  3. OpenHAB
  4. Door battery status
Door battery status
6 Posts 4 Posters 4.0k Views 4 Watching
    MagnusF
    I started a few months ago with MySensor and openhab and have now configured a node with a door contact. I'm using a serial gateway connected to a RPi with openhab. The node is registered as Door in openhab and works with the door Open / Closed. The node is powered by battery so I want to report battery status but do not know how to get this to openhab. Have searched the forum but have not found anything.
    The Thing Door has in openhab 4 channels:
    Tripped Status, mysensors:door 709db93f:door_3_1:tripped, Contact
    Armed Status, mysensors:door 709db93f:door_3_1:armed, Switch
    Battery Level, mysensors:door 709db93f:door_3_1:battery, Number
    Last Update, mysensors:door 709db93f:door_3_1:lastupdate, DateTime
    All the channels have the same node id (3) and child id (1) so how shall I send the battey value from the sketch to the channel "Battery Level"?
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      @MagnusF said in Door battery status:
      h to the channel
      did You try sendBatteryLevel function ?
      M 1 Reply Last reply
      • rozpruwaczR rozpruwacz
        h to the channel
        MagnusF
        @rozpruwacz Thanks!
        That it could be that simple! :flushed: Did not see the connection between sending the battery status in the sketch and the thing in openhab.
        • MasMatM
          MasMatM
          MasMat
          A little off topic but I'm struggling with a same type of scenario. Didnt want to start a new topic if the answer is here.
          The battery I figured out but I'm having problems with the item (contact) and getting it to my sitemap.
          I have checked both files "Contact" in items and "Text" in sitemap (when I add this line the sitemap doesnt load).
          I will post my code if necessary, but can you tell me if a map is always necessary for door contacts? I have other types of sensors working without problems. Should my arduino send only specific words or boolean to make it work?
          F M 2 Replies Last reply
          • MasMatM MasMat
            F
            F
            fredswed
            @masmat - I am far from an OpenHAB expert but... The sitemap in OpenHAB is only needed to view the status of (or interact with) the item. It is not required for the functionality of an item or thing itself.
            Have you checked your logs to see if there are clues when OpenHAB parses the things/items filed?
            Please start another thread and post your .things, .items, .sitemap files and a log extract there so we can have a look at them.
            • MasMatM MasMat
              MagnusF
              @masmat No it's not necessary to put the "Contact" in a sitemap, your arduino shall send boolean (0/1).
