  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
  • d00616D d00616
    1. I have updated the radio driver with fixes for some hardware errata.
    2. I have updated the https://github.com/mysensors/ArduinoHwNRF5 with an enhanced definition format. File name and contents are changed! The board description is compatible with the NRF5 variant provided by Arduino, but it's not possible to use this variant at the moment.
    Where do we find the update? i.e. is it baked into the regular MySensors development code thread, or is it elsewhere?
      I'm guessing it's this one? https://github.com/mysensors/ArduinoHwNRF5
        #70
        I refreshed all the libraries. I'm able to compile and upload my sketches, but now it complains a lot about "invalid libraries."
        Sketch uses 3836 bytes (0%) of program storage space. Maximum is 524288 bytes.
        Licensed under GNU GPL v2
        For bug reports, read
        debug_level: 0
        adapter speed: 10000 kHz
        xPSR: 0x01000000 pc: 0x000006e8 msp: 0x20010000
        ** Programming Started **
        auto erase enabled
        wrote 4096 bytes from file C:\Users\David\AppData\Local\Temp\arduino_build_255419/Interrupt_button_test_v005.ino.hex in 0.800001s (5.000 KiB/s)
        ** Programming Finished **
        ** Verify Started **
        verified 3964 bytes in 0.060000s (64.518 KiB/s)
        ** Verified OK **
        ** Resetting Target **
        shutdown command invoked
        Invalid library found in C:\Users\David\Documents\Arduino\libraries\arduino-nRF5: C:\Users\David\Documents\Arduino\libraries\arduino-nRF5
        Invalid library found in C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5: C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5
        d00616D 1 Reply Last reply
          debug_level: 0
          auto erase enabled
          ** Verified OK **
          d00616D
          d00616D
          d00616
          @NeverDie said in 💬 MySensors NRF5 Platform:
          At the moment, I cannot reproduce this with Linux and Arduino 1.8.2. I try to find out what's wrong.
          • d00616D d00616
            d00616D
            d00616D
            d00616
            wrote on last edited by d00616
            #72
            Can you try to remove the .ci and .mystools folders?
            • d00616D d00616
              Done. So, here it is now:
              Archiving built core (caching) in: C:\Users\David\AppData\Local\Temp\arduino_cache_16539\core\core_MySensors_nRF5_MyBoard_nRF52832_bootcode_none,lfclk_lfxo,reset_notenable_2d457965a40837233e636c052c58b359.a
              Sketch uses 3872 bytes (0%) of program storage space. Maximum is 524288 bytes.
              debug_level: 0
              xPSR: 0x01000000 pc: 0x0000070c msp: 0x20010000
              auto erase enabled
              wrote 4096 bytes from file C:\Users\David\AppData\Local\Temp\arduino_build_610023/Interrupt_button_test_v006.ino.hex in 0.800001s (5.000 KiB/s)
              verified 4000 bytes in 0.060000s (65.104 KiB/s)
              ** Verified OK **
              BTW, I'm using the Windows version of Arduino IDE 1.8.5, which is the most current.
                debug_level: 0
                auto erase enabled
                ** Verified OK **
                d00616D
                d00616D
                d00616
                I don't know the correct path on an Windows system. On my system the Sketches are in the ~/Arduino folder in my home directory (~). The arduino-nrf5 is in ~/.arduino15/packages/sandeepmistry/hardware/nRF5/0.4.0 and the ArduinoHwNRF5 files are in ~/.arduino15/packages/MySensors/hardware/nRF5/0.2.1
                • mfalkviddM
                  on my Windows machine, all boards are located in c:\Users<username>\AppData\Local\Arduino15\packages
                  Strange that they've been installed to C:\Users\David\Documents\Arduino\libraries\ on your machine.
                  Maybe just delete the folders and re-install using the board manager?
                    @mfalkvidd All I know is that if I put a library in the folder: C:\Users\David\Documents\Arduino\libraries
                    it always gets detected and used. It also means you can completely uninstall/re-install the arduino IDE, and nothing gets lost. I'm not sure about other locations.
                    Am I the only one doing it this way?
                      @NeverDie for libraries, doing what you do should result in the same behavior as when using the Library Manager.
                      But I'm not sure it works with boards (especially given that the Arduino IDE complains when you put boards in the libraries folder).
                        I use the board manager to manage the boards. I believe it connects directly into github.
                        Anyhow, I stripped out all the non-library stuff, and now Windows IDE works without complaining.
                          #79
                          Has anyone here yet figured out how to have more than one type of interrupt at a time wake-up the MCU from sleep? Based on the examples so far, it seems as though only one type at a time can be active. I'm sure there must be some way to do it. For instance, it would be desirable if the MCU could wake up not just from a timer event every, say, 5 minutes, to take a temperature reading, but also immediately if there is a leak detected. Right now it's just one or the other.
                          rmtuckerR 1 Reply Last reply
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            So we can not use the normal statement
                            int8_t sleep(int interrupt, int mode, unsigned long ms=0);
                            I did not realize that was the case as i have never tried it.
                              #81
                              I believe hwSleep(..) is the preferred incantation, but beyond that I'm not sure of anything. Maybe @d00616 can comment?
                              I should be receiving a number of different PCB projects tomorrow for final assembly and test, and if I can't resolve this soon, I'm simply going to release them without full demo code.
                              scalzS 1 Reply Last reply
                                #82
                                In MySensors, the regular way to use sleep mode is by using the sleep() functions:
                                https://www.mysensors.org/download/sensor_api_20#sleeping
                                But like you said, you can also use the raw hwSleep() from the hw abstraction layer. Or you could also rewrite it!
                                Which means at each abstraction layer, there are additional logics. sleep() functions have more logics (regarding MySensors states and features) than the raw hwSleep for example (like testing if there is an ongoing ota, smartsleep, heartbeat etc..). I have nodes where i use raw or not, but it's good to know what's behind.
                                • scalzS scalz
                                  rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  @scalz
                                  So the statement
                                  Can be used for timer and pin interrupt at he same time on the NRF5 platform just like the arduino?
                                    I'll try it, but I have strong doubts that it's going to work.
                                    FWIW, here's the pin mapping currently being supplied by digitalPinToInterrupt(..) for the nRF5:
                                    Digital pin 0 = interrupt pin 0
                                    Digital pin 1 = interrupt pin 1
                                    Digital pin 2 = interrupt pin 2
                                    Digital pin 3 = interrupt pin 3
                                    Digital pin 4 = interrupt pin 4
                                    Digital pin 5 = interrupt pin 5
                                    Digital pin 6 = interrupt pin 6
                                    Digital pin 7 = interrupt pin 7
                                    Digital pin 8 = interrupt pin 8
                                    Digital pin 9 = interrupt pin 9
                                    Digital pin 10 = interrupt pin 10
                                    Digital pin 11 = interrupt pin 11
                                    Digital pin 12 = interrupt pin 12
                                    Digital pin 13 = interrupt pin 13
                                    Digital pin 14 = interrupt pin 14
                                    Digital pin 15 = interrupt pin 15
                                    Digital pin 16 = interrupt pin 16
                                    Digital pin 17 = interrupt pin 17
                                    Digital pin 18 = interrupt pin 18
                                    Digital pin 19 = interrupt pin 19
                                    Digital pin 20 = interrupt pin 20
                                    Digital pin 21 = interrupt pin 21
                                    Digital pin 22 = interrupt pin 22
                                    Digital pin 23 = interrupt pin 23
                                    Digital pin 24 = interrupt pin 24
                                    Digital pin 25 = interrupt pin 25
                                    Digital pin 26 = interrupt pin 26
                                    Digital pin 27 = interrupt pin 27
                                    Digital pin 28 = interrupt pin 28
                                    Digital pin 29 = interrupt pin 29
                                    Digital pin 30 = interrupt pin 30
                                      #85
                                      The last I heard, from @d00616 , we had to supply code such as:
                                          // Enable interrupt
                                        NVIC_EnableIRQ(RTC0_IRQn);
                                      and
                                      // This must be in one line
                                      extern "C" { void RTC0_IRQHandler(void) {rtcInterruptCounter++; NRF5_RESET_EVENT(NRF_RTC0->EVENTS_OVRFLW); NRF_RTC0->EVENTS_OVRFLW=0; }}
                                      to get interrupts to work. Even with that approach, though, I haven't gotten it to support any interrupts in addition to a timed sleeping, though I have gotten it to support one interrupt that's separate from a timed sleeping (basically, sleeps indefinitely until the interrupt happens).
                                        #86
                                        OK, I just now tried:
                                          sleep(3,CHANGE,3000);
                                        and, as I suspected, it does nothing but sleep for 3 seconds. It's not responsive to any changes on pin P03 on an nRF52.
                                        @scalz Are you getting a different result? It seems like there's a strong disconnect somewhere between what you're recommending and what I am experiencing.
                                          #87
                                          I didn't give any recommandation, you misread. I just said the regular way to use sleep feature in mysensors, for users, is with sleep(..). But I agree, I misread you too! when you were asking for the specific nrf52 case I guess :)
                                          That said, I got this working when I made my recessed node for door (accelerometer and hall effect sensor with sleeping). Maybe things have changed in the lib?? or not. I'm struggling between different version of the lib, and some are different from the dev branch.. I'll recheck this asap (not sure for this evening).
