  3. Please share your raingauge sketch that works with Domoticz
8 Posts 4 Posters 3.2k Views 2 Watching
  • E
    E
    edweather
    Can someone please share his Raingauge sketch that works with domoticz and is running from an external powersupply 3v or 5v. Trying to get the 'original' to work but it does not work well. It keeps sending rainfall every hour even if it does not rain :umbrella:
    I tried the example from @sundberg84 and @TheoL but they have added extra sensor or using batteries.
    I am using the latest Mysensors 2.1.1 using esp8266 gateway with domoticz 3.7416.
    Thanks Edwin.
    My last try of the raingauge sketch. This one keeps asking the V_VAR1 value from the gateway.
    // Arduino Tipping Bucket Rain Gauge
    #define MY_DEBUG // Enable MySensors debug prints to serial monitor
    // Running this in Domoticz stable version 2.5 will not work - upgrade to beta.
    #define DIGITAL_INPUT_SENSOR 3 // The reed switch you attached. (Only 2 and 3 generates interrupt!)
    #define CHILD_ID 1 // Id of the sensor child
    #define BATT_CHILD 2
    #define NODE_ID AUTO // or AUTO to let controller assign
    #define SKETCH_NAME "Rain Gauge" // Change to a fancy name you like
    #define SKETCH_VERSION "10" // Your version
    unsigned long SLEEP_TIME = 180*60000; // Sleep time (in milliseconds).
    //unsigned long SLEEP_TIME = 20000; // use this instead for debug
    float hwRainVolume = 0; // Current rainvolume calculated in hardware.
    int hwPulseCounter = 0; // Pulsecount recieved from GW
    float fullCounter = 0; // Counts when to send counter
    float bucketSize = 0.3; // Bucketsize mm, needs to be 1, 0.5, 0.25, 0.2 or 0.1
    boolean pcReceived = false; // If we have recieved the pulscount from GW or not
    boolean reedState; // Current state the reedswitch is in
    boolean oldReedState; // Old state (last state) of the reedswitch
    unsigned long lastSend =0; // Time we last tried to fetch counter.
    MyMessage volumeMsg(CHILD_ID,V_RAIN);
    MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
      #ifndef MY_DEBUG
      SERIAL_START(115200);  //Start serial if MySensors debugging isn't enabled
    pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP); // sets the reed sensor digital pin as input
    reedState = digitalRead(DIGITAL_INPUT_SENSOR); // Read what state the reedswitch is in
    oldReedState = reedState; // Set startup position for reedswitch
    void presentation()  {
    delay(500); // Allow time for radio if power used as reset
    // Register this device as Rain sensor (will not show in Domoticz until first value arrives)
    present(CHILD_ID, S_RAIN);
    unsigned long currentTime = millis();
    //See if we have the counter/pulse from Domoticz - and ask for it if we dont.
    if (!pcReceived && (currentTime - lastSend > 5000)) {
    request(CHILD_ID, V_VAR1);
    lastSend=currentTime;
    return;
    if (!pcReceived) {
    return;
    //Read if the bucket tipped over
    boolean tipped = oldReedState != reedState;
    //BUCKET TIPS!
    if (tipped==true) {
    hwRainVolume = hwRainVolume + bucketSize;
    send(volumeMsg.set((float)hwRainVolume,1));
    wait(1000);
    fullCounter = fullCounter + bucketSize;
    //Count so we send the counter for every 1mm
    if(fullCounter >= 1){
    hwPulseCounter++;
    send(lastCounterMsg.set(hwPulseCounter));
    wait(1000);
    fullCounter = 0;
    sleep(INTERRUPT, CHANGE, SLEEP_TIME);
    //The interupt can be CHANGE or FALLING depending on how you wired the hardware.
    //Read if we have a incoming message.
    if (message.type==V_VAR1) {
    hwPulseCounter = message.getULong();
    hwRainVolume = hwPulseCounter;
    pcReceived = true;
    //Sends 1 per hour as a heartbeat.
    F 1 Reply Last reply
    • E edweather
      Thanks Edwin.
        #ifndef MY_DEBUG
      return;
      if (!pcReceived) {
      return;
      //BUCKET TIPS!
      if (tipped==true) {
      wait(1000);
      hwPulseCounter++;
      wait(1000);
      fullCounter = 0;
      pcReceived = true;
      F
      F
      flopp
      @edweather
      Does the node get VAR1 from DZ?
      Does it send new value every hour or same value?
      E 1 Reply Last reply
      • F flopp
        @edweather
        E
        E
        edweather
        @flopp thanks for the quick reply.
        The debug output gives:
        28004 TSF:MSG:SEND,33-33-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:	Sent Message
        Sender: 33
        Last Node: 33
        Next Node: 0
        Destination: 0
        Sensor Id: 1
        Command: REQ
        Message Type:V_VAR1
        Payload Type: P_STRING
        Payload Length: 0
        Signing: 0
        Failed uplink counter: 0
        Status: OK (OK=success, NACK=no radio ACK received)
        Payload:
        28499 TSF:MSG:READ,0-0-33,s=1,c=2,t=24,pt=0,l=0,sg=0:	Received Message
        Sender: 0
        Last Node: 0
        Destination: 33
        Sensor Id: 1
        Command: REQ
        Message Type: V_VAR1
        Payload Length: 0
        Signing: 0
        Payload:
        I tried it with your sketch but this gives me a pulse count every time the sensor starts up.
        Normaly you do this only once but I think it will do this every hour when synching the time.
        I uploaded your sketch 5 minutes ago so I can't confirm this now.
        Getting pulse count
        Received last pulse count from gw: 1
        Getting Time
        Time received...
        16:14
        Tipped 2 times.
        Rain fall is 0.6 mm.
        Getting pulse count
        Received last pulse count from gw: 2
        Getting Time
        Time received...
        16:14
        Tipped 3 times.
        Rain fall is 0.9 mm.
        Getting pulse count
        Received last pulse count from gw: 3
        Getting Time
        Time received...
        16:16
        Tipped 4 times.
        Rain fall is 1.2 mm.
        Getting pulse count
        Received last pulse count from gw: 4
        Getting Time
        Time received...
        16:17
        Tipped 5 times.
        Rain fall is 1.5 mm.
        Getting pulse count
        Received last pulse count from gw: 5
        Getting Time
        Time received...
        16:17
        Tipped 6 times.
        Rain fall is 1.8 mm.
        The sketch with extra sensors removed:
          Include libraries used by the sketch
        #include <Time.h>
        #include <TimeLib.h>
        #include <Wire.h>
        #define BUCKET_PIN 3                  // The Arduino pin to which the bucket is attached. We need an interrupt pin (2 or 3 on the Uno and the Pro Mini)
        #define SKETCH_INFO "Rain Gauge" // The name of the sketch as presented to the gateway
        #define SKETCH_VERSION "1.0"          // The version of the sketch as presented to the gateway
        #define CHILD_ID_RAIN_LOG 4           // The child id of the rain gauge
        #define MS_WAIT 100                   // short delay used to give the NRF24L01+ antenna some time to recover from the last data sending
        #define bucketSize 0.3                // I've used a MI-SOL Rain Guage which has a bucket size of 0.3 mm
        MyMessage msgRain( CHILD_ID_RAIN_LOG, V_RAIN );
        MyMessage lastCounterMsg( CHILD_ID_RAIN_LOG, V_VAR1 );
        unsigned long hwPulseCounter = 0; // Pulsecount recieved from GW
        unsigned long lastTipTime = millis(); // TS of when the bucket tip has been detected for the last time
        volatile unsigned long wasTippedCounter; // Queue for storing the tipped counter as been set by the interrupt handler.
        byte lastHour;                    // Stores the hour used for checking if time needs to be synchronized
          sendSketchInfo( SKETCH_INFO, SKETCH_VERSION );
          wait( MS_WAIT );
          present( CHILD_ID_RAIN_LOG, S_RAIN, "Rain fall" );
          wait( MS_WAIT );
          unsigned long functionTimeout = millis();
          while ( pcReceived == false && millis() - functionTimeout < 30000UL ) {
            request( CHILD_ID_RAIN_LOG, V_VAR1);
            Serial.println(F("Getting pulse count"));
            Serial.println(F("."));
            wait( 1000 );
          attachInterrupt( digitalPinToInterrupt( BUCKET_PIN ), sensorTipped, CHANGE ); //FALLING );  // depending on location of the hall effect sensor may need CHANGE
          Serial.begin( 115200 );
          pinMode( BUCKET_PIN, INPUT_PULLUP );
          while ( timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL ) {
            requestTime();
            Serial.println(F("Getting Time"));
            wait( 1000 );
          lastHour = hour();
          Sends the value of the rain gauge to the Gateway.
        void sendRainVolumeData() {
          float hwRainVolume = hwPulseCounter * bucketSize;
          Serial.print( "Tipped " );
          Serial.print( hwPulseCounter );
          Serial.println( " times." );
          Serial.print( "Rain fall is " );
          Serial.print( hwRainVolume, 1 );
          Serial.println( " mm." );
          send( msgRain.set( (float)hwRainVolume, 1 ) );
          wait( MS_WAIT );
          send( lastCounterMsg.set( hwPulseCounter ) );
          wait( MS_WAIT );
          if ( wasTippedCounter != hwPulseCounter ) {
            hwPulseCounter = wasTippedCounter;
            sendRainVolumeData();
          byte currentHour = hour();
          if (currentHour != lastHour) {
            Serial.println( "Resyncing hour" );
            requestTime(); // sync the time every hour
            wait( MS_WAIT );
            lastHour = currentHour;
            sendRainVolumeData(); // Send heart beat
        void sensorTipped() {
          unsigned long thisTipTime = millis();
          if (thisTipTime - lastTipTime > 100UL) {
            wasTippedCounter++;
          lastTipTime = thisTipTime;
        void receiveTime(unsigned long time) {
          Serial.println( F("Time received..."));
          setTime(time);
          char theTime[6];
          sprintf(theTime, "%d:%2d", hour(), minute());
          Serial.println(theTime);
          if ( message.sensor == CHILD_ID_RAIN_LOG && message.type == V_VAR1) { // We only expect pulse count values from the gateway
            wasTippedCounter = hwPulseCounter;
            pcReceived = true;
            Serial.print("Received last pulse count from gw: ");
            Serial.println(hwPulseCounter);
        • E edweather
          Sender: 33
          Last Node: 33
          Next Node: 0
          Destination: 0
          Sensor Id: 1
          Command: REQ
          Message Type:V_VAR1
          Payload Length: 0
          Signing: 0
          Payload:
          Sender: 0
          Last Node: 0
          Destination: 33
          Sensor Id: 1
          Command: REQ
          Payload Length: 0
          Signing: 0
          Payload:
          Getting pulse count
          Getting Time
          Time received...
          16:14
          Tipped 2 times.
          Getting pulse count
          Getting Time
          Time received...
          16:14
          Tipped 3 times.
          Getting pulse count
          Getting Time
          Time received...
          16:16
          Tipped 4 times.
          Getting pulse count
          Getting Time
          Time received...
          16:17
          Tipped 5 times.
          Getting pulse count
          Getting Time
          Time received...
          16:17
          Tipped 6 times.
          #include <Time.h>
          #include <Wire.h>
            wait( MS_WAIT );
            wait( MS_WAIT );
              wait( 1000 );
              requestTime();
              wait( 1000 );
            lastHour = hour();
            wait( MS_WAIT );
            wait( MS_WAIT );
              wait( MS_WAIT );
              wasTippedCounter++;
            setTime(time);
            char theTime[6];
              pcReceived = true;
          E
          E
          edweather
          After one night with not a drop of rain ? False tips?
          0_1495357517670_upload-ae462a54-28c5-445f-885d-8b13d250979c
          • E edweather
            @edweather this thread discusses some recent false tips. Maybe you are experiencing something similar?
              E
              E
              edweather
              @mfalkvidd thanks, I will look at that thread.
              • sundberg84S
                Did you make sure the pin isnt floating? A pulldown resistor 10k to gnd can be good.
                • sundberg84S sundberg84
                  E
                  E
                  edweather
                  @sundberg84 Thanks, tried but I keep getting false rain tips.
