  3. Powering LED strip lighting
6 Posts 3 Posters 2.6k Views 2 Watching
  • N
    N
    NotYetRated
    wrote on last edited by NotYetRated
    Looking to run a few sections of LED strip accent lighting around my bar and home theater. I want to tie a few strands together, hide wiring, and power them from a hidden outlet as a permanent install.
    What do you guys suggest in terms of wiring to connect between the strips? Roughly 20 feet of routing between one strip and 8 feet the other.
    I plan to tie it to a MySensors relay and turn on/off via my Vera. Probably set to a scene, and tied to zwave led dimmer/switch.
    These are the strips. http://www.amazon.com/gp/product/B00L74ROFC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    • daulagariD
      daulagariD
      daulagari
      How much current does these strips draw?
      I read it is 12 Volts but what counts for wiring is the current...
      • N
        N
        NotYetRated
        I have read a couple of different draws for these strips, and current(ly) do not know for sure.
        I have seen posted from 0.08 watts per LED, to 0.2 watts per LED.
        eBay kits are sold with 5m strands, 300 LEDs, with 5A/12V power supplies though, making the draw 60W, or 0.2w/LED...
        • daulagariD
          daulagariD
          daulagari
          0.2 Watt per LED seems reasonable, so 60 Watt or 5A @ 12 V per strip.
          If you want to have not too much voltage drop over the 20/8 feet you should use a cable that has low resistance, only 1 Ohm gives 5 Volts voltage drop...
          Maybe better to run 110/230 Volts to the strip and have the power supply there.
          N 1 Reply Last reply
          • daulagariD daulagari
            N
            N
            NotYetRated
            @daulagari Indeed it appears they may be optimal to keeping the lights equal(or similar) brightness. I was hoping to use just one dc converter, perhaps Ill just have to bite it and install a few, all MySensors connected of course.
            Thanks.
            • tbowmoT
              tbowmoT
              tbowmo
              for a standard 220V appliance cord with 0.75mm2 (square mm) you have a resistance of 1 ohm for each 43m
              for 20 feet (6.1 meters), the resistance is 0.142 ohm, with 5A load, you have a drop of 0.7V..
              for 8 feet (2.5m) the resistance is 0.06ohm, again with 5A load, you have a drop of 0.3V
              So only 0.4V in difference...
              / Thomas
