  3. RFM69HW 433 communication problem
34 Posts 5 Posters 8.0k Views 4 Watching
  • CarywinC Carywin
    Right, I'm sure that node is fine, I mainly just zoomed in and looked at this one:
    I use this same small piggyback board for many nodes and it works great with those 21mm coil antennas.
    However, I just noticed the #define for TX power. I think the H and HW versions have a minimum of 13dB or something. Have you tried without?
    @Carywin I was using the nodes on easypcb also for the new ones. What do you suggest I set the TX power?
    S 1 Reply Last reply
      @gohan - i never messed with TX power... have a look and try my sketches above. They work for me.
      • CarywinC Offline
        CarywinC Offline
        Carywin
        wrote on last edited by Carywin
        #23
        I would suggest comment out the TX power setting and let the ATC control it. If it still doesn't work, try:
        #define MY_RFM69_ATC_MODE_DISABLED
        #define MY_RFM69_TX_POWER_DBM 20
        Edit:
        Maybe also try
        and see if that tells you anything more.
          If my headache gets better, I'll do some more tests tonight
          J 1 Reply Last reply
            J Offline
            J Offline
            Jokgi
            @gohan If you are using AutoAcks and you have a combination of True Nordic based Modules and nRF24L01P clones you may have a issue. Is there a way to not use acknowledgements and see if you can communicate properly between the modules?
              I'm using rfm69 not nrf24l01
                wrote on last edited by gohan
                #27
                I think i solved the mistery... the alixpress seller sent me RFM69W modules instead of HW... I just noticed the chips are the same and in fact they work if I compile the node without the #define MY_IS_RFM69HW. I don't even know if I can get a partial refund since quite some time has passed
                PS :rage: :rage: :zap: :zap:
                  @gohan - so you got communication now that is working? That is great news.
                    Yeah... Not a good news that I got "scammed"
                      @gohan - nope its not! I hope you will get your money back!
                      But atleast you know you can make it work and how!
                      gohanG 1 Reply Last reply
                      • S sundberg84
                        @sundberg84 the bad thing is that I was recommended to use that seller as a good one.
                          @gohan - did I ? Im sorry If i did...
                          My RFM modules have been working good and are as described.
                            No, it wasn't you.
                            • S Offline
                              I guess this isnt in question anymore but I just wanted to comfirm I have tested node and it works with HW version as well. I use the code above and just added
                              #define MY_IS_RFM69HW  // Mandatory if you radio module is the high power version (RFM69HW and RFM69HCW), Comment it if it's not the case
                              12.2k
