  3. Supercap Solar Powered Mysensors nodes as cheap as possible
98 Posts 6 Posters 34.3k Views 8 Watching
    It started charging at around 7:30am: it is placed on an eastern wall in vertical position with practically no direct sunlight. It takes a while to stabilize around 2.55V but overall it looks reasonable for the cost of all the power circuit.
    0_1509635630373_upload-5a2288c5-2308-4125-ba3e-6d83cb94fa71
    • NeverDieN
      NeverDieN
      What is the cost? Also, it's not clear to me how much usable charge you're getting.
        1.5€ for solar panel, 1.7€ for 100F supercap, 1€ for booster and some cents for MCP1700, diodes and a small PCB. A fully charged supercap gives 3 days of working time, with send every 10 minutes of temp. hum, TX rssi, RX RSSI, battery voltage and battery percentage
        gohanG NeverDieN 2 Replies Last reply
        • NeverDieN
          NeverDieN
          #44
          Sounds sorta roughly like the kind of circuit used in solar garden lamps, except you've replaced the typical rechargeable battery with a supercap and are boosting to a higher voltage than they typically do. I wonder whether any of them do boost to the same voltage that you're targeting? Perhaps the brighter ones, for example? Those solar garden lights typically have a single, inexpensive integrated circuit that does it all.
            the booster is plugged in the Easy PCB and it is used to power arduino and sensor
            NeverDieN 1 Reply Last reply
              NeverDieN
              NeverDieN
              #46
              @gohan said in Supercap Solar Powered Mysensors nodes as cheap as possible:
              By "plugged in," do you mean like in your earlier photo?
                wrote on last edited by gohan
                #47
                nope, that was the 5.5v supercap version. I mean plugged in in the socket next to the green screw terminal. Of course the buck boost module now it is not used. I have to put the new photo I know.
                • NeverDieN
                  NeverDieN
                  Since you're not posting schematics, maybe it's time for a new photo....
                    I need to learn how to make schematics :sweat_smile:
                      0_1509643234861_upload-e0f0eada-447b-47c3-9d6d-500457d53ed2
                      Does it make sense? The output terminals go to the Easy Pcb green screw terminals .
                        NeverDieN
                        NeverDieN
                        Does it make sense?
                        I suppose. Why the two diodes again instead of just the one?
                          #52
                          Because only one was not dropping enough voltage to have a safe margin, the schottky is giving that extra 0.2v
                          • NeverDieN
                            NeverDieN
                            You'll have a very long charge tail with the diode(s) in that position.
                              Do you mean it will take long time to fully charge?
                                NeverDieN
                                NeverDieN
                                @gohan Yes.
                                  It took about 5 hours to charge and it wasn't in direct sunlight, I'm still happy with the results given I'm using general purpose parts I already had around and no sophisticated charge controllers (and no particular knowledge about electronics :sweat_smile:)
                                    NeverDieN
                                    NeverDieN
                                    @gohan :+1:
                                      0_1509815907001_upload-9b8d0c02-2431-40e8-a5e2-a8116c85246a
                                      Today was overcast all day so it took about 3 hours longer (until 3pm) to fully charge but overall it looks like a nice graph for the last 3 days.
                                        0_1510134605001_upload-fe574220-a002-4e36-bb4f-a895f54f1db9
                                        2 days of rain and it can't charge, luckily it has more than 3 days of running time without charge. Being not in direct sunlight (vertically positioned on a wall just below roof) it has some drawbacks, but today it is catching up
                                        • NeverDieN
                                          NeverDieN
                                          The overcast days are where the two diodes are burning you.
