  3. nRF5 action!
nRF5 action!
  • d00616D d00616
    @NeverDie Thank you sharing your experience here. It helps me of better understanding some nRF5 internals. It would be awesome if you share your code.
    Do you know of any good PPI tutorials? The datasheet seems awfully skimpy on its explanation of exactly how to use it.
    To understand PPI you have to be in mind that nearly everything is driven by tasks and events. If you want to do something, you have to start a task like 'NRF_RADIO->TASKS_TXEN=1'. If a task ends it generates an event like 'NRF_RADIO->EVENTS_READY'. You can replace NRF_RADIO with another periphery the registers have an equal naming scheme.
    For an event an Interrupt can be enabled with the NRF_RADIO->INTENSET register. Each event correspondents with a bit in that register. In an interrupt, you have to reset the NRF_RADIO->EVENTS_READY register to 0 to allow triggering a new interrupt. For compatibility, you can use the NRF_RESET_EVENT macro in interrupts. This reads back the register on nRF52 to avoid caching effects. Interrupts doesn't matter for PPI :-)
    The next fine thing are Shortcuts. Shortcuts are limited to the same peripheral unit. Bits in the NRF_RADIO->SHORTS register are corresponding to a connection between an event and a test. If the event is triggered the task is started. This allows to trigger things like send an packet after the radio is ready. To use this, you have to enable the shortcut in the NRF_RADIO->SHORTS register.
    To break the limits of shortcuts, there is the PPI unit with 32 channels. Some of the channels are predefined but interesting to see how things are implemented with BLE. The other PPI channels are flexible. To use one of these channels, you have to write a pointer of your event register, like '(uint32_t)&NRF_RADIO->EVENTS_END' to the NRF_PPI->CH[YOUR_CHANNEL].EEP register and a pointer to your task you want to start in the NRF_PPI->CH[YOUR_CHANNEL].TEP register like '(uint32_t)&NRF_TIMER0->TASKS_START'. Then you have to enable the PPI channel by setting the corresponding bit like 'NRF_PPI->CHENSET |= (1 << COUR_CHANNEL)' that's all.
    The nRF52, but not the nRF52 comes with NRF_PPI->FORK[YOUR_CHANNEL].TEP registers. in my reading you can start a second task with this register like writing to NRF_PPI->CH[YOUR_CHANNEL].TEP.
    I have no idea about using the PPI Groups.
    Arudino provides a PPI library for the primo: http://cdn.devarduino.org/learning/reference/ppi I think we have to use this library to be compatible in the future. I hope there is a chance to port things to arduino-nrf5 back.
    Edit: The arduino PPI library is not flexible enough to support radio events. :-(
    NeverDieN
    NeverDieN
    Here it is:
    #include <nrf.h>
      NRF_POWER->DCDCEN=1;  //enable the DCDC voltage regulator as the default.
      //guarantee RESET pin is working
      if (((NRF_UICR-> PSELRESET[0])==0xFFFFFFFF) && ((NRF_UICR-> PSELRESET[1])==0xFFFFFFFF)) { //if the two RESET registers are erased
        NRF_NVMC->CONFIG=1;  // Write enable the UICR
        NRF_UICR-> PSELRESET[0]=21;  //designate pin P0.21 as the RESET pin
        NRF_UICR-> PSELRESET[1]=21;  //designate pin P0.21 as the RESET pin
        NRF_NVMC->CONFIG=0;  // Put the UICR back into read-only mode.
      NRF_RADIO->FREQUENCY=123;
      NRF_RADIO->MODE=2;  //set 250kbps datarate.  May as well stretch out the NULL packet as much as possible.
      NRF_RADIO->TASKS_DISABLE=1;  //turn-off the radio to establish known state.
      while (NRF_RADIO->STATE!=0) {}  //busy-wait until radio is disabled
      NRF_RADIO->TASKS_TXEN=1;  //wake-up the radio
      while ((NRF_RADIO->STATE)!=10) {}  //busy-wait until radio has started TXIDLE
      //Assertion: radio is now in TXIDLE state.
        //assume radio is in TXIDLE state.
        NRF_RADIO->TASKS_START=1;  //Move from TXIDLE state to TX state.  This sends a NULL packet.
        while ((NRF_RADIO->STATE)!=11) {}  //busy-wait until radio is in TX state
        while ((NRF_RADIO->STATE)==11) {}  //busy-wait until radio is back to TXIDLE state
        //Assertion: radio is now back to TXIDLE state
    • NeverDieN
      NeverDieN
      #822
      So, to make the above code work as a PPI, all I would need is some kind of linkage such that whenever the "event" of TXIDLE occurs, then a "task" (in this case it would be TASKS_START) is executed to move the radio back into the TX state.
      Hmmm.. Still not obvious though from just the datasheet how to actually setup even that simple linkage.
      d00616D 1 Reply Last reply
      • NeverDieN NeverDie
        d00616D
        d00616D
        d00616
        wrote on last edited by d00616
        #823
        This is a use case for shortcuts. PPI is not required.
        There is no TXIDLE event but looking at the state diagram is TXIDLE a result of ether READY or END event. You can enable following shortcurts:
        NRF_RADIO->SHORTS = RADIO_SHORTS_READY_START_Msk | RADIO_SHORTS_END_START_Msk;
        In PPI this should be the code (untested):
        #define CHANNEL (1)
        NRF_PPI->CH[CHANNEL].EEP = (uint32_t)&NRF_RADIO->EVENTS_END;
        NRF_PPI->CH[CHANNEL].TEP = (uint32_t)&NRF_RADIO->TASKS_START;
        NRF_PPI->CH[CHANNEL+1].EEP = (uint32_t)&NRF_RADIO->EVENTS_READY;
        NRF_PPI->CH[CHANNEL]+1.TEP = (uint32_t)&NRF_RADIO->TASKS_START;
        NRF_PPI->CHENSET = (1 << CHANNEL) | (1 <<( CHANNEL+1));
        • NeverDieN
          NeverDieN
          Thanks! That helps my understanding quite a bit. I've tested the following shortcut code, and it works:
          #include <nrf.h>
            NRF_RADIO->SHORTS = B100001;  //Implement shortcuts: READY_START and END_START
            NRF_RADIO->TASKS_TXEN=1;  //wake-up the radio transmitter and move it into state TXIDLE.
            //The shortcuts will take-over the moment the state TXIDLE becomes activated.
          NeverDieN 1 Reply Last reply
          • NeverDieN
            NeverDieN
            Is there any example code which illustrates the use of interrupts on the nRF52832?
              #include <nrf.h>
              NeverDieN
              NeverDieN
              #826
              Looks as though it should be possible to send tightly packed meaningful packets, not just null packets, using almost the same methodology.
                d00616D
                d00616D
                d00616
                Yes. In a sketch, you have to put the interrupt routine into one line. You can define the interrupt only once. If you want to use the radio ISR, you can't enable the radio in MySensors.
                https://github.com/sandeepmistry/arduino-nRF5/issues/52
                https://github.com/mysensors/MySensors/blob/development/drivers/NRF5/Radio_ESB.cpp#L500
                • NeverDieN
                  NeverDieN
                  Interestingly enough, it turns out all I need to do is transmit one packet, and afterward just leave the radio in TXIDLE mode. That's because, as indicated in the datasheet, it transmits a carrier wave of one's (or any pattern you program) after the packet, expecting that another packet will be sent soon. This is illustrated in Figure 37 of the DS.
                  • NeverDieN
                    NeverDieN
                    #829
                    So, I've got the transmit side of this problem figured out. Next up: the receiver side, which already works using the MCU.
                    The next step will be to see whether I can setup timed events from the RTC which can be used to trigger the PPI to measure the RSSI without waking up the MCU. Also, I'll need some way for the PPI to evaluate the magnitude of the RSSI without involving the MCU. Ideally it would also trigger a Rx sequence if the RSSI is above threshold and wake the MCU if something gets received. Not sure how much of this will be possible, but that's the wish list.
                    I'd say the energy consumption is already pretty good after switching to the RSSI paradigm, but if this succeeds, then it may cut what remains of the energy consumption roughly in half. At that point, I think we will have wrung just about every possible bit of efficiency out of this radio, with the remaining to-do's as mostly mop-up and maybe some fine tuning (e.g. to better mitigate against false positives on the RSSI threshhold trigger).
                    • NeverDieN
                      NeverDieN
                      #830
                      So, I figure the way to get started is to do something "easy", like maybe use the PPI to blink an LED.
                      We want the lower power RTC, not the system clock. We want to use the RTC TICK event, so that the mpu can be powered down while the PPI is running.
                      So, because I want a timer event every 100ms, that means the prescaler should be 3276.
                      • NeverDieN
                        NeverDieN
                        #831
                        So, just starting on this, where I'm at is:
                        #include <nrf.h>
                        #define LED_PIN 18
                        bool toggle=false;  //track whether or not to toggle the LED pin
                          NRF_CLOCK->LFCLKSRC=1;  //use the crystal oscillator.
                          NRF_CLOCK->TASKS_LFCLKSTART=1;  //start the crystal oscillator clock
                          while (!(NRF_CLOCK->EVENTS_LFCLKSTARTED)) {}  //busy-wait until the clock is confirmed started.
                          NRF_RTC1->TASKS_STOP=1;  //stop the RTC so that we can set the prescaler
                          NRF_RTC1->PRESCALER=3276;  //once per 100ms
                          NRF_RTC1->TASKS_START=1;  //start the RTC so that we can start getting TICK events
                          hwPinMode(LED_PIN,OUTPUT_H0H1);  //establish P0.18 as the LED pin.
                          if (NRF_RTC1->EVENTS_TICK) {
                            toggle=!toggle;
                            digitalWrite(LED_PIN,toggle);
                        Unfortunately, this does not work because (NRF_RTC1->EVENTS_TICK) always reads as zero. Not sure why(?).
                          This whole topic has been brewing in the back of my mind for a couple years now:
                          https://forum.mysensors.org/topic/1788/nrf51822-as-an-all-in-one
                          and
                          https://forum.mysensors.org/topic/3836/anyone-besides-me-looking-into-long-range-bluetooth-for-their-wireless-nodes
                          With the nRF52840, it looks as though the moment has finally arrived to tie it all together and give it a try. :)
                          I just have no idea where to even begin though. Just order the nRF52840 preview DK? Is it fairly quick to get something up and running, or is it a fairly steep learning curve?
                          JokgiJ
                          JokgiJ
                          Jokgi
                          @NeverDie you will need long range capabilities on both sides of the link. So two preview kits work great. Long range is supported by SDK 14 and the current softdevice.
                          • scalzS scalz
                            @NeverDie
                            nrf52832 is definitely better than nrf24l01. if i'm not wrong, 4db can double range in theory.
                            For range, an important point is the antenna, as you already know.
                            Chip antenna can be ok, depending on the environment and usecase, but can't compete with a rfm69. These antennas are not for long range, so the adafruit board. How to miniaturize antennas without loosing performance..
                            JokgiJ
                            JokgiJ
                            Jokgi
                            @scalz the nRF52832 has a hotter receiver. ( better sensitivity.) at 1 mb/ s then the nRF24l series. Overall link Budget is better. 840 even better with a 8dB output.
                            • scalzS
                              scalzS
                              wrote on last edited by scalz
                              #834
                              @Jokgi
                              of course I agree !
                              that's why in the past i preferred rfm69 modules (better range of course, but more power hungry). 832 being better than nrf24, i'm now using it. And I also like the 840dk (neat package) :+1:
                              That said, if i remember well, nrf52832 is not fully BLE5 long range compatible as 840 is.
                              • JokgiJ Jokgi
                                NeverDieN
                                NeverDieN
                                #835
                                @Jokgi said in nRF5 Bluetooth action!:
                                I'm not disagreeing, but presently modules for it (other than the preview DK) aren't yet available. Meanwhile, hopefully nearly all of what's being learned here about the nRF52832 will be of direct relevance. For instance: PPI.
                                  #include <nrf.h>
                                  #define LED_PIN 18
                                      toggle=!toggle;
                                  NeverDieN
                                  NeverDieN
                                  #836
                                  It should be working, but it isn't. Nor do I see a way to check it with an oscilliscope. So, my current theory is that it gets set but cleared so quickly that it can't be read by the MCU. So, the next step will be to assume that it is, in fact, working, and to use it as a PPI trigger, which is what this is all building toward anyway.
                                  On the other hand, perhaps there's an easy way to have the EVENTS_TICK set an interrupt bit, which would persist until it was cleared? Hmmm. No, not quite, but there is INTENSET, which will set an interrupt on an EVENT_TICK. That will do. Exactly which interrupt gets triggered though? Figure 46 shows that an IRQ signal is sent to NVIC ( the Nested Vectored Interrupt Controller). According to the table in sectoin 7.3, the NVIC has 37 interrupt vectors. According to section 15.8:
                                  A peripheral only occupies one interrupt, and the interrupt number follows the peripheral ID. For example, the
                                  peripheral with ID=4 is connected to interrupt number 4 in the Nested Vectored Interrupt Controller (NVIC).
                                  So, based on that, we need to know the ID number for the RTC, and then we'll know which interrupt number to track. According to Table 10, the Peripheral ID for the RTC is 11 (well, at least it is for the RTC0, so I will recode to use RTC0 instead of RTC1).
                                  Now, according to Table 10, the memory location that corresponds to Peripheral ID 11 is 0x4000B000. Therefore, it is this memory location we need to examine to know if a TICK interrupt has occured.
                                  • NeverDieN
                                    NeverDieN
                                    #837
                                    Close, but no cigar. What I found out is that if I set the TICK interrupt with:
                                          NRF_RTC0->INTENSET=1;  //set the TICK interrupt bit
                                    then at the following memory addresses, the value stored there immediately becomes 1:
                                    4000B300
                                    4000B304
                                    4000B308
                                    and if I clear the TICK interrupt with:
                                          NRF_RTC0->INTENCLR=1;  //clear the TICK interrupt bit
                                    then the values at those same memory addresses immediately becomes zero. I can toggle back and forth as much as I want, and this is always true.
                                    However, none of this is telling me whether the TICK interrupt has actually triggered. Where do I find that?
                                    Based on the current pre-scaler, COUNTER increments once every TICK (i.e. once every 100ms). However, is there an actual TICK flag somewhere that goes high at those times and then low again after getting cleared? Or, is it only accessible indirectly by using PPI?
                                    • NeverDieN
                                      NeverDieN
                                      #838
                                      OK, I came up with a simple equivalent. Basically, every time COUNTER is incremented, I reset it to zero. It then effectively acts much the way a TICK should. For whatever reason, once EVENTS_TICK goes high, it just stays high forever. So, it doesn't seem very useful per se, though maybe there's a way to clear it that I haven't yet found.
                                      • NeverDieN
                                        NeverDieN
                                        #839
                                        Strangely enough, the overflow is the same: once it goes HIGH, it stays that way:
                                        https://pastebin.com/vypuVJeh
                                        So, I would think there must be some way (?) to clear them.
                                        • NeverDieN
                                          NeverDieN
                                          #840
                                          I found the answer. Unlike EVENTS in other peripherals, which are read-only, the EVENTS in RTC are RW. So, the way you clear the TICK and OVRFLW events is just by setting them to zero manually:
                                          e.g.
                                          NRF_RTC0->EVENTS_TICK=0;
                                          LOL. Of course, the DS never mentions this.
                                          In any case, with that change, it can now work properly:
                                          https://pastebin.com/nHWAGFkd
