  3. Fewer home automation postings? What's behind it?
78 Posts 19 Posters 23.2k Views 18 Watching
  • nagelcN
    nagelcN
    nagelc
    I think frustration is probably a factor. Some parts of home automation can be quite difficult.
    Just look at the "safe-in-wall-ac-to-dc-transformers" thread for an example. You really need to understand this to make a safe in wall switch to control your lights. Another difficult area is presence detection. Motion sensors and door switches can only get you so far.
    I suspect many people get past the excitement of building their first sensors and find controlling things more difficult than they want to attempt. Then they end up buying something like a Phillips Hue or giving up all together.
    PS: The first circuit board I designed is a temperature sensor with NRF24 from directions on this site. Now running over 2 years on a set of AA batteries. I feel a little proud of that one every time I see it still reporting it's temperature in Domoticz.
    • nagelcN nagelc
      zboblamontZ
      zboblamontZ
      zboblamont
      @nagelc If there is any frustration leading to folks abandoning DIY in favour of commercial offerings I suggest they would have favoured that route to begin with.
      For somebody starting out on this DIY hobby the learning curve can be daunting, the technicalities and terminology may be comfortable for those with experience, it is easy to forget that the learner is essentially trying to decode hieroglyphics in the dark by dim candlelight, ie even the most basic explanations can prove challenging to begin with.
      The problem for any forum will be the level at which the information is pitched, as it has to accommodate so many levels of expertise...
      • G
        G
        gadgetman
        Rise of cheap zigbee sensors from China is my take. I have a bunch of highly reliable magnetic reed sensors, push buttons, PIR, temp sensors that are smaller and better looking than anything I could make with mysensors. I'm using ms for the more complex and custom applications I have in mind.
          I am also keeping an eye on the xiaomi sensors as in fact they are cheap and better looking than anything you could make on your own. I am still wondering about their reliability and also I don't like a lot the gateway that connects directly to a wall plug.
          G 1 Reply Last reply
            G
            G
            gadgetman
            @gohan I don't use their gateway as it's a bit clunky although it does have local control. Like many I use a Samsung smartthings hub which doesn't cost much more as it's often heavily discounted - pairing with the ST hub can be hit or miss though.
            gohanG 1 Reply Last reply
            • G gadgetman
              NeverDieN
              NeverDieN
              #26
              @gadgetman said in Fewer home automation postings? What's behind it?:
              First I've heard of it. Any links?
              • NeverDieN NeverDie
                G
                G
                gadgetman
                @NeverDie Just do a search on sites like gearbest.com or Banggood.com for Xiaomi smart home. The common sensors go on sale fairly often but they're usually less than $10 a pop.
                • G gadgetman
                  @gadgetman are you saying there is no guarantee to have the xiaomi sensors working on the ST hub?
                    G
                    G
                    gadgetman
                    @gohan Not at all. It's just that the pairing process has a manual element (as opposed to being capable of being auto discovered) to it as it's not officially supported by ST. Community members have developed device drivers for the window, temp, PIR and pushbutton switches. Although I had a few issues trying to settle on the right zigbee frequency (2.4Ghz so susceptible to interference from wifi sources), once that was sorted everything is working great.
                    • G gadgetman
                      NeverDieN
                      NeverDieN
                      @Nca78 Found some inexpensive yet attractive project boxes that you can put your sensors inside. Looks quite nice!
                      https://www.openhardware.io/view/411/BlackCircle-Sensor-High-WAF-TempHum-sensor
                      • scalzS
                        scalzS
                        wrote on last edited by scalz
                        #31
                        I agree with @gadgetman , it's easier&quicker to get started for "HA noobs" or those who don't want to spend too much time in hardware.
                        I thought about trying xia**i devices too. But I have no use, I have enough boards for my needs :grin:
                        That said, i've not been tempted because, and that's important for me:
                        1. I want to fully control my HA, and it's also easier if use 1 or 2 protocols instead of many
                        2. so I can debug inside
                        3. and I don't need to wait for an API update
                        4. and I can also fix a faulty hw as I've fun making my hw. But this is not the most valuable argument here, I agree, regarding such a cheap and simple sensor.
                        1 to 3 : solved by using a great and secure opensource lib... MySensors :)
                        But if i can make my devices looking great with 3d printer and a few tricks to improve look, more features or sensors, smaller, and the final cost not more than twice the price of a xia**i, . I'm happy to forget counting my time lol. But we're getting in connoisseur field I agree
                        • R
                          R
                          robosensor
                          Ikea is also producing zigbee-compatible smart home components (TRÅDFRI series), including led lighting, dimmers, PIRs, ethernet gateways without cloud-based parts (can work w/o internet).
                          Starting from $11-$19 for dimmers/PIRs here in Poland.
                          • alowhumA
                            alowhumA
                            alowhum
                            "From my personal experience, it will be failure and frustration that gets people down. They arrive at this site and it all looks really good.....until you come to try it and then you discover a whole nets of vipers just waiting."
                            I've been thinking that it would be nice to create a spinoff website for MySensors that focuses on ease of use and tried-an-tested solutions. Plug n play.
                            For example, a beautiful site with a few home automation staples, and with the best sensors to use for that scenario, and upload-and-go code. Ideally people wouldn't need to solder anything.
                            Then that site could be used for workshops on DIY, cheap and privacy friendly home automation, for example in libraries.
                            scalzS 1 Reply Last reply
                              Not even all commercial product are tested, plug n play and easy to use. In the build section there are some ready solutions with code and suggested sensors to use.
                              alowhumA 1 Reply Last reply
                                alowhumA
                                alowhumA
                                alowhum
                                @gohan actually, a lot of the examples in the build section are out of date :-( It caused a lot of unnecessary frustration. See this post I made earlier.
                                • alowhumA alowhum
                                  scalzS
                                  scalzS
                                  #36
                                  @alowhum said in Fewer home automation postings? What's behind it?:
                                  that would just be reinventing the wheel, a no end wheel, imho.. Doesn't MySensors website already focus on these goals?
                                  I think that would be better to improve what exists. If there are issues with some sketch, why not fix them?
                                  About the 'whole net of vipers' someone mentioned..
                                  Even if, in the best of world, people wouldn't need to solder anything nor programming, their device for 1buck (soon 'My HA for one buck' or better, 'My House for one buck' lol) I think they will always get some troubles if they don't read, learn etc..
                                  Minimal skills and effort are needed. There are too much different hardware, setup etc to feed support for every case.
                                  What I mean is you could try to build an alternative website for a some usecase, but you won't cover all newbie questions, else you would need to build another mysensors.org :)
                                  But why not, feel free to create a more friendly, bug-free, up-to-date website. In this case you're brave because there is the core team, admins, for this job, which knows well the lib (better for reliable docs and advices), or help us to improve what exists ;)
                                    Developing new code, test it, update the web site and so on are time consuming activities and since MySensors is not a commercial product, there are not people spending the whole days doing all of them so something gets left behind inhevitably
                                    • alowhumA
                                      alowhumA
                                      alowhum
                                      @gohan I actually did all that, but got a lot of pushback.
                                      I created:
                                      • An upgrade to the Dallas temperature sensor to make it non-blocking.
                                        https://forum.mysensors.org/topic/6395/new-non-blocking-temperature-sensor-code
                                      • A new temperature node that uses the BME280, which I think should be the default recommended temperature/humidity/airpressure sensor.
                                        https://forum.mysensors.org/topic/6406/next-generation-temperature-sensor-for-mysensors/9
                                      • A new dust sensor that uses a laser based sensor. This one actually works, is more precise, and allows uses to compare values because the fan is built-in (so everyone has the same fan = same airspeed).
                                        https://forum.mysensors.org/topic/6404/next-generation-dust-sensor-for-mysensors
                                      • A new Co2 sensor
                                        https://forum.mysensors.org/topic/6528/mh-z19-co2-sensor/
                                        Who pushed back?
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          Let's not go into that.
