  3. nRF5 action!
nRF5 action!
  • T
    Toyman
    Given new Arduino Primo contains a buzzer connected to nrf52, we might expect tone() function to be compatible with nrf52 very soon
    https://www.arduino.cc/en/uploads/Main/ARDUINO_PRIMO-V022_SCH.pdf
    • NeverDieN NeverDie
      Quantization error on the hwCpuVoltage() function appears to about 14 millivolts, which is a nice little improvement over the atmega328p. Measurement accuracy appears to be well within those bounds.
      Next step is to measure voltage on an analog pin using an AnalogRead. Not sure if the reference voltage is Vcc (as it typically is with the atmega328p) or something else for those measurements.
      NeverDieN
      NeverDieN
      #502
      Strangely, if I do, say, analogRead(A4) on the nRF52832, all I get back is a 10-bit number, not a 12-bit number. i.e. the number never exceeds 1023. That can't be right. Should I be using a different function call to get the full 12 bits on the nRF52832?
        @NeverDie looks like you need to call analogReadResolution first https://github.com/sandeepmistry/arduino-nRF5/blob/425e719af8d85b543def01e49a6ef4048525dc59/cores/nRF5/wiring_analog.h#L74
        NeverDieN 1 Reply Last reply
          NeverDieN
          NeverDieN
          #504
          @mfalkvidd said in nRF5 Bluetooth action!:
          Thanks! That did the trick. Calling analogReadResolution(12) once in Setup() routine, I now get back a 12-bit number (i.e. up to 4095) thereafter when I do an analogRead(...). :)
          • NeverDieN
            NeverDieN
            So, just did the experiment, and here are the results. Supplying 3.3v to the Ebyte Module, a voltage of 3.0 volts on A4 yields an analogRead(A4) of 4095. Less voltage on A4 yields a lower number.
            So, generalizing, I suspect that the reference voltage for analogRead() is Vcc-0.3.
            So, you either know Vcc, because of a voltage regulator or something, or else you must call hwCpuVoltage() to get what it is. Then, subtract 0.3v from that, and that's the reference voltage which corresponds to an analogRead() return value of 4095.
            d00616D 1 Reply Last reply
            • NeverDieN
              NeverDieN
              #506
              I just did a quick and dirty measurement on the current consumption of the nRF52832 Ebyte module during sleep, and it measured 10 milliamps. I measured it using a uCurrent Gold. That's very high current for most battery powered applications. Can someone else here please measure it also and either confirm or refute?
              I invoked sleep with this from the mocksensors sketch:
              	wait(SLEEP_TIME); //sleep a bit
              Perhaps there's a way to invoke a deeper sleep than that where less current is drawn?
              rmtuckerR 1 Reply Last reply
                rmtuckerR
                rmtuckerR
                rmtucker
                wrote on last edited by rmtucker
                #507
                @NeverDie
                Try
                sleep(60000); // Sleeps for a minute in deep sleep
                • rmtuckerR rmtucker
                  @NeverDie
                  Try
                  NeverDieN
                  NeverDieN
                  #508
                  @rmtucker said in nRF5 Bluetooth action!:
                  Thanks! That's a big improvement. I'm now reading 51uA. I did the measurements on the Ebyte nRF52832 module, powering it at 3.3v.
                  However, to be frank, that's still rather high compared to, say, an atmega328p with a RFM69 radio, which can have a combined sleep current of less than 1uA.
                  Is there anything more that can be done to lower the sleep current further?
                    rmtuckerR
                    rmtuckerR
                    rmtucker
                    @NeverDie
                    Is that a bare board with nothing connected (Not even serial)?
                      @NeverDie
                      NeverDieN
                      NeverDieN
                      @NeverDie
                      Yes. It's the bare Ebyte nRF52832 module. The only connections are Vcc and GND.
                        @NeverDie
                        rmtuckerR
                        rmtuckerR
                        rmtucker
                        @NeverDie
                        Theoretically it should be around 1.9uA
                        • NeverDieN
                          NeverDieN
                          Interestingly, I just now tried the same measurement with one of these nRF52832 modules instead of the Ebyte module:
                          https://www.aliexpress.com/item/nRF52832-Bluetooth-4-1-BLE-Module-M4-Transparent-Transmission-SMA-512K-FLASH-64K-RAM-pass-through/32798522093.html?spm=a2g0s.9042311.0.0.KKA3PF
                          and during sleep it measured 6uA. Quite a bit lower!
                          Anyone know of a module which tests even lower than that?
                          Nca78N 1 Reply Last reply
                            Nca78N
                            Nca78N
                            Did you use the same board definition in the IDE and the same script ?
                            • Nca78N Nca78
                              NeverDieN
                              NeverDieN
                              @Nca78 said in nRF5 Bluetooth action!:
                              Yes.
                                Yes.
                                rmtuckerR
                                rmtuckerR
                                rmtucker
                                @NeverDie
                                Have you tried sleep and wait for an external interrupt instead of sleep and wake on timer?
                                Just in case it is the lfxtl that is causing the problem.
                                  @NeverDie
                                  NeverDieN
                                  NeverDieN
                                  @NeverDie
                                  Haven't tried that yet. Is there a library functional call for that, or do I need to start addressing the registers directly? With this new mpu, I feel like I'm learning to walk all over again.
                                    @NeverDie
                                    rmtuckerR
                                    rmtuckerR
                                    rmtucker
                                    @NeverDie
                                    Try
                                    sleep(digitalPinToInterrupt(10), FALLING,0);
                                      @NeverDie
                                      Try
                                      NeverDieN
                                      NeverDieN
                                      #518
                                      @NeverDie
                                      Try
                                      Unexpected result: using that as the sleep invocation, the infor-link module measures at 14ua while sleeping. i.e. worse, not better, compared to the 6ua measured earlier.
                                      • NeverDieN
                                        NeverDieN
                                        #519
                                        Looks as though the infor-link is using an A620N crystal:
                                        I tried to see if I could find a datasheet for it, in the hope of learning what its current consumption is (or, at least, should be). Unfortunately, though, I couldn't find a datasheet for an A620N.
                                        • NeverDieN
                                          NeverDieN
                                          #520
                                          Maybe it doesn't matter, because in looking at the actual module I received, it appears to use a different XTAL anyway: A649N.
