https://github.com/mysensors/ArduinoHwNRF5
                    • NeverDieN NeverDie
                      NeverDieN
                      NeverDieN
                      #70
                      I refreshed all the libraries. I'm able to compile and upload my sketches, but now it complains a lot about "invalid libraries."
                      WARNING: Spurious .ci folder in 'MySensors' library
                      WARNING: Spurious .mystools folder in 'MySensors' library
                      Sketch uses 3836 bytes (0%) of program storage space. Maximum is 524288 bytes.
                      Open On-Chip Debugger 0.10.0-dev-00254-g696fc0a (2016-04-10-10:13)
                      Licensed under GNU GPL v2
                      For bug reports, read
                         http://openocd.org/doc/doxygen/bugs.html
                      debug_level: 0
                      adapter speed: 10000 kHz
                      cortex_m reset_config sysresetreq
                      nrf52.cpu: target state: halted
                      target halted due to debug-request, current mode: Thread
                      xPSR: 0x01000000 pc: 0x000006e8 msp: 0x20010000
                      ** Programming Started **
                      auto erase enabled
                      wrote 4096 bytes from file C:\Users\David\AppData\Local\Temp\arduino_build_255419/Interrupt_button_test_v005.ino.hex in 0.800001s (5.000 KiB/s)
                      ** Programming Finished **
                      ** Verify Started **
                      verified 3964 bytes in 0.060000s (64.518 KiB/s)
                      ** Verified OK **
                      ** Resetting Target **
                      shutdown command invoked
                      Invalid library found in C:\Users\David\Documents\Arduino\libraries\arduino-nRF5: C:\Users\David\Documents\Arduino\libraries\arduino-nRF5
                      Invalid library found in C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5: C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5
                        debug_level: 0
                        auto erase enabled
                        ** Verified OK **
                        d00616D
                        d00616D
                        d00616
                        @NeverDie said in 💬 MySensors NRF5 Platform:
                        At the moment, I cannot reproduce this with Linux and Arduino 1.8.2. I try to find out what's wrong.
                        • d00616D d00616
                          d00616D
                          d00616D
                          d00616
                          wrote on last edited by d00616
                          #72
                          Can you try to remove the .ci and .mystools folders?
                          • d00616D d00616
                            NeverDieN
                            NeverDieN
                            Done. So, here it is now:
                            Archiving built core (caching) in: C:\Users\David\AppData\Local\Temp\arduino_cache_16539\core\core_MySensors_nRF5_MyBoard_nRF52832_bootcode_none,lfclk_lfxo,reset_notenable_2d457965a40837233e636c052c58b359.a
                            Sketch uses 3872 bytes (0%) of program storage space. Maximum is 524288 bytes.
                            debug_level: 0
                            xPSR: 0x01000000 pc: 0x0000070c msp: 0x20010000
                            auto erase enabled
                            wrote 4096 bytes from file C:\Users\David\AppData\Local\Temp\arduino_build_610023/Interrupt_button_test_v006.ino.hex in 0.800001s (5.000 KiB/s)
                            verified 4000 bytes in 0.060000s (65.104 KiB/s)
                            ** Verified OK **
                            BTW, I'm using the Windows version of Arduino IDE 1.8.5, which is the most current.
                              debug_level: 0
                              auto erase enabled
                              ** Verified OK **
                              d00616D
                              d00616D
                              d00616
                              I don't know the correct path on an Windows system. On my system the Sketches are in the ~/Arduino folder in my home directory (~). The arduino-nrf5 is in ~/.arduino15/packages/sandeepmistry/hardware/nRF5/0.4.0 and the ArduinoHwNRF5 files are in ~/.arduino15/packages/MySensors/hardware/nRF5/0.2.1
                                on my Windows machine, all boards are located in c:\Users<username>\AppData\Local\Arduino15\packages
                                Strange that they've been installed to C:\Users\David\Documents\Arduino\libraries\ on your machine.
                                Maybe just delete the folders and re-install using the board manager?
                                  NeverDieN
                                  NeverDieN
                                  @mfalkvidd All I know is that if I put a library in the folder: C:\Users\David\Documents\Arduino\libraries
                                  it always gets detected and used. It also means you can completely uninstall/re-install the arduino IDE, and nothing gets lost. I'm not sure about other locations.
                                  Am I the only one doing it this way?
                                    @NeverDie for libraries, doing what you do should result in the same behavior as when using the Library Manager.
                                    But I'm not sure it works with boards (especially given that the Arduino IDE complains when you put boards in the libraries folder).
                                    • NeverDieN
                                      NeverDieN
                                      I use the board manager to manage the boards. I believe it connects directly into github.
                                      Anyhow, I stripped out all the non-library stuff, and now Windows IDE works without complaining.
                                      • NeverDieN
                                        NeverDieN
                                        #79
                                        Has anyone here yet figured out how to have more than one type of interrupt at a time wake-up the MCU from sleep? Based on the examples so far, it seems as though only one type at a time can be active. I'm sure there must be some way to do it. For instance, it would be desirable if the MCU could wake up not just from a timer event every, say, 5 minutes, to take a temperature reading, but also immediately if there is a leak detected. Right now it's just one or the other.
                                        rmtuckerR 1 Reply Last reply
                                          rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          @NeverDie
                                          So we can not use the normal statement
                                          int8_t sleep(int interrupt, int mode, unsigned long ms=0);
                                          I did not realize that was the case as i have never tried it.
