  3. Unable to get relay status from Domoticz
13 Posts 3 Posters 4.8k Views 3 Watching
  • S
    sineverba
    wrote on last edited by sineverba
    Starting from relay example and @Boots33 synchronising light switch (https://forum.mysensors.org/topic/6948/synchronising-light-switch) I'm arranging a node with a DS18B20 +relay (simple thermostat).
    My issue is that I cannot receive the relay status from controller (Domoticz). Looking with log parser, seems to me that PAYLOAD is empty.
    This is in effect the log:
    6480 TSF:MSG:SEND,10-10-0-0,s=1,c=2,t=2,pt=0,l=0,sg=1,ft=0,st=OK:
    6496 TSF:MSG:SEND,10-10-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    6625 TSF:MSG:READ,0-0-10,s=255,c=3,t=17,pt=6,l=25,sg=1:427C42AE0562164806668CEBC26347BE1A113516C9C14F345A
    6723 TSF:MSG:SEND,10-10-0-0,s=1,c=2,t=2,pt=0,l=0,sg=1,ft=0,st=OK:
    9059 TSF:MSG:READ,0-0-10,s=255,c=3,t=17,pt=6,l=25,sg=1:499D2360929A82BB0BB9B0C47873D3E460ADF357B2DECAA3F4
    9153 TSF:MSG:SEND,10-10-0-0,s=0,c=1,t=0,pt=7,l=5,sg=1,ft=0,st=OK:29.5
    180163 TSF:MSG:READ,0-0-10,s=1,c=3,t=16,pt=0,l=0,sg=1:
    180185 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:F62E5E036965BB68EEE8797C8E9F12AA8C935F0C49F4359DFB
    180329 TSF:MSG:READ,0-0-10,s=1,c=1,t=2,pt=0,l=1,sg=1:0
    180428 TSF:MSG:SEND,10-10-0-0,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    241998 TSF:MSG:READ,0-0-10,s=1,c=3,t=16,pt=0,l=0,sg=1:
    242184 TSF:MSG:READ,0-0-10,s=1,c=1,t=2,pt=0,l=1,sg=1:1
    242284 TSF:MSG:SEND,10-10-0-0,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
    And payload seems totally empty.
    Another one thing, neither I read in serial monitor the debug section println
    case C_REQ:                                             // message is a returning request from controller
            Serial.print("Incoming request. The request_state is now: ");
    Seems never executed the case "C_REQ".
    If Domoticz sends command to poweron (or poweroff) the relay, all works like a charme. I would simply get the state of relay viewed on Domoticz.
    This is the script (my relay module is powered when PIN goes LOW; for this you see the "inverted" in #define section)
     * Sketch for a relay + termostat.
     * In test from 11/08/2017
     * @version 2.0
     * DEFINE MYSENSORS SECTION
    #define MY_DEBUG                    // Enable Basic Debug
    //#define MY_DEBUG_VERBOSE_SIGNING    // Enable Signing Debug
    #define MY_SIGNING_SOFT
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
    #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x3B,0xF4,0x61,0xFF,0xFF,0x97,0xB1,0xFF,0xEC}}}
    #define MY_NODE_ID 10               // Default ID
    #define MY_WITH_LEDS_BLINKING_INVERSE
    #define MY_DEFAULT_ERR_LED_PIN 16
    #define MY_DEFAULT_TX_LED_PIN 17
    #define MY_DEFAULT_RX_LED_PIN 18
     * Include libraries
    #include <OneWire.h>
     * Define section.
     *    // NAME
    #define SKETCH_NAME       "Termostato+Relay"
    #define SKETCH_VERSION    "2.0"
        //  PIN
    #define PIN_DS18B20       2
    #define PIN_RELAY         3
    #define PIN_LED_STATUS    19
        //  CHILD ID
    #define CHILD_ID_TEMP     0
    #define CHILD_ID_RELAY    1
        //  RELAY SECTION
    #define RELAY_ON          0   // if inverted, invert here
    #define RELAY_OFF         1   // if inverted, invert here
        //  WAITs TIMES
    #define WAIT_LOOPS        5  // The status led flashes ON 10 ms and OFF 4990 ms == 5000 ms of loop. 5000 * WAIT_LOOPS = number of cycles before new read. 60 == 5 minutes
    #define WAIT_RETURN       1500  //  Milliseconds to wait for returns from gateway
     * Various variable
    bool is_first_loop = true;
    bool request_state;
    bool state = false; // the current state of relay
    bool uplink_available = true;
    unsigned long uplink_check_time;                // holder for uplink checks
    unsigned long uplink_check_period = 30*1000;     // time between checks for uplink in milliseconds
     * One Wire Section
    OneWire oneWire(PIN_DS18B20); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
     * Mysensors message
    MyMessage msg_temperature(CHILD_ID_TEMP , V_TEMP);
    // Initialize relay message
    MyMessage msg_relay(CHILD_ID_RELAY , V_STATUS);
     * Before class
    void before() {
      sensors.begin();
     * Presentation.
     * Presents the child to the controller
    void presentation() {
      // send sketch name
      sendSketchInfo(SKETCH_NAME , SKETCH_VERSION);
      // Present all sensors to controller.
      // TEMPERATURE
      // RELAY
      present(CHILD_ID_RELAY , S_BINARY);
     * Our Setup
      // SETUP LED STATUS
        // Set the LED STATUS as OUTPUT and shutdown it.
      pinMode(PIN_LED_STATUS , OUTPUT);
      digitalWrite(PIN_LED_STATUS , LOW);
      // SETUP RELAY
        // Set the RELAY PIN as OUTPUT and LOW
      pinMode(PIN_RELAY , OUTPUT);
      digitalWrite(PIN_RELAY , RELAY_OFF);
      // initialize sensors
     * Our loop
      Serial.println("-------------- DEBUG loop() ---------------");
      Serial.print("Value of is_first_loop is ");
      Serial.println(is_first_loop);
      Serial.println("-------------------------------------------");
      if ( is_first_loop == true ) {
        // request state of relay to the controller;
        getStateFromController();
        // set is_first_loop = false;
      // executed the reading
      loopTemperature();
      // light the status led... so wait
      lightLedStatus();
     * Get the state of relay from controller.
     * Executed once at first loop.
     * @since 2.0
    void getStateFromController() {
      Serial.println("-------------- DEBUG getStateFromController() ---------------");
      if (request( CHILD_ID_RELAY , V_STATUS)) {       // request the current state of the switch on the controller and check that an ack was received
        Serial.print("request( CHILD_ID_RELAY , V_STATUS) value is ");
        Serial.print(request( CHILD_ID_RELAY , V_STATUS));
        Serial.println("Uplink available!");
        wait (WAIT_RETURN);
        Serial.print("Relay in controller is marked as ");
        * THIS IS FOREVER FALSE == 0 :(
        Serial.println(request_state);
        if (request_state != state) {      // check that controller is corectly showing the current relay state
            send(msg_relay.set(state), false);  // notify controller of current state
      } else {
        Serial.println("! ERROR uplink is not available!");
        uplink_available = false;               // no uplink established
        uplink_check_time = millis();
      Serial.println("-------------------------------------------------------------");
     * Loop temperature.
     * Executed inside loop()
     * @since 2.0
    void loopTemperature() {
      // we need sensors.requestTemperatures() to NO BLOCK THE THREAD!!!
      float temperature = readTemperature();
      Serial.println("-------------- DEBUG loopTemperature() ---------------");
      Serial.print("Temperature is now ");
      Serial.println(temperature);
      Serial.println("------------------------------------------------------");
      sendTemperatureToController(temperature);
    /****       VARIOUS FUNCTION TO SUPPORT     *****/
     * Receive function
     * @since 2.0
    void receive(const MyMessage &msg_relay) {
      Serial.println("-------------- DEBUG receive() ---------------");
      if (msg_relay.type == V_STATUS) {                                   // check to see if incoming message is for a switch
        switch (msg_relay.getCommand()) {                                 // message.getCommand will give us the command type of the incomming message
          case C_SET:                                                   //message is a set command  from controller to update relay state
            state = msg_relay.getBool();                                  // get the new state
            digitalWrite(PIN_RELAY, state ? RELAY_ON : RELAY_OFF);      // switch relay to new state
            uplink_available = true;                                     //  uplink established
            Serial.print(msg_relay.sensor);
            Serial.println(msg_relay.getBool());
            break;
            request_state = msg_relay.getBool();                       // update requestState with returning state
            break;
      Serial.println("--------------------------------------------");
     * Read the temperature from DS18B20
     * @since 2.0
    float readTemperature() {
      int16_t conversionTime = millisToWaitForConversion(sensors.getResolution());
      wait(conversionTime);
      float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(CHILD_ID_TEMP):sensors.getTempFByIndex(CHILD_ID_TEMP)) * 10.)) / 10.;
      return temperature;
     * Get the millis to wait before reading based on resolution.
     * @since 2.0
    int16_t millisToWaitForConversion(uint8_t bitResolution) {
      switch (bitResolution) {
        case 9:
        return 94;
        case 10:
        return 188;
        case 11:
        return 375;
        default:
        return 750;
     * Send the temperature to controller
     * @since 2.0
    void sendTemperatureToController(float temperature) {
        send(msg_temperature.setSensor(CHILD_ID_TEMP).set(temperature,1));
        digitalWrite(MY_DEFAULT_ERR_LED_PIN , LOW);
        Serial.println("-------------- DEBUG sendTemperatureToController() ---------------");
        Serial.println("No error on send temperature");
      } else {
        // light the error led fixed!
        digitalWrite(MY_DEFAULT_ERR_LED_PIN , HIGH);
        Serial.println("! ERROR sending temperature");
     * Light the LED status
     * @since 2.0
    void lightLedStatus() {
      int k = 0;
      for ( k = 0; k < WAIT_LOOPS; k++) {
        digitalWrite(PIN_LED_STATUS,HIGH);
          wait(10); // 5 * 1000 millisends = 5 seconds;
        digitalWrite(PIN_LED_STATUS,LOW);
          wait(4990);
    /****       VARIOUS FUNCTION TO DEBUG     *****/
     * Test Led status
     * @since 2.0
    void testLed() {
      int k = 16;
      for (k = 16; k<20; k++) {
        pinMode(k,OUTPUT);
        digitalWrite(k,HIGH);
        wait(50);
        digitalWrite(k,LOW);
        wait(50);
    Thank you for your time.
      Do a debug print of the command you received before you enter the "case"
      S 1 Reply Last reply
        sineverba
        @gohan
        I did edit the receive function with this:
          Serial.print("msg_relay.type value is ");
          Serial.println(msg_relay.type);
          Serial.println("------------------------------------------");
          Serial.print("msg_relay.getCommand() value is ");
          Serial.println(msg_relay.getCommand());
        Receive is NOT called at first start ( I have no debug in monitor). Receive is called only when from DOMOTICZ I poweron or poweroff the relay.
        In effect this is the debug monitor:
        request( CHILD_ID_RELAY , V_STATUS) value is 1
        Uplink available!
        Relay in controller is marked as 0
        msg_relay.type value is 2
        msg_relay.getCommand() value is 1
        Last two receive() debug called only when I did poweron or poweroff the relay.
        • B
          B
          Ben Andrewes
          You could try editing out all the ifs etc in the getStateFromController and only request the state (surrounded by a few serial prints to see which bits execute). If it works in simplest form then you could build up the logic around it to see what is failing
            Serial.println(" starting GetStateFromController");
            request( CHILD_ID_RELAY , V_STATUS);
            wait (WAIT_RETURN);
           serial.print("Waiting");
            I still miss the point in asking the status of the relay...
            • B Ben Andrewes
                wait (WAIT_RETURN);
              sineverba
              @Ben-Andrewes request return every time "1". This is not the state of relay in Domoticz . The following state from Domoticz is "0", either if in Domoticz relay need to be on or off ....
                sineverba
                @gohan to mantain them in sync after a power failure.
                But you did put me on right way. I could simply put the relay off on Arduino start and send off to Domoticz.
                Every 5 minutes I could send the corrent state ti Domoticz (Imagine a gateway Power failure instead).
                In this mode I delegate all logic to Domoticz, when the relay need to be on or off....
                  There is the savestate and readstate functions in mysensors in case you need it
                    sineverba
                    @gohan I know, but I would to not use the EEprom and I would also learn and understand where is my error / why cannot get the state... :)
                      I was just trying to point out that it is a design flaw as the nodes should be as much as indipendent as possible from controller but if you want to play around, have fun
                      • S
                        sineverba
                        Ok,
                        I don't know if it is necessary to open a new post.
                        I imagine now it's a problem of Domoticz.
                        I did change all my logic. NOw on startup and every X minutes, the node send to the Domoticz the status of relay, to mantain it in sync.
                        Errrr...... the status is received but not displayed correctly :disappointed_relieved:
                        I attach an image to explain better.
                        Domoticz is last update version, this is the current sketch:
                         * TERMINARE SE UPLINK NON è DISPONIBILE
                         * @version 2.0
                        #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x3B,0xF4,0x61,0xDF,0x1E,0xFF,0xFF,0xFF,0xEC}}}
                         * Include libraries
                         * Define section.
                         *    // NAME
                        #define SKETCH_VERSION    "3.0"
                            //  PIN
                        #define PIN_RELAY         3
                            //  CHILD ID
                            //  RELAY SECTION
                            //  WAITs TIMES
                        #define WAIT_LOOPS        1  // The status led flashes ON 10 ms and OFF 4990 ms == 5000 ms of loop. 5000 * WAIT_LOOPS = number of cycles before new read. 60 == 5 minutes
                        //#define WAIT_RETURN       1500  //  Milliseconds to wait for returns from gateway
                         * One Wire Section
                         * Mysensors message
                         * Before class
                        void before() {
                          sensors.begin();
                         * Presentation.
                          // send sketch name
                          // TEMPERATURE
                          // RELAY
                         * Our Setup
                          // SETUP LED STATUS
                          // SETUP RELAY
                         * Our loop
                          // send the relay state to controller
                          sendRelayStateToController();
                          loopTemperature();
                          lightLedStatus();
                         * Send the state of relay to controller.
                         * @since 3.0
                        void sendRelayStateToController() {
                          Serial.println("-------------- DEBUG sendRelayStateToController() ---------------");
                          bool current_state = digitalRead(PIN_RELAY);
                          if (current_state == 1) {
                            current_state = RELAY_ON;
                          } else {
                            current_state = RELAY_OFF;
                          Serial.print("current_state value is ");
                          Serial.println(current_state);
                          send(msg_relay.set(current_state) , true);
                          Serial.println("------------------------------------------------------------");
                         * Loop temperature.
                         * @since 2.0
                         * Receive function
                         * @since 2.0
                          if ( !message.isAck() ) {
                            if ( message.type == V_STATUS) {
                              if (  message.getCommand() == 1 ) {
                                bool received_state = message.getBool();
                                Serial.print("received_state value is ");
                                Serial.println(received_state);
                                if ( received_state == 1) {
                                  digitalWrite(PIN_RELAY , RELAY_ON);
                                } else {
                         * @since 2.0
                          return temperature;
                         * @since 2.0
                            case 9:
                            return 94;
                            case 10:
                            return 188;
                            case 11:
                            return 375;
                            default:
                            return 750;
                         * @since 2.0
                            //Serial.println("-------------- DEBUG sendTemperatureToController() ---------------");
                            //Serial.println("No error on send temperature");
                            //Serial.println("------------------------------------------------------");
                          } else {
                            //Serial.println("! ERROR sending temperature");
                         * @since 2.0
                          int k = 0;
                              wait(4990);
                          Is displayed opposite or it is not updated?
                            sineverba
                            @gohan Totally not updated. I did upload just now the @boots33 sketch in synch and it works. So it is my fault... But I cannot find!
                            I re-start from fresh (err.. from boots sketch).
