  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
    looking at d00616 howto it's explained to use Mysensors development branch (or maybe he added it today :) ). but that makes sense as this port is newer than master branch.
    it uses the core libraries depending on the board used in Arduino.
    • scalzS scalz
      #59
      @scalz: I think @rmtucker was discussing using the development version of the sandeepmistry nrf5 Arduino library, it was not related to the MySensors library.
      rmtuckerR 1 Reply Last reply
        rmtuckerR
        rmtuckerR
        rmtucker
        @mfalkvidd
        Sorry i should have made it more understandable.
        When you follow the instructions below as per sandeeps site it does not install the latest NR5 libraries that you see on github.
        Installing
        Board Manager
        Download and install the Arduino IDE (At least v1.6.12)
        Start the Arduino IDE
        Go into Preferences
        Add https://sandeepmistry.github.io/arduino-nRF5/package_nRF5_boards_index.json as an "Additional Board Manager URL"
        Open the Boards Manager from the Tools -> Board menu and install "Nordic Semiconductor nRF5 Boards"
        Select your nRF5 board from the Tools -> Board menu
        Following this you must install the development version aswell which is what you see on github by doing this.
        From git (for core development)
        Follow steps from Board Manager section above
        cd <SKETCHBOOK>, where <SKETCHBOOK> is your Arduino Sketch folder:
        OS X: ~/Documents/Arduino
        Linux: ~/Arduino
        Windows: ~/Documents/Arduino
        Create a folder named hardware, if it does not exist, and change directories to it
        Clone this repo: git clone https://github.com/sandeepmistry/arduino-nRF5.git sandeepmistry/nRF5
        Restart the Arduino IDE
        Otherwise you run into all kinds of problems using the old library.
        • d00616D
          d00616D
          d00616
          I have added a note at the end of the installation documentation. To make things easier, I have opened an issue to update the Arduino-nRF5 release.
          https://github.com/sandeepmistry/arduino-nRF5/issues/182
          d00616D 1 Reply Last reply
          • d00616D d00616
            d00616D
            d00616D
            d00616
            I2C should be fixed now. Version 0.4.0 is released!
            rmtuckerR NeverDieN 2 Replies Last reply
            • d00616D d00616
              rmtuckerR
              rmtuckerR
              rmtucker
              @d00616
              So should i be able to delete the hardware folder that the development version created from github and just update from boards manager?.
              • rmtuckerR rmtucker
                @d00616
                d00616D
                d00616D
                d00616
                @rmtucker said in 💬 MySensors NRF5 Platform:
                If this don't work, remove all folder created by hardware and boards manager, close Arduino IDE and reinstall it via Boards Manager.
                • F
                  F
                  Fabien
                  Hi, I don't us nrf52 yet but as i'm a platformio supporter, There is a new release for nrf52 platform with initial arduino framework support ! Good news, i think I will test nrf52 in few weeks.
                  https://github.com/platformio/platform-nordicnrf52/releases/tag/v1.2.0
                  • d00616D d00616
                    To help clarify for others who are reading this: the Arduino IDE board manager let me upgrade to 0.4.0 from 0.3.0 by just clicking on the board entry "Nordic Semiconductor NRF5 Boards by Sandeep Mistry", selecting the 0.4.0 version, and then clicking Install.
                    • d00616D
                      d00616D
                      d00616
                      1. I have updated the radio driver with fixes for some hardware errata.
                      2. I have updated the https://github.com/mysensors/ArduinoHwNRF5 with an enhanced definition format. File name and contents are changed! The board description is compatible with the NRF5 variant provided by Arduino, but it's not possible to use this variant at the moment.
                      • d00616D d00616
                        Where do we find the update? i.e. is it baked into the regular MySensors development code thread, or is it elsewhere?
                          I'm guessing it's this one? https://github.com/mysensors/ArduinoHwNRF5
                            #70
                            I refreshed all the libraries. I'm able to compile and upload my sketches, but now it complains a lot about "invalid libraries."
                            Sketch uses 3836 bytes (0%) of program storage space. Maximum is 524288 bytes.
                            Licensed under GNU GPL v2
                            For bug reports, read
                            debug_level: 0
                            adapter speed: 10000 kHz
                            xPSR: 0x01000000 pc: 0x000006e8 msp: 0x20010000
                            ** Programming Started **
                            auto erase enabled
                            wrote 4096 bytes from file C:\Users\David\AppData\Local\Temp\arduino_build_255419/Interrupt_button_test_v005.ino.hex in 0.800001s (5.000 KiB/s)
                            ** Programming Finished **
                            ** Verify Started **
                            verified 3964 bytes in 0.060000s (64.518 KiB/s)
                            ** Verified OK **
                            ** Resetting Target **
                            shutdown command invoked
                            Invalid library found in C:\Users\David\Documents\Arduino\libraries\arduino-nRF5: C:\Users\David\Documents\Arduino\libraries\arduino-nRF5
                            Invalid library found in C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5: C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5
                              debug_level: 0
                              auto erase enabled
                              ** Verified OK **
                              d00616D
                              d00616D
                              d00616
                              @NeverDie said in 💬 MySensors NRF5 Platform:
                              At the moment, I cannot reproduce this with Linux and Arduino 1.8.2. I try to find out what's wrong.
                              • d00616D d00616
                                d00616D
                                d00616D
                                d00616
                                wrote on last edited by d00616
                                #72
                                Can you try to remove the .ci and .mystools folders?
                                • d00616D d00616
                                  Done. So, here it is now:
                                  Archiving built core (caching) in: C:\Users\David\AppData\Local\Temp\arduino_cache_16539\core\core_MySensors_nRF5_MyBoard_nRF52832_bootcode_none,lfclk_lfxo,reset_notenable_2d457965a40837233e636c052c58b359.a
                                  Sketch uses 3872 bytes (0%) of program storage space. Maximum is 524288 bytes.
                                  debug_level: 0
                                  xPSR: 0x01000000 pc: 0x0000070c msp: 0x20010000
                                  auto erase enabled
                                  wrote 4096 bytes from file C:\Users\David\AppData\Local\Temp\arduino_build_610023/Interrupt_button_test_v006.ino.hex in 0.800001s (5.000 KiB/s)
                                  verified 4000 bytes in 0.060000s (65.104 KiB/s)
                                  ** Verified OK **
                                  BTW, I'm using the Windows version of Arduino IDE 1.8.5, which is the most current.
                                    debug_level: 0
                                    auto erase enabled
                                    ** Verified OK **
                                    d00616D
                                    d00616D
                                    d00616
                                    I don't know the correct path on an Windows system. On my system the Sketches are in the ~/Arduino folder in my home directory (~). The arduino-nrf5 is in ~/.arduino15/packages/sandeepmistry/hardware/nRF5/0.4.0 and the ArduinoHwNRF5 files are in ~/.arduino15/packages/MySensors/hardware/nRF5/0.2.1
                                    • mfalkviddM
                                      on my Windows machine, all boards are located in c:\Users<username>\AppData\Local\Arduino15\packages
                                      Strange that they've been installed to C:\Users\David\Documents\Arduino\libraries\ on your machine.
                                      Maybe just delete the folders and re-install using the board manager?
                                        @mfalkvidd All I know is that if I put a library in the folder: C:\Users\David\Documents\Arduino\libraries
                                        it always gets detected and used. It also means you can completely uninstall/re-install the arduino IDE, and nothing gets lost. I'm not sure about other locations.
                                        Am I the only one doing it this way?
                                          @NeverDie for libraries, doing what you do should result in the same behavior as when using the Library Manager.
                                          But I'm not sure it works with boards (especially given that the Arduino IDE complains when you put boards in the libraries folder).
