  3. Repeater node is not working
2 Posts 2 Posters 1.5k Views 2 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    This is a standard repeater sketch:
     * Version 1.0 - Henrik Ekblad
     * Example sketch showing how to create a node thay repeates messages
     * from nodes far from gateway back to gateway.
     * It is important that nodes that has enabled repeater mode calls
     * process() frequently. Repeaters should never sleep.
    #define MY_DEBUG_VERBOSE_SIGNING
    //#define MY_SIGNING_ATSHA204
    //#define MY_SIGNING_REQUEST_SIGNATURES
    //#define MY_SIGNING_ATSHA204_PIN 17
    #define MY_NODE_ID 18
    // Enabled repeater feature for this node
    #define MY_REPEATER_FEATURE
    Serial.println("Starting Repeater Node - MySensors 2.1.1");
    	//Send the sensor node sketch version information to the gateway
    	sendSketchInfo("Repeater Node", "1.0");
    the node never receives or forwards any packates
    MCO:BGN:INIT REPEATER,CP=RNNRS--,VER=2.1.1
    TSF:LRT:OK
    TSM:INIT
    TSF:WUR:MS=0
    TSM:INIT:TSP OK
    TSM:INIT:STATID=18
    TSF:SID:OK,ID=18
    TSM:FPAR
    TSF:MSG:SEND,18-18-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    TSF:MSG:READ,0-0-18,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSF:MSG:FPAR OK,ID=0,D=1
    TSM:FPAR:OK
    TSM:ID
    TSM:ID:OK
    TSM:UPL
    TSF:MSG:SEND,18-18-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    TSF:MSG:READ,0-0-18,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSF:MSG:PONG RECV,HP=1
    TSM:UPL:OK
    TSM:READY:ID=18,PAR=0,DIS=1
    TSF:MSG:SEND,18-18-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    Waiting for GW to send signing preferences...
    TSF:MSG:READ,0-0-18,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    Received signing presentation, but signing is not supported (message ignored)
    TSF:MSG:SEND,18-18-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    TSF:MSG:SEND,18-18-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    TSF:MSG:READ,0-0-18,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    TSF:MSG:SEND,18-18-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Repeater Node
    TSF:MSG:SEND,18-18-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    MCO:REG:REQ
    TSF:MSG:SEND,18-18-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    TSF:MSG:READ,0-0-18,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    MCO:PIM:NODE REG=1
    MCO:BGN:STP
    MCO:BGN:INIT OK,TSP=1
    Am I missing something here?
      It looks like it is rebooting for no reason, try to use latest 2.2.0 library
