  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
  • NeverDieN
    NeverDieN
    #121
    @d00616 You mentioned that it works only with a particular version of GCC. Does that mean I need to have a particular version of the Arduino IDE installed? I'm currently running the latest version of Windows Arduino IDE, which is 1.8.5.
    d00616D 1 Reply Last reply
    • NeverDieN
      NeverDieN
      #122
      The irony of it all is that the earlier setup from 3 or so weeks ago seemed to work just fine. Unfortunately, I no longer have any idea how to get back to that. :sob:
      • scalzS
        scalzS
        wrote on last edited by scalz
        #123
        @NeverDie
        C:\Users...\AppData\Local\Arduino15\packages\MySensors\
        NeverDieN 1 Reply Last reply
        • scalzS scalz
          @NeverDie
          NeverDieN
          NeverDieN
          #124
          @scalz said in 💬 MySensors NRF5 Platform:
          @NeverDie
          Thanks!
          The good news is that it compiles now. Also, the pin mapping for an LED is working. However, the bad news is that pin mapping for Serial Rx and Tx doesn't seem to be working, so I can't read any serial debug messages. Therefore, not sure if I2C is working or not.
          • NeverDieN
            NeverDieN
            I did another purge and reinsatall of the boards, and now serial is working. :)
            • NeverDieN
              NeverDieN
              Unfortunately, it does not appear that I2C is working.
              • NeverDieN
                NeverDieN
                Curiously, I2c does seem to work on a nRF52 DK using the myboard board definition.
                • NeverDieN
                  NeverDieN
                  However, it doesn't seem to be working on the nrf51.
                  • NeverDieN NeverDie
                    d00616D
                    d00616D
                    d00616
                    @neverdie said in 💬 MySensors NRF5 Platform:
                    The GCC version is part of the arduino-nrf5 distribution.
                    I have I2C and serial running with a NRF52832.
                    You can try to remove the compat_pin_mapping line and add the 0.1.0 pin map at this place. Then the board definition is nearly the 0.1.0 version.
                    I check the NRF51 board. What do you mean with no working?
                    NeverDieN 4 Replies Last reply
                    • NeverDieN
                      NeverDieN
                      I hope that narrows down the likely cause of the problem. The fact that it's working on the nRF52 gives me some hope it can be made to work on the nRF51.
                      • d00616D d00616
                        NeverDieN
                        NeverDieN
                        @d00616 said in 💬 MySensors NRF5 Platform:
                        The nRF51 can't find the si7021 device, even though it's connected.
                        • d00616D d00616
                          NeverDieN
                          NeverDieN
                          Yes, it does seem to work on the nRF52832. Just not presently on the nRF51822.
                          • d00616D d00616
                            NeverDieN
                            NeverDieN
                            #133
                            I'm running the sparkfun si7021 code. When I run it on the nrf52832, it yields:
                            Si7021 Found
                            Temp:70.51F, Humidity:40.71%
                            which is correct, but when I run it on the nRF51822, the result is:
                            No Devices Detected
                            Temp:-51.85F, Humidity:-5.81%
                            which is incorrect.
                              d00616D
                              d00616D
                              d00616
                              wrote on last edited by d00616
                              #134
                              Can you check, if the device works with the "Generic NRF51822" board? You can edit the variant files in the arduino-nrf5\variants directory.
                              C:\Users...\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.4.0\variants\Generic
                              • d00616D d00616
                                NeverDieN
                                NeverDieN
                                I tried, but I guess I'm not doing it right. I couldn't even get it to blink an LED that way.
                                • d00616D d00616
                                  NeverDieN
                                  NeverDieN
                                  So, I take it you are suggesting that in myboardnrf5.cpp, where it says:
                                  #ifdef MYBOARDNRF5
                                  #include <variant.h>
                                  #include <compat_pin_mapping.h>
                                  I replace
                                  with what exactly? At this point I'm not even sure where 0.1.0 pin-map is, or even what it's called.
                                    NeverDieN
                                    NeverDieN
                                    #137
                                    After I modify the generic variant board definition, is there some trick to making it go "live"?
                                    • scalzS
                                      scalzS
                                      #138
                                      @NeverDie
                                      there is no trick.. it should work.
                                      d00616 said, for a test, to not use his defines, the method that you're used to.
                                      So change the defines you need in the generic variant file, then in arduino:
                                      • NeverDieN
                                        NeverDieN
                                        I think this must be where the disconnect is happening. Where do I find the files or directory for Generic nRF51? The closest I see is a directory called just "Generic":
                                        That's the one I tried modifying:
                                        and it had no effect. So, I suspect there must be a different "generic nRF51" somewhere which is closely tied with the menu item you show the picture of. However, I don't see where.
                                        Nca78N 1 Reply Last reply
                                          Nca78N
                                          Nca78N
                                          @neverdie did you check there ?
