  3. nRF5 action!
nRF5 action!
  • NeverDieN
    NeverDieN
    #241
    I have some of these 1.27mm 10 pin box connectors on order from Aliexpress (above), but I'm ordering a few more from Digikey so I can get them faster:
    https://www.digikey.com/product-detail/en/3220-10-0100-00/1175-1627-ND/3883661
    It should make wire-ups for chip programming/debugging a lot easier.
    Of course, I'd most prefer to do it all wirelessly.... Has anyone reading this had any success with that, or know of anyone who has without resorting to espruino?
    • NeverDieN
      NeverDieN
      #242
      If we upload to an nRF52840 the current mysensors demo code examples for an nRF52832, will it work? Anyone tried it?
      d00616D 1 Reply Last reply
      • NeverDieN NeverDie
        d00616D
        d00616D
        d00616
        The 52840 is currently unsupported:
        https://github.com/sandeepmistry/arduino-nRF5/issues/70
        You can try the source code from: https://github.com/lpercifield/arduino-nRF5/tree/nrf52840
        • NeverDieN
          NeverDieN
          #244
          In that case I think I may order another nRF52832 DK, because I want to establish very soon some kind of reasonable baseline for the kind of range I should expect. The adafruit nRF52832 Feather seems to have awful range, and I'm not sure if that's what I should expect generally, or whether it's just that particular design/device. If it turns out to be true for nRF52832 generally, then I may just shelve things and wait for the nRF52840 to become supported and then try again with that.
          TerrenceT 1 Reply Last reply
            TerrenceT
            TerrenceT
            Terrence
            • NeverDieN
              NeverDieN
              #246
              I found I could improve reception from the Adafruit nRF52832 Feather by using an PA+LNA boosted nRF24L01. So, although this feels a bit like a step backward, it's at least workable and fairly cheap. Also, it need only go onto a gateway, thereby allowing other motes to potentially use smaller nRF5 modules. :)
              NeverDieN 1 Reply Last reply
                NeverDieN
                NeverDieN
                I have this on order to serve the purpose:
                https://www.aliexpress.com/item/E01-ML01DP5-Ebyte-2-4GHz-20dBm-2100m-nRF24L01-SPI-Wireless-transceiver-module/32638720689.html
                though yesterday I tested the idea using one of these:
                https://www.aliexpress.com/item/Smart-Electronics-1Set-2-4G-1100-Meters-Long-Distance-NRF24L01-PA-LNA-Wireless-Transceiver-Communication-Modules/32707423150.html?spm=2114.search0204.3.105.TGUiz5&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10130_10084_10083_10080_10082_10081_10110_10178_10137_10111_10060_10112_10113_10155_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_5360020_10189_10052_10053_10142_10107_10050_10051-10111,searchweb201603_5,ppcSwitch_4_ppcChannel&btsid=a7086a85-885c-430a-a6db-e8f80171efc1&algo_expid=959e3532-756a-47c5-8de7-461b096da1d9-10&algo_pvid=959e3532-756a-47c5-8de7-461b096da1d9
                • NeverDieN
                  NeverDieN
                  Here's a demo of the high speed feature of nRF52 on a Samsung S8 phone:
                  https://devzone.nordicsemi.com/blogs/1106/bluetooth-5-2mbps-demo-with-nrf52-series-and-samsu/
                  It occurs to me now how much more interesting this will get when phones later have the nRF52840 in them and can do long range bluetooth communication.
                    TerrenceT
                    TerrenceT
                    Terrence
                    @NeverDie >>1100-Meters Long-Distance
                    That would be impressive.
                    • NeverDieN
                      NeverDieN
                      https://www.openhardware.io/view/436
                        Maybe @sundberg84 could take inspiration for his easy pcb 😀
                          Mike_Lemo
                          how'd you program this blank nrf52832 chip with an SWD programmer like the ST link v2 what programming environment to use and so on?
                          NeverDieN mtiutiuM 2 Replies Last reply
                          • M Mike_Lemo
                            NeverDieN
                            NeverDieN
                            #253
                            @Mike_Lemo
                            I had no luck using the ST link v2 from Windows. You might be luckier, or you might try using it from Linux. However, as discussed above, I have had success using the nRF52832 DK and the Arduino IDE from Windows. That's how I intend to program the nRF52832 module using the breakout board I posted above.
                            • M Mike_Lemo
                              mtiutiuM
                              mtiutiuM
                              mtiutiu
                              wrote on last edited by mtiutiu
                              #254
                              @Mike_Lemo
                              I used the Arduino IDE with sandeepmistry arduino core installed and I managed to program a nrf51822 module with success. I used a cheap st-link programmer from AliExpress. I don't know about nrf52832 as I don't have one. But I don't see why it wouldn't work. You need 4 wires: Vdd(3.3V), GND, SWD and SWCLK.
                              From Arduino IDE you need to select st-link as programmer.
                              It uses openocd under the hood to do the work and it worked both on Windows and Linux. On Linux you might need to set udev rules for allowing regular user to use the st-link.
                              NeverDieN M 2 Replies Last reply
                              • mtiutiuM mtiutiu
                                @Mike_Lemo
                                NeverDieN
                                NeverDieN
                                @mtiutiu said in nRF5 Bluetooth action!:
                                Did you power the nrf51822 through the st-link programmer, or did you power it independently?
                                mtiutiuM 1 Reply Last reply
                                • mtiutiuM mtiutiu
                                  @Mike_Lemo
                                  Mike_Lemo
                                  @mtiutiu And when you want to program an independent chip with the ST link V2 do you just chose "generic nrf52"?
                                  Also how is it possible to connect between through two NRF52s in slave master config?
                                  Is it possible to take advantage of the NFC functionality with that programming environment?
                                  • NeverDieN
                                    NeverDieN
                                    Good news! I received my second nRF52832 DK today, so now I can have a DK on both ends of a link. Bottom line: I ran some quick tests, and it has much better range than the Adafruit nRF52832 Feather.
                                    Whew! What a relief. The Adafruit had very disappointing range. In contrast, and as expected, the two DK's have better range than regular nRF24L01+ radios.
                                      Mike_Lemo
                                      @NeverDie How did you manage to send and receive data between these two units? may you share the code with us?
                                      • M Mike_Lemo
                                        NeverDieN
                                        NeverDieN
                                        #259
                                        @Mike_Lemo
                                        I'm simply using the GatewaySerial and the LightSensor sketches from the mysensors developers release. Just make the following change in each sketch:
                                        //#define MY_RADIO_NRF24
                                        #define MY_RADIO_NRF5_ESB
                                          mtiutiuM
                                          mtiutiuM
                                          mtiutiu
                                          @NeverDie
                                          Powered from st-link programmer.
