  3. NRF24 i cant configure raspberry pi1
25 Posts 4 Posters 5.8k Views 4 Watching
  • Rodolfo VieiraR Offline
    Rodolfo Vieira
    wrote on last edited by Rodolfo Vieira
    hello everbody, i need your help.
    I connect my NRF to Raspberrypi according the tutorial: https://www.mysensors.org/build/raspberry
    1 step i installed that line:
    git clone https://github.com/mysensors/MySensors.git --branch master
    OK
    2 step i wrote: cd MySensors
    but when i tried 3 step
    pi@hassbian:~ $ cd MySensors
    pi@hassbian:~/MySensors $ --my-transport=nrf24
    give this error:
    -bash: --my-transport=nrf24: command not found
    what can i do?
    thanks
    • Rodolfo VieiraR Rodolfo Vieira
      OK
      give this error:
      what can i do?
      thanks
      @Rodolfo-Vieira enter ./configure before you add all the parameters
        Rodolfo Vieira
        @mfalkvidd
        pi@hassbian:~/MySensors $ ./configure
        [SECTION] Detecting target machine.
        [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv6l.
        [SECTION] Checking GPIO Sysfs.
        [OK] /sys/class/gpio/export found
        [SECTION] Detecting SPI driver.
        [WARNING] No supported SPI driver detected.
        [SECTION] Detecting init system.
        [OK] init system detected: systemd.
        [SECTION] Saving configuration.
        [SECTION] Cleaning previous builds.
        [OK] Finished.
        the error continues
          @mfalkvidd
          [OK] Finished.
          the error continues
          @Rodolfo-Vieira put everything on the same line before you press enter :)
            Rodolfo Vieira
            @Rodolfo-Vieira said in NRF24 i cant configure raspberry pi1:
            @mfalkvidd ahhhh ok :) sorry, now i can solve this problem:
              @Rodolfo-Vieira that is just a warning. What does it say after?
                Rodolfo Vieira
                @mfalkvidd
                ok, already actived SPY
                [OK] SPI driver detected:SPIDEV.
                [OK] Finished.
                now what the frequency i should in this line:
                --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw
                remember i use nrf24 no rfm69
                  @mfalkvidd
                  [OK] Finished.
                  @Rodolfo-Vieira none of the rfm parameters are applicable if you use the nrf24 radio.
                    Rodolfo Vieira
                    @mfalkvidd
                    ok thank you so...i make this:
                    1 git clone https://github.com/mysensors/MySensors.git --branch master
                    cd MySensors
                    2 ./configure --my-transport=nrf24
                    3 ./configure --my-gateway=ethernet --my-port=5003
                    4 ./configure --my-gateway=ethernet --my-controller-ip-address=192.168.1.65
                    5 make
                    6 sudo ./bin/mysgw -h
                    7 sudo ./bin/mysgw -d
                    and i receive this:
                    pi@hassbian:~/MySensors $ sudo ./bin/mysgw -d
                    mysgw: Starting gateway...
                    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: !TSM:INIT:TSP FAIL
                    mysgw: TSM:FAIL:CNT=1
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:FAIL:RE-INIT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=2
                    mysgw: TSM:FAIL:PDT
                    what is the problem?
                      @mfalkvidd
                      cd MySensors
                      5 make
                      and i receive this:
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:PDT
                      @Rodolfo-Vieira everything on a single line :)
                      ./configure and then add all the options you want. Then press enter. Then run make.
                      But it looks like the radio is not correctly wired. Could you post a photo?
                        Rodolfo Vieira
                        @mfalkvidd lol ok, i am newbie sorry for the stupid acts.
                        1 ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003 --my-gateway=ethernet --my-controller-ip-address=192.168.1.65
                        2 make
                        3 sudo ./bin/mysgw -h
                        4 sudo ./bin/mysgw -d
                        result:
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: TSM:FAIL:PDT
                          TSM:INIT:TSP FAIL means the software is unable to communicate with the radio. That is usually due to the radio not being correctly wired. Could you post a photo?
                            Rodolfo Vieira
                            off course
                            https://goo.gl/photos/WB7kkt9A4uxkSwr99
                              off course
                              @Rodolfo-Vieira thanks. It will take me a while to compare to the wiring guide but I'll report as soon as I have mapped the colors.
                                Rodolfo Vieira
                                @mfalkvidd ok no problem i waiting
                                  @Rodolfo-Vieira on raspberry pi 1, pin 15 is not gnd. Move it to pin 20 or one of the other gnd pins. Stop mysgw (ctrl+c) and start it again after you have switched pins.
                                    Rodolfo Vieira
                                    @mfalkvidd you are correct. I confirm all the wires 5 times.
                                    but the error is the same.
                                    after that i changed my nrf for two other that i had, and the error is the same.
                                    exist any way to confirm if the nrf24 is working fine? may be my nrf are damaged. i dont know.
                                    edit: I tried to , connect POWER NRF24 to external power, and connect ground external power to ground raspberry pi.. and the result is the same.
                                    TSM:INIT:TSP FAIL
                                      TSM:INIT:TSP FAIL
                                      @Rodolfo-Vieira do you mean that moving gnd on nrf24 from 19 to 20 on raspberry pi did not help?
                                        Rodolfo Vieira
                                        @mfalkvidd
                                        yes i changed gnd As you told me,,,and not work.
                                        after that i confirm again all wires...and not work again.... then i connect more two nrf24...make sudo reboot
                                        and run sudo ./bin/mysgw -d
                                        but the error is the same,,, so a decide help with external source 3.3v
                                        i connected wire power nrf24 ---> power external source
                                        gnd powersource -------> other gnd raspberry pi
                                        sudo reboot again...
                                        after sudo ./bin/mysgw -d
                                        and the error is the same..... :(
                                        • mfalkviddM Offline
                                          Sorry, I see now that I probably misinterpreted the photo.
                                          Cross-referencing your colors with the official wiring instructions is very tedious.
                                          But it looks like the wiring is indeed correct.
