  3. NRF24 i cant configure raspberry pi1
25 Posts 4 Posters 5.8k Views 4 Watching
  • mfalkviddM Offline
    Easiest way to check the nrf is probably to build a node, if you have a spare Arduino.
    • Rodolfo VieiraR Offline
      Rodolfo Vieira
      @mfalkvidd
      may be all my nrf24 are damaged, i have 3.
      Is there any way to check if they are good?
      If the connections are well made should work correct?
      And is an external source even necessary?
      tomorrow i will test what do you say me now, because now have to go to work.
      • J Offline
        J Offline
        Juan González M.
        Same problem here.
        Rodolfo VieiraR 1 Reply Last reply
        • J Juan González M.
          Same problem here.
          Rodolfo Vieira
          @Juan-González-M. said in NRF24 i cant configure raspberry pi1:
          Same problem here.
          If you solve the problem please tell me.
          • H Offline
            H Offline
            HenkeP
            hi,
            I just did this setup last week and also had similar problems. I did run make without any options added. NRF24 is allready enabled by default.
            One thing I did was to enable SPI and then I think it worked better. There's options in "sudo raspi-config" (advanced menu) to enable I2C and SPI, could that be the issue?
            //Henrik
