  3. Supercap Solar Powered Mysensors nodes as cheap as possible
98 Posts 6 Posters 34.3k Views 8 Watching
    The booster is only from the supercap to the node to keep a steady 3.3v. The solar panel if feeding the buck converter directly so it will start charging when panel is providing around 4,5v. It is a double conversion, I know, but efficiency is not the goal.
      I guess I might have overlooked the backward discharge of the buck converter.... It drained the supercap in 4 hours while it should have lasted 3 days. I need to put a diode in place :sweat_smile:
      0_1508706780475_upload-be076a5d-9be1-4db6-a135-f618726bbc36
        Interesting... The node is still dead... I guess there is big flaw in the setup or the buck converter is dead due to the reverse current flow from supercapacitor
          Schottky diode to the rescue: the buck converter had a 1.5 mA drain. No wonder it didn't last long. After I put a schottky on the input now I get no drain :muscle:
            0_1508947582961_upload-fa827db0-bb57-447e-891c-da5819e0ab6e
            Now voltage stays between 2 and 2.4V (it should be 2.62V but I need to adjust the buck converter and add 0.2V as they are lost though the diode now). I don't understand why the voltage is so unstable now during discharge hours
            NeverDieN 1 Reply Last reply
              NeverDieN
              NeverDieN
              @gohan It suggests your boost converter is mostly failing to boost whatever is in the cap to the target voltage.
                I am measuring the supercap voltage before the booster like it was a 2xAA rechargeable batteries. If you look at previous graphs it was much smoother when the diode was not in place
                • xydixX
                  xydixX
                  xydix
                  Hi guys.
                  Im I wrong if I say that both @gohan and @NeverDie discuss a lot of solar/supercap in multipe threads?
                  Have some of you come to an conclution?
                  Wich supercap is best(good enough)?
                  Wich solarpanel the best?
                  This is very interesting but im an curious what is the optimal setup?
                  • xydixX xydix
                    Hi guys.
                    NeverDieN
                    NeverDieN
                    #29
                    @xydix In what sense do you mean optimal? I think what separates our approaches is that gohan wants to buy readymade parts off aliexpress and, if possible, connect them with dupont wires. So, if that rings true for you, then you will probably find his approach more optimal.
                    xydixX 1 Reply Last reply
                    • NeverDieN NeverDie
                      xydixX
                      xydixX
                      xydix
                      wrote on last edited by xydix
                      #30
                      @NeverDie Doesn't matter for me. I have seen your boards on openhardware for solar panels. Interesting.
                      In many cases an custom PCB get pretty expensive if you just want 1 or 2 board because buy all components required, these are often is selled in 10 pcs or more.
                      In my case, I want something that works, then if i can get away with just an LDO on an protoboard im fine with that.
                      I try to build as cheap nodes as possible.
                      Then if i can find cheap stuff in aliexpress that is doing the job, thats fine.
                      Have you had any good results useing solar panel indoors?
                      • xydixX xydix
                        NeverDieN
                        NeverDieN
                        #31
                        @xydix said in Supercap Solar Powered Mysensors nodes as cheap as possible:
                        Definitely yes. A typical $1 6v solar panel together with an LDO and diode works fine. At least for me. Gohan is exploring something altogether different, and I'd rather not derail his thread. So, if you want more detail, just read the thread I wrote previously.
                          I'll let go until Saturday, then I'll do the voltage adjustment and try to discharge the supercap and see if is is able to recover from that condition. If it doesn't I'll need to find a piece of hardware that will have to hold the booster from switching on until a minimum voltage is reached and also add some dynamic sleep time that increases as the voltage decreases below certain levels
                          • xydixX xydix
                            NeverDieN
                            NeverDieN
                            #33
                            If you want the barest minimum of parts, I've also done it with just a solar panel, a diode, a supercap, and mcu+radio. That's it. Then the trick is to have your mcu monitor the voltage on the supercap. As the voltage approaches the limit, the MCU turns on the radio receiver to burn off extra current, so that the voltage never exceeds the supercap's limit (usually 2.7v). It works.
                            Having said all that, though, I'm interested in what Gohan will come up with. I'm sure his approach will work too. :)
                              The best option I think would be 2 supercaps in series and a balance circuit/overvoltage protection /sab mosfets, this way you only need the solar panel and a diode for charging. The problem still remains when the supercaps eventually drain completely
                                I'm kind of stuck in finding any ready made product for balancing, so I'm looking at the ALD810026 sab mosfet chip and mount it on a 8soic to dip adapter. It's the closest I could get without the need to print out a pcb. What do you think?
                                  NeverDieN
                                  NeverDieN
                                  #36
                                  @gohan said in Supercap Solar Powered Mysensors nodes as cheap as possible:
                                  ALD810026
                                  I haven't tried to do balancing, so you're guess is probably better than mine. The guy with the swiss accent had a circuit for it. Your solution sounds better than his though because his only worked while charging to maximum charge whereas yours maybe balances after-the-fact and/or to less charges as well?
                                    Yes, he used those pcbs from aliexpress that do overvoltage protection, but those are sized for much bigger caps and wouldn't fit much into small boxes. For what I could understand the sab mosfets work while the supercap discharges to keep voltage even across them, so you have to be careful not to apply a higher voltage than the maximum combined of the caps in series. If I could find a way to make a overvoltage protection with some simple components I'd be fine with it.
                                    • NeverDieN
                                      NeverDieN
                                      #38
                                      Not long ago someone (was it you?) posted a link to a youtube video where some guy had a charge balancing circuit that wasted very little power, IIRC. He's probably selling it now. Maybe you could just buy one of those?
                                        exactly, it was me and it was about these sab mosfets
                                          I maybe up to something: I used a MCP1700 ldo and on Vout a diode + a schottky in series to drop the voltage ( could have used just the diode, but the Vout was 2.7x volts so for supercap longevity I added the schottky to have a safe margin) and it is charging even with panel pointed away from the sun. I'll see how it goes tomorrow, but I am pretty happy with the results so far. If it works I think i can't go cheaper then a LDO + 2 diodes :v:
