  2. Feature Requests
  3. OTA preflash validation
4 Posts 2 Posters 2.1k Views 4 Watching
  • B
    B
    bilbolodz
    I think it's a good idea to implement OTA "pre flash" validation. There should a possibility to define some HARDWARE_ID into sketch, modify OTA message to tell node "these new sketch is for XYZ HARDWARE_ID" and add some predefined function (as validate_OTA()) to block flashing if code is NOT for these hardware.
    Accidentally I've flashed node mounted in a field and very well water protected with a wrong HEX. Dissembling module in "the middle of field", cleaning contacts from protecting grease, flashing it and protecting again was VERY painful......
      Testing is always good practice anyway :D
      • B
        B
        bilbolodz
        It WAS tested but "in the middle of night" I've chosen WRONG firmware..... :-(
          Sorry to hear that, but I understand... I've been there too
