  3. Domoticz
  4. Domoticz - soil moisture + one relay = Lua script error (Blockly)
27 Posts 2 Posters 10.0k Views 2 Watching
  • k5austriaK
    k5austriaK
    k5austria
    This post is deleted!
    • k5austriaK
      k5austriaK
      k5austria
      • k5austriaK
        k5austriaK
        k5austria
        wrote on last edited by k5austria
        #23
        Sensor logs on to Gateway only with original sketch. Other sketchs can be quite normal uploaded to Arduino but remains for GW invisible.
          Pls post node serial output when not connecting to the gateway
          • k5austriaK
            k5austriaK
            k5austria
            wrote on last edited by gohan
            #25
            3 TSM:INIT
            4 TSF:WUR:MS=0
            11 TSM:INIT:TSP OK
            13 TSF:SID:OK,ID=2
            14 TSM:FPAR
            51 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            775 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            780 TSF:MSG:FPAR OK,ID=0,D=1
            2058 TSM:FPAR:OK
            2059 TSM:ID
            2060 TSM:ID:OK
            2062 TSM:UPL
            2065 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            2074 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            2079 TSF:MSG:PONG RECV,HP=1
            2081 TSM:UPL:OK
            2083 TSM:READY:ID=2,PAR=0,DIS=1
            2087 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            2095 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            2102 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
            2110 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
            2123 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
            2132 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2139 MCO:REG:REQ
            2146 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
            2152 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
            2157 MCO:PIM:NODE REG=1
            2160 MCO:BGN:INIT OK,TSP=1
            2168 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:413
            2174 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
            2180 MCO:SLP:TPD
            2182 MCO:SLP:WUP=-1
            2189 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:412
            2195 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
            2200 MCO:SLP:TPD
            2202 MCO:SLP:WUP=-1
            2209 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:412
            2214 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
            2220 MCO:SLP:TPD
              Check yourself in the log parser page https://www.mysensors.org/build/parser
              Your node is connected to gateway and reporting the values (look at the 413 - 412 -412 that were sent).
              Also please use the Code TAG when posting code or logs as it makes it more readable.
              • k5austriaK
                k5austriaK
                k5austria
                #27
                Ok ! Sorry !
                After several reset from raspberry is the sensor visible by Domoticz, but is not in device list.
                1_1493548837217_2017-04-30 12_23_44-Domoticz.png 0_1493548837214_2017-04-30 12_22_50-Domoticz.png
