  3. 💬 Easy-Peasy Amplified MySensors Serial Gateway
19 Posts 11 Posters 11.9k Views 9 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/457/Easy-Peasy-Amplified-MySensors-Serial-Gateway
    • YveauxY
      YveauxY
      Are you sure the wemos can supply sufficient power for the amplified nrf?
      • YveauxY Yveaux
        @Yveaux good point. Wemos D1 mini uses a ME6211 ldo which is rated for 500mA (600mA absolute maximum). If I remember correctly, the nrf24 with pa/lna needs a maximum of 115mA and the esp8266 itself 160mA. So there should be plenty of margin.
        YveauxY 1 Reply Last reply
          YveauxY
          YveauxY
          @mfalkvidd said in 💬 Amplified MySensors Serial Gateway:
          I hope all the clones will use the same LDO, or equivalent then ;-)
          korttomaK 1 Reply Last reply
          • YveauxY Yveaux
            korttomaK
            korttomaK
            korttoma
            @Yveaux said in 💬 Amplified MySensors Serial Gateway:
            Lets hope people stick to the originals since they are not that expensive
            https://wemoscc.aliexpress.com/store/1331105
            • Tomas
            • scalzS
              scalzS
              wrote on last edited by scalz
              very simple :)
              I agree with yveaux though, always good to have some optional footprints for decoupling in case. No idea if there are some. Also, putting electronics above antenna (of esp8266) is not very recommended, but this should work.
              • skywatchS
                skywatchS
                skywatch
                This does not use the genuine NRF24L01+ by the looks of it.
                The wording is clever, but the imported parts list does not include Norway and the device is only 'based on' and imported chip from Norway. Nowhere does it say it incorporates this chip and if you look at the RF spec, it can operate higher than the NRF spec sheet for the real chip.....
                • NeverDieN
                  NeverDieN
                  I don't know anything more than you do. However, you could substitute a different amplified nRF24L01+ module if you prefer. I can say that it seems to work alright at 250kbps and 1mbps. 2mbps is possibly problematic, though in my limited testing the cause of that may be unrelated.
                  • NeverDieN
                    NeverDieN
                    I had a chance to test the module more thoroughly, and it appears to work just fine at 2mbps also. So, as of this moment, everything seems good, and I'm not aware of any problems. :)
                    • S
                      seaspac
                      is there a connection diagram?
                      • NeverDieN
                        NeverDieN
                        The newer E01-2G4M27D has more powerful transmit and more sensitive receive capability:
                        https://www.aliexpress.com/item/4000536940861.html?spm=a2g0s.9042311.0.0.58a24c4dtdfoIK
                        • K
                          K
                          KevinT
                          I know this thread is old but it seems the most relevant. I just tried to compile the standard GatewaySerial.ino sketch using Wemos D1 mini as board type and I get error:
                          MyMainESP8266.cpp:95:9: error: 'cont_can_yield' was not declared in this scope;
                          I'm using MySensors Library v2.3.2
                          I'm assuming this used to work. Is it broken or I am doing something wrong?
                          • K KevinT
                            Great to see you again @KevinT
                            It is broken, and you are doing something wrong :-)
                            Use the latest supported version of the board definitions. See https://forum.mysensors.org/post/114086
                            • K
                              K
                              KevinT
                              Hi @mfalkvidd
                              I rolled back the esp8266 library to 2.6.2 and it compiles.
                              Is there an upcoming release to fix this?
                              • K KevinT
                                Hi @mfalkvidd
                                @KevinT did you read the thread I linked?
                                • K
                                  K
                                  KevinT
                                  Yes, Lol, you have 2 PRs but both have issues. I looked, but I didn't manage to find them on Github/MySensors. I did read that espressif updated their esp8266 core to use standard Arduino yield functions. I guess it's related to that.
                                  • K KevinT
                                    @KevinT should be one of these https://github.com/mysensors/MySensors/pulls?q=is%3Apr+esp8266+sort%3Aupdated-desc+
                                    • Lucas FischerL
                                      Lucas FischerL
                                      Lucas Fischer
                                      That issue is caused by the newer ESP8266 core changing yield functions. Downgrading the ESP8266 core to v2.6.2 (or v2.7.4 depending on your board setup) remains the most reliable workaround until those MySensors core PRs get merged into a main release. Keep an eye on those GitHub PRs for updates on full compatibility with current core releases!
                                      • N
                                        N
                                        noahnelson
                                        wrote last edited by
                                        For anyone building this in CI or PlatformIO, pin the ESP8266 platform version that bundles core 2.6.2 instead of relying on a globally installed core. That keeps builds reproducible while the MySensors PRs are pending. In Arduino IDE the selected core is global, so switching between projects can pick the newer version again. Might be worth adding a note to the build instructions.
