  3. 💬 NModule Temperature, Humidity, Light, Door sensor shield
contest2017doortemperaturei2cmysensorslightnmodule
41 Posts 4 Posters 15.6k Views 3 Watching
  • Nca78N
    Nca78N
    I'm thinking about upgrading this board to include pinout for LIS3DH breakout board, like this one :
    https://www.aliexpress.com/item/LIS3DH-Three-Converters-Motion-Accelerometer-Triaxial-Acceleration-Temperature-Sensor-Module-Development-Board-Replace-ADXL345/32840326778.html
    and ditch the ADXL shield as it's not a good solution, it has either the ADXL345 which uses too much power, or the ADXL362 which is ultra low power but lacks advanced functionality like tap/double tap detection.
    I would like to have feedback of users on this (do it sound useful ?), and also know if anyone uses the SMD footprints on the board, for leds and for reserve capacitors, as it could be a cleaner board without those footprints.
    I would make the following changes :
    • put footprint for LIS3DH accelerometer along the "NModule connector" as it has too many pins to put elsewhere
    • keep only one I2C footprint on the side, for "GY-49" MAX44009 light sensor breakout board: https://www.aliexpress.com/item/GY-49-MAX44009-Ambient-Light-Sensor-Module-for-Arduino-with-4P-Pin-Header-Module/32828654450.html
    • temperature/humidity would be via the existing "SMD" footprint, it's not through hole but very easy to solder as it's 2.54mm pad spacing
    • remove SMD footprints for LED, add footprint for through hole reserve capacitor, keep SMD footprints for reserve capacitors only if I have space for them
    • shield would be a bit extended to go over the 2 M2 holes in the "power" part of the NModule, so it could be fitted with spacers and nylon screws and have stable/reliable mechanical connection between NModule and Shield. Basically this would be the footprint of the shield : 0_1527422032044_c8e52cd0-47fe-4a5e-b6a3-554e216603cc-image.png
    So in the end it would make one shield to have Temperature/Humidity/Light/Acceleration or Temperature/Humidity/Light/Door.
