  3. Where to get legit nRF24L01+ modules?
counterfeitnrf24l01+nrf24l01+pa+lna
85 Posts 9 Posters 35.4k Views 12 Watching
  • d00616D d00616
    @Yveaux Thank you for the X-Ray images. I can't get images in that resolution.
    YveauxY
    YveauxY
    @d00616 they aren't xray images. The die shots were obtained by eating away the chip package with acid.
      Itead or some other legit company like mouser should stock the real thing.
      Bogus ExceptionB
      Bogus ExceptionB
      Bogus Exception
      @hek Thanks for writing. I got 4 from itead the other day (2 each of 2 types), and they are in the boxes in front of me. FOr one thing-they have a box! I am making a video for my blog comparing them to the clones (as best I can), and I'm going to test out that current statement I found online...
      Thanks for the tip!
      "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
      -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
      -ATTiny, ATMega, STM32
      -Geek Channel: https://www.youtube.com/TheSalesEngineer
      • tbowmoT tbowmo
        I think that Itead studio promised me that it was genuine NRF that they used for their modules.
        But it's a couple of years since I purchased any from them, and I'm not sure which ones of the different NRF modules that I have, that actually came from Itead.. :)
        Bogus ExceptionB
        Bogus ExceptionB
        Bogus Exception
        @tbowmo Thanks for the tip. I have some in front of me, still in box. Will post results.
        • Nca78N
          Nca78N
          I received my Ebyte modules, not a warranty of authenticity but the nrf chip has a square instead of a dot like all the fakes I have been using until now. I have a few standard SMD modules and a PA LNA version, I will try to make some basic range tests soon compared to the SMD clones.
          Bogus ExceptionB gohanG 3 Replies Last reply
          • Nca78N Nca78
            Bogus ExceptionB
            Bogus ExceptionB
            Bogus Exception
            OK! I followed your suggestions and tried itead. These are the pics of what I got 4 of (sorry no pro rig-just a loupe & module in one hand & mouse in the other!
            (all are hosted on one of my servers, not here locally)
            gohanG 1 Reply Last reply
            • Bogus ExceptionB Bogus Exception
              @Bogus-Exception let us know how they perform
              Bogus ExceptionB 1 Reply Last reply
                Bogus ExceptionB
                Bogus ExceptionB
                Bogus Exception
                @gohan I'll do my best to measure meaningful metrics between these & clones. Also, I have 4 eBytes coming (2x blue, 2x red)...
                • Bogus ExceptionB
                  Bogus ExceptionB
                  Bogus Exception
                  wrote on last edited by Bogus Exception
                  #48
                  So far I've noticed on all versions of the legit nRF24 chips that the 'square' is actually 4 vertical lines, covering a square area, at the 'top left' of the chip.
                  Just tried over the past 2 hours to replace the clone in my MyController gateway with either the itead or ebyte legit modules, and neither one of them would communicate with the other nodes. I put the clone back in, and it worked. Weird.
                  Not like it matters much, but here is the sketch (all comments removed) using a BME280 and a light sensor module, on a Nano, USB powered:
                  #define MY_GATEWAY_SERIAL
                  #if F_CPU == 8000000L
                  #define MY_BAUD_RATE 38400
                  #include <Adafruit_Sensor.h>
                  #include <Adafruit_BME280.h>
                  #define BME_SCK 13
                  #define BME_MISO 12
                  #define BME_MOSI 11
                  #define BME_CS 6
                  #define SEALEVELPRESSURE_HPA (1013.25)
                  const float ALTITUDE = 18;
                  Adafruit_BME280 bme(BME_CS); // hardware SPI
                  #define LIGHT_CHILD 0
                  #define BARO_CHILD 1
                  #define TEMP_CHILD 2
                  #define HUM_CHILD 3
                  boolean metric;
                  uint8_t decimals;
                  MyMessage lightMsg(LIGHT_CHILD, V_LIGHT_LEVEL); // 0
                  MyMessage pressureMsg(BARO_CHILD, V_PRESSURE); // 1
                  MyMessage tempMsg(TEMP_CHILD, V_TEMP); // 2
                  MyMessage humMsg(HUM_CHILD, V_HUM); // 3
                  #define LIGHT_SENSOR_ANALOG_PIN 0
                  int lastLightLevel;
                  unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                    #ifdef MY_DEBUG
                      Serial.begin(115200);
                    decimals = 2;
                    bool status;
                    status = bme.begin();
                    if (!status) {
                      #ifdef MY_DEBUG
                        Serial.println("Could not find a valid BME280 sensor, check wiring!");
                      while (1);
                    sendSketchInfo("Master Nano", "1.0");
                    present(LIGHT_CHILD, S_LIGHT_LEVEL);  // 0
                    present(BARO_CHILD, S_BARO);          // 1
                    present(TEMP_CHILD, S_TEMP);          // 2
                    present(HUM_CHILD, S_HUM);            // 3
                    int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                      #ifdef MY_DEBUG
                        Serial.print(F("Sending lightMsg: "));
                        Serial.println(String(lightLevel));
                      send(lightMsg.set(lightLevel));
                      lastLightLevel = lightLevel;
                    float p_Mb = bme.readPressure() / 100.0F;
                    float p_Hg = p_Mb / 33.86;
                    #ifdef MY_DEBUG
                      Serial.print(F("Sending pressureMsg: "));
                      Serial.println(String(p_Hg));
                    send(pressureMsg.set(p_Hg, decimals));
                    float t_C = bme.readTemperature();
                    float t_F = (t_C * (9/5)) + 32;
                    #ifdef MY_DEBUG
                      Serial.print(F("Sending tempMsg: "));
                      Serial.println(String(t_F));
                    send(tempMsg.set(t_F, decimals));
                    float h_Pct = bme.readHumidity();
                    #ifdef MY_DEBUG
                      Serial.print(F("Sending humMsg: "));
                      Serial.println(String(h_Pct));
                    send(humMsg.set(h_Pct, decimals));
                    #ifdef MY_DEBUG
                      Serial.print(F("Sleeping for: "));
                      Serial.println(String(SLEEP_TIME));
                    sleep(SLEEP_TIME);
                  It works with the clone... I am using a regulator board for the nRF24-the one it plugs into & breaks out the 8 pins...
                  YveauxY gohanG 2 Replies Last reply
                    #define BME_SCK 13
                    #define BME_MISO 12
                    #define BME_MOSI 11
                    #define BME_CS 6
                    #define HUM_CHILD 3
                    boolean metric;
                    uint8_t decimals;
                    int lastLightLevel;
                      #ifdef MY_DEBUG
                      decimals = 2;
                      bool status;
                      if (!status) {
                        #ifdef MY_DEBUG
                        while (1);
                        #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      sleep(SLEEP_TIME);
                    YveauxY
                    YveauxY
                    @Bogus-Exception said in Where to get legit nRF24L01+ modules?:
                    You cannot rely on the print of the nRF to distinguish fake from genuine. Nordic is fabless, so they use different factories to produce their chips, each with its own specific marking.
                      #define BME_SCK 13
                      #define BME_MISO 12
                      #define BME_MOSI 11
                      #define BME_CS 6
                      #define HUM_CHILD 3
                      boolean metric;
                      uint8_t decimals;
                      int lastLightLevel;
                        #ifdef MY_DEBUG
                        decimals = 2;
                        bool status;
                        if (!status) {
                          #ifdef MY_DEBUG
                          while (1);
                          #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        sleep(SLEEP_TIME);
                      @Bogus-Exception may I ask why are you using spi for bme280 sensor instead of i2c?
                      Bogus ExceptionB 2 Replies Last reply
                        Bogus ExceptionB
                        Bogus ExceptionB
                        Bogus Exception
                        @gohan I already have the 3 pins for SPI in use for the nRF, so adding the BME was just one more pin. Simply conserving pins.
                        • YveauxY Yveaux
                          Bogus ExceptionB
                          Bogus ExceptionB
                          Bogus Exception
                          @Yveaux Fair enough. I won't rel on that, but did want to mention the observation.
                          On a relatively side note, I got 4 SMD nRF24 cards from eByte, but can't locate any boards to mount them on! The holes are 1.27mm pitch, so I just ordered some 1.27mm headers.
                          Has anyone grabbed a board to surface mount solder them at this pitch?
                          NeverDieN Nca78N 2 Replies Last reply
                            NeverDieN
                            NeverDieN
                            #53
                            What's the pitch on most other SMD nRF24L01+ modules? Is it also 1.27mm, or something else? I hadn't paid attention.
                            • NeverDieN NeverDie
                              Bogus ExceptionB
                              Bogus ExceptionB
                              Bogus Exception
                              @NeverDie Great question. Mine look like these from a post earlier in this thread, and they are the first I've seen that didn't have their (breadboard-unfriendly) pinout.
                              • NeverDieN
                                NeverDieN
                                Not sure if it's what you mean, but for prototyping purposes you could solder them to generic 1.27mm proto-board, such as this: https://www.aliexpress.com/item/6-X-8CM-spacing-1-27-universal-board-thickness-1-6mm-sided-HASL-PCB-test-board/32774106087.html?spm=a2g0s.9042311.0.0.eD40xE
                                  I think there are adapters to solder the smd version and make them 8 pin compatible or there are generic adapters that can change the pitch
                                    Nca78N
                                    Nca78N
                                    You can use NModule, the footprint highlighted in red color in the image below is compatible
                                    https://www.openhardware.io/view/364/NModule
                                    • Nca78N Nca78
                                      Bogus ExceptionB
                                      Bogus ExceptionB
                                      Bogus Exception
                                      @kalina made these DIP-to-SMD-NRF24L01-adapter, but my need isn't enough quantity to buy the chemicals, pay someone to make a rum of them, or convince my wife that, "We'll sell them and make our money back!" :-[
                                      NeverDieN 1 Reply Last reply
                                      • Nca78N Nca78
                                        Bogus ExceptionB
                                        Bogus ExceptionB
                                        Bogus Exception
                                        @Nca78 Not just the module (10 for $15, right?), but the page concept is exactly what I am doing these days. Built in flexibility where it matters!
                                        You've clearly spent a lot of time at my stage of tinkering with this!
                                        Little touches like PA pinout, etc. makes this cake have more icing then cake! :o
                                          NeverDieN
                                          NeverDieN
                                          #60
                                          @Bogus-Exception
                                          I'm sure the Kalina adapter would be inexpensive if you purchased 3 through OSH PARK because the surface area is small.
