  3. Help with sketch...
Help with sketch...
6 Posts 3 Posters 2.1k Views 3 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    This is what I want to do:
    when motionsensor is triggered run distance-sensors for 10 seconds and then sleep.
    I think I have most of the parts working but I am struggeling with how to combine all the sketches. I have tried several times and think I managed to combine the first two at one time. But then everything just stoped working after trying to add the timer part.
    This is the distance-sensor-sketch which kind of works most of the time (And is just supposed to tell if I someone enters or leaves a room :
    #include <NewPing.h>
    #include <Bounce2.h>
    #define SONAR_NUM     2 // Number of sensors.
    #define MAX_DISTANCE 200 // Maximum distance (in cm) to ping.
    #define PING_INTERVAL 40 // Milliseconds between sensor pings (29ms is about the min to avoid cross-sensor echo).
    int ledPin = 4;
    //Bounce debouncer = Bounce();
    //int oldValue=-1;
    unsigned long pingTimer[SONAR_NUM]; // Holds the times when the next ping should happen for each sensor.
    unsigned int cm[SONAR_NUM];         // Where the ping distances are stored.
    uint8_t currentSensor = 0;          // Keeps track of which sensor is active.
    int dirA = 0;
    int dirB = 0;
    int val = 0;
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    int doorDistance = 65;
    boolean bigChange_0;  //SensorA
    boolean bigChange_1;  //SensorB
    NewPing sonar[SONAR_NUM] = {     // Sensor object array.
      NewPing(8, 7, MAX_DISTANCE), // Each sensor's trigger pin, echo pin, and max distance to ping.
      NewPing(6, 5, MAX_DISTANCE)
      Serial.begin(115200);
      pingTimer[0] = millis() + 75;           // First ping starts at 75ms, gives time for the Arduino to chill before starting.
      for (uint8_t i = 1; i < SONAR_NUM; i++) // Set the starting time for each sensor.
        pingTimer[i] = pingTimer[i - 1] + PING_INTERVAL;
         // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
       pinMode(ledPin, OUTPUT);  // declare LED as output
      for (uint8_t i = 0; i < SONAR_NUM; i++) { // Loop through all the sensors.
        if (millis() >= pingTimer[i]) {         // Is it this sensor's time to ping?
          pingTimer[i] += PING_INTERVAL * SONAR_NUM;  // Set next time this sensor will be pinged.
          if (i == 0 && currentSensor == SONAR_NUM - 1) oneSensorCycle(); // Sensor ping cycle complete, do something with the results.
          sonar[currentSensor].timer_stop();          // Make sure previous timer is canceled before starting a new ping (insurance).
          currentSensor = i;                          // Sensor being accessed.
          cm[currentSensor] = 0;                      // Make distance zero in case there's no ping echo for this sensor.
          sonar[currentSensor].ping_timer(echoCheck); // Do the ping (processing continues, interrupt will call echoCheck to look for echo).
      // Other code that *DOESN'T* analyze ping results can go here.
      val = digitalRead(BUTTON_PIN);  // read input value
      if (val == HIGH) {         // check if the input is HIGH (button released)
        digitalWrite(ledPin, LOW);  // turn LED OFF
      } else {
        digitalWrite(ledPin, HIGH);  // turn LED ON
        int measure = (int)cm[0];
        if(measure != doorDistance && measure != 0){
           Serial.print(measure);
           Serial.println();
           doorDistance = measure;
         // Send in the new value
        // send(msg.set(value==HIGH ? 1 : 0));
    void echoCheck() { // If ping received, set the sensor distance to array.
      if (sonar[currentSensor].check_timer())
        cm[currentSensor] = sonar[currentSensor].ping_result / US_ROUNDTRIP_CM;
    void oneSensorCycle() { // Sensor ping cycle complete, do something with the results.
      bigChange_0 = ((doorDistance-(int)cm[0]) > 10)?true:false;
      bigChange_1 = ((doorDistance-(int)cm[1]) > 10)?true:false;
      if(bigChange_0 && bigChange_1){
          if(dirA > dirB){
              Serial.print("Entering Room");
              Serial.println();
              dirA = 0;
              dirB = 0;
            else if(dirA < dirB){
              Serial.print("Leaving Room");
              Serial.println();
              dirA = 0;
              dirB = 0;
            else{
              dirA = 0;
              dirB = 0;
      else if(bigChange_0){
          dirA=1;
      else if(bigChange_1){
         dirB=1;
      else {
        dirA = 0;
        dirB = 0;
    This is the standard motion-sensor-sketch:
    // Enable debug prints
    // #define MY_DEBUG
    // Initialize motion message
        sendSketchInfo("Motion Sensor", "1.0");
        present(CHILD_ID, S_MOTION);
        // Read digital motion value
        bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        Serial.println(tripped);
        send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
        sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    And this is the blink_without_delay-sketch from the arduino site which uses a timer:
    // Generally, you should use "unsigned long" for variables that hold time
    // The value will quickly become too large for an int to store
    unsigned long previousMillis = 0;        // will store last time LED was updated
    // constants won't change :
    const long interval = 10000;           // interval at which to blink (milliseconds)
      // set the digital pin as output:
      // here is where you'd put code that needs to be running all the time.
      // check to see if it's time to blink the LED; that is, if the
      // difference between the current time and last time you blinked
      // the LED is bigger than the interval at which you want to
      // blink the LED.
      if (currentMillis - previousMillis >= interval) {
        // save the last time you blinked the LED
        previousMillis = currentMillis;
        // if the LED is off turn it on and vice-versa:
        if (ledState == LOW) {
          ledState = HIGH;
        } else {
          ledState = LOW;
        // set the LED with the ledState of the variable:
        digitalWrite(ledPin, ledState);
    • BartEB
      BartEB
      BartE
      wrote on last edited by BartE
      @Cliff-Karlsson
      You might try this piece of code
      It only contains the start and stop mechanism for the distance sensor based on the PIR status. The distance measurement code you need to add youself
      // #define MY_DEBUG
      // Instantiate a Bounce object
      unsigned long distanceTimer = 0;
      #define DISTANCEMEASURETIME (10 * 1000)
          // After setting up the button, setup the Bounce instance :
          debouncer.attach(DIGITAL_INPUT_SENSOR);
          debouncer.interval(5); // interval in ms
          // Check if the PIR sensor has been changed
          if (debouncer.update()) {
             bool tripped = (debouncer.read() == HIGH);
             if (tripped) {
                distanceTimer = millis() + DISTANCEMEASURETIME;
          // Check if we need to measure distance
          if (distanceTimer > 0) {
             if (millis() > distanceTimer) {
                 // No times up stop reset the timer
                 distanceTimer = 0;
             }  else {
                  // add the distance measurement code here
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        @BartE Thanks for the help but I can't get it to work. I Only get alot of radio errors:
        3 TSM:INIT
        4 TSF:WUR:MS=0
        11 !TSM:INIT:TSP FAIL
        12 TSM:FAIL:CNT=1
        14 TSM:FAIL:PDT
        I also tried commenting out all mysensors stuff, but I got no reactions at al from leds or serial monitor.
        I am using a UNO with a separate 12v power supply attached so it can't be power related right?
        int ledPin = 4;
        int dirA = 0;
        int dirB = 0;
        int val = 0;
        #define BUTTON_PIN  1  // Arduino Digital I/O pin for button/reed switch
             // Setup the button
             //  send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
               if (tripped) {
                   distanceTimer = 0;
               }  else {
          } else {
               Serial.println();
              if(dirA > dirB){
                  Serial.println();
                  dirA = 0;
                  dirB = 0;
                  Serial.println();
                  dirA = 0;
                  dirB = 0;
                else{
                  dirA = 0;
                  dirB = 0;
              dirA=1;
             dirB=1;
          else {
            dirA = 0;
            dirB = 0;
        BartEB 1 Reply Last reply
          3 TSM:INIT
          4 TSF:WUR:MS=0
          12 TSM:FAIL:CNT=1
          14 TSM:FAIL:PDT
          int ledPin = 4;
          int dirA = 0;
          int dirB = 0;
          int val = 0;
               // Setup the button
                 if (tripped) {
                     distanceTimer = 0;
                 }  else {
            } else {
                 Serial.println();
                if(dirA > dirB){
                    Serial.println();
                    dirA = 0;
                    dirB = 0;
                    Serial.println();
                    dirA = 0;
                    dirB = 0;
                  else{
                    dirA = 0;
                    dirB = 0;
                dirA=1;
               dirB=1;
            else {
              dirA = 0;
              dirB = 0;
          BartEB
          BartEB
          BartE
          @Cliff-Karlsson these radio errors normally are the result of no connection with the MySensors gateway.
          Please make sure you also remove the #include mysensors.h line when you want to comment out all MySensors stuff
          When you connect a Arduino board via USB to your PC no additional power supply is required, so to make sure the power is not causing the problems just disconnect te power.
          • core_cC
            core_cC
            core_c
            Right BartE..
            On this forum i read about someone connecting both USB and a power supply at the same time, and blew up his Arduino.
            I do not know for sure what would happen, (never did that), but i'm not willing to test it out..
            • core_cC
              core_cC
              core_c
              I did not know about the newPing.h library. (i can not find it when searching for it in the Arduino IDE).. so i googled it.
              The example (for 15 sensors) confuses me :)
              Can't you just do something like this?
              boolean bigChange[SONAR_NUM];
                 pingTimer[1] = pingTimer[0] + PING_INTERVAL;
                // your rest code here..
                           pingTimer[i] += PING_INTERVAL;
                           cm[i] = sonar.ping_cm();
                           bigChange[i] = ((doorDistance-(int)cm[i]) > 10)?true:false;
                       oneSensorCycle;
              And adjust oneSensorCycle() to use bigChange[0] & bigChange[1] instead of bigChange_0 & bigChange_1
