  3. I have great problem with raspberry and domoticz and mysensors gateway !
42 Posts 6 Posters 12.9k Views 6 Watching
  • tbowmoT tbowmo
    @Reza
    In it's default setup, domoticz writes log files and other data to the SD card all the time, and this can (over time) wear the SD card down, and eventually make it fail!
    F.ex. everytime my domoticz instance receives a message from the MySensors gateway, it writes a log entry, describing which node it received the data from. (I have my log file stored on a ram disk though, so not writing directly to the SD card)
    R
    R
    Reza
    @tbowmo
    now you use a external memory for log ? and have not any problem ?
    can you give me a Training link for setup step by step usb memory for write log ?
    • tbowmoT
      tbowmoT
      tbowmo
      No, I do not use external memory.. I have a ram disk (I take some of the RAM memory of the RPI and converts it into a "disk")
      See this link for more info http://bfy.tw/Dlkf
      R gohanG 2 Replies Last reply
      • tbowmoT tbowmo
        R
        R
        Reza
        @tbowmo you was helper for me always . thank you for this .
        i found this :
        https://www.domoticz.com/wiki/Setting_up_a_RAM_drive_on_Raspberry_Pi
        this is help me for dont happen fail again ?
        again thank you for help
        • tbowmoT
          tbowmoT
          tbowmo
          @Reza
          It will not totally prevent these things of happening, but it might help reduce the risk of it happening again..
          R 1 Reply Last reply
          • tbowmoT tbowmo
            @Reza
            R
            R
            Reza
            @tbowmo thank you again my dear friend.
            • tbowmoT tbowmo
              @tbowmo How big did you make the RAMdisk?
              • tbowmoT
                tbowmoT
                tbowmo
                @gohan
                63Mb. The sd card was made for my old 512Mb RPI B, now it runs on my 1024Mb RPI2, and have been working fine for more than a year.
                • tbowmoT tbowmo
                  @gohan
                  R
                  R
                  Reza
                  wrote on last edited by Reza
                  #28
                  @tbowmo do you know how i can stop domoticz.sh (after i compile source domoticz) for change log...
                  i see this topic. (https://www.domoticz.com/wiki/Moving_Log_and_Temporary_Files_To_a_RAM_Drive)
                  but this is for standard install. i use source and i can not how stop and change and start again....
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Reza
                    I think you can find information here http://bfy.tw/Dn2q
                    • tbowmoT tbowmo
                      @Reza
                      R
                      R
                      Reza
                      @tbowmo i search about this and i test this code before:
                      Start Domoticz
                      sudo service domoticz.sh start
                      Stop Domoticz
                      sudo service domoticz.sh stop
                      Check if Domoticz is running
                      sudo service domoticz.sh status
                      but this is dont work for domoticz that compile from source.
                      this is result:
                      pi@raspberrypi:~ $ sudo service domoticz.sh stop
                      Failed to stop domoticz.service: Unit domoticz.service not loaded.
                      pi@raspberrypi:~ $ sudo service domoticz.sh status
                      ● domoticz.service
                         Loaded: not-found (Reason: No such file or directory)
                         Active: inactive (dead)
                      pi@raspberrypi:~ $
                      for this i had to question from you :(
                      sundberg84S gohanG 2 Replies Last reply
                      • R Reza
                        Start Domoticz
                        Stop Domoticz
                        this is result:
                        ● domoticz.service
                        pi@raspberrypi:~ $
                        #31
                        @Reza you can run ps to see current services running. Maybe its named something else when compiled from source - or its not just running? Did you try to start it before stopping it?
                        • R Reza
                          Start Domoticz
                          Stop Domoticz
                          this is result:
                          ● domoticz.service
                          pi@raspberrypi:~ $
                          @Reza why are you running it from source and not from standard install?
                          • sundberg84S sundberg84
                            R
                            R
                            Reza
                            @sundberg84
                            thank you friend. domoticz now is working for me.but when run ps i dont see domoticz:
                            pi@raspberrypi:~ $ ps
                              PID TTY          TIME CMD
                             1000 pts/0    00:00:00 bash
                             1026 pts/0    00:00:00 Xtightvnc
                             1031 pts/0    00:00:00 xstartup
                             1034 pts/0    00:00:00 lxsession
                             1066 pts/0    00:00:00 dbus-launch
                             1084 pts/0    00:00:00 openbox
                             1086 pts/0    00:00:00 lxpolkit
                             1088 pts/0    00:00:00 lxpanel
                             1090 pts/0    00:00:01 pcmanfm
                             1134 pts/0    00:00:00 start-pulseaudi
                             1135 pts/0    00:00:00 xprop
                             1585 pts/0    00:00:01 Xtightvnc
                             1589 pts/0    00:00:00 xstartup
                             1592 pts/0    00:00:00 lxsession
                             1624 pts/0    00:00:00 dbus-launch
                             1643 pts/0    00:00:00 openbox
                             1645 pts/0    00:00:00 lxpolkit
                             1647 pts/0    00:00:00 lxpanel
                             1649 pts/0    00:00:02 pcmanfm
                             1693 pts/0    00:00:00 start-pulseaudi
                             1694 pts/0    00:00:00 xprop
                             2546 pts/0    00:00:00 ps
                            this is files after compile . and i put "/home/pi/rayan/domoticz" to "rc.local" for up after startup.
                              R
                              R
                              Reza
                              @gohan because i wanted change some things. for example font , theme , icons and etc...
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @Reza
                                Once again, try this link http://bfy.tw/DnCc
                                (Hint.. try looking for answers by using google!)
                                R 2 Replies Last reply
                                • tbowmoT tbowmo
                                  @Reza
                                  R
                                  R
                                  Reza
                                  @tbowmo thank you . i will search about this issue
                                  • tbowmoT tbowmo
                                    @Reza
                                    R
                                    R
                                    Reza
                                    @tbowmo thanks for all guide. i could do it. thank you
                                    My friend just one question . i want know if i choose for example 20mb for ram driver (tmpfs). after full this memory (if i dont clear this), so what happen ? raspberry will be crash ? or not happen and I dont have any new log and report ? or again write on ago log ? thank you for all help
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      I restart domoticz every night, and delete the log file. If you don't do this regularly, the disk will fill up, and domoticz will not be able to write any logs. I don't know what will happen with domoticz in that case
                                      • tbowmoT tbowmo
                                        R
                                        R
                                        Reza
                                        @tbowmo
                                        every night !! :O you do with hand or auto with a program? if you have a program for this can you share this ?
                                        i test with 1mb memory, i see after full , domoticz dont work and have some problem. so we must clear ...
                                        can you help me for build a program for this ? for example when this is 90% memory (tmpfs) so clear this...
                                        • tbowmoT tbowmo
                                          R
                                          R
                                          Reza
                                          #40
                                          @tbowmo i found this script.but becuase i am beginner in script i can not know this.
                                          can we use this for clean tmpfs after 2day each week ? can you edit this for our use exactly ? i build a tmpfs in /var/log . and i move domoticz.log to this folder... now what change i need in this script for clean /var/log every 2 days and how to use this automatic for always when power off/on , reboot and...
                                          thank you for help
                                          #!/bin/bash
                                          # Diskclean-Linux.sh - Remove unused files from /tmp directories
                                          # @author: Crunchify.com
                                          # ------------- Here are Default Configuration --------------------
                                          # CRUNCHIFY_TMP_DIRS - List of directories to search
                                          # DEFAULT_FILE_AGE - # days ago (rounded up) that file was last accessed
                                          # DEFAULT_LINK_AGE - # days ago (rounded up) that symlink was last accessed
                                          # DEFAULT_SOCK_AGE - # days ago (rounded up) that socket was last accessed
                                          CRUNCHIFY_TMP_DIRS="/tmp /var/tmp /usr/src/tmp /mnt/tmp"
                                          DEFAULT_FILE_AGE=+2
                                          DEFAULT_LINK_AGE=+2
                                          DEFAULT_SOCK_AGE=+2
                                          # Make EMPTYFILES true to delete zero-length files
                                          EMPTYFILES=false
                                          #EMPTYFILES=true
                                          cd
                                          /tmp/log "cleantmp.sh[$$] - Begin cleaning tmp directories"
                                          echo ""
                                          echo "delete any tmp files that are more than 2 days old"
                                          /usr/bin/find $CRUNCHIFY_TMP_DIRS                               \
                                               -depth                                                     \
                                               -type f -a -ctime $DEFAULT_FILE_AGE                        \
                                               -print -delete
                                          echo ""
                                          echo "delete any old tmp symlinks"
                                               -depth                                                     \
                                               -type l -a -ctime $DEFAULT_LINK_AGE                        \
                                               -print -delete
                                          echo ""
                                          if /usr/bin/$EMPTYFILES ;
                                          then
                                          echo "delete any empty files"
                                               -depth                                                     \
                                               -type f -a -empty                                          \
                                               -print -delete
                                          fi
                                          echo "Delete any old Unix sockets"
                                               -depth                                                     \
                                               -type s -a -ctime $DEFAULT_SOCK_AGE -a -size 0             \
                                               -print -delete
                                          echo""
                                          echo "delete any empty directories (other than lost+found)"
                                               -depth -mindepth 1                                         \
                                               -type d -a -empty -a ! -name 'lost+found'                  \
                                               -print -delete
                                          echo ""
                                          /usr/bin/logger "cleantmp.sh[$$] - Done cleaning tmp directories"
                                          # send out an email about diskcleanup action
                                          mail -s "Disk cleanup has been performed successfully." you@email.com
                                          echo ""
                                          echo "Diskcleanup Script Successfully Executed"
                                          exit 0
