  3. RFM69 new driver delay
67 Posts 10 Posters 17.7k Views 8 Watching
  • pepsonP pepson
    @gohan
    But how I can download info from gateway and node?
    On github created issue but nothing replay from developers...
    @pepson all core members are helping MySensors when they have free time. Quick replies can happen, but don't count on it. We have as many projects and as little time as you.
    pepsonP 1 Reply Last reply
      pepsonP
      pepsonP
      pepson
      @mfalkvidd
      OK thanks
        mickecarlsson
        wrote on last edited by mickecarlsson
        #23
        I run mysgw 2.30 on a RPi 3 Model B and all nodes on 2.20 with RFM69:
        cat /proc/cpuinfo
        Hardware	: BCM2835
        Revision	: a02082
        I did a git pull then configured:
        ./configure --my-transport=rfm69 --my-is-rfm69hw --my-rfm69-frequency=868
        make
        sudo make install
        Note that I don't use LED's or specify gateway. My Controller is Domoticz
        I then started the gateway with debug (note missing -d) (and the log is from today):
        pi@mysensors-gw:~ $ sudo /usr/local/bin/mysgw
        Jun 21 06:36:58 INFO  Starting gateway...
        Jun 21 06:36:58 INFO  Protocol version - 2.3.0
        Jun 21 06:36:58 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,VER=2.3.0
        Jun 21 06:36:58 DEBUG TSF:LRT:OK
        Jun 21 06:36:58 DEBUG TSM:INIT
        Jun 21 06:36:58 DEBUG TSF:WUR:MS=0
        Jun 21 06:36:58 DEBUG TSM:INIT:TSP OK
        Jun 21 06:36:58 DEBUG TSM:INIT:GW MODE
        Jun 21 06:36:58 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
        Jun 21 06:36:58 DEBUG MCO:REG:NOT NEEDED
        Jun 21 06:36:58 DEBUG Listening for connections on 0.0.0.0:5003
        Jun 21 06:36:58 DEBUG MCO:BGN:STP
        Jun 21 06:36:58 DEBUG MCO:BGN:INIT OK,TSP=1
        Jun 21 06:37:18 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;2;
        Jun 21 06:37:18 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;2;Get Version
        Jun 21 06:37:20 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;18;PING
        Jun 21 06:37:30 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;18;PING
        Jun 21 06:37:37 DEBUG TSF:MSG:READ,22-22-0,s=1,c=1,t=0,pt=7,l=5,sg=0:23.3
        Jun 21 06:37:37 DEBUG TSF:MSG:READ,22-22-0,s=2,c=1,t=1,pt=7,l=5,sg=0:48.0
        After the debug check I pressed ctrl-c and started mysgw as a service
        sudo systemctl start mysgw.service
        System has been running without any hickup since then.
        If you check the commit 2175c993ef81b78527c85649f5bdc3585d2f41b2 you will notice that -d is removed and some other features has been added.
        git log 2175c993ef81b78527c85649f5bdc3585d2f41b2
        Author: Marcelo Aquino <marceloaqno@users.noreply.github.com>
        Date:   Fri Mar 23 07:00:34 2018 -0300
            Linux: Use config file for gateway settings (#1061)
            - The following settings can be use on the config file:
              - verbose=[debug,info,notice,warn,err] - Logging verbosity.
              - log_file[0|1] - Enable logging to a file.
              - log_filepath=(FILE) - Log file path.
              - log_pipe=[0|1] - Enable logging to a named pipe(aka fifo).
                Use this option to view your gateway's log messages from the
                log_pipe_file (defined below).
                To do so, run the following command on another terminal:
                - $ cat "log_pipe_file"
              - log_pipe_file=(FILE)
              - syslog=[0|1] - Enable logging to syslog.
              - eeprom_file=[/etc/mysensors.eeprom]
              - eeprom_size=[1024]
            - Change some mysgw parameters:
              - Added:
                - -q, --quiet:  for quiet mode, disable log messages written to the
                terminal.
              - Removed:
                - -d, --debug: removed, log messages are now enabled by default.
              - Replaced:
                - -b, --background: replaced by --daemon
            - isatty() is no longer used, log messages by default are printed to
              stderr unless the gateway is started with --quiet (#1022)
            - MY_LINUX_CONFIG_FILE: no longer holds the path to the eeprom file,
              but to the configuration file
        My nodes has these definitions (I don't use New Driver):
        #define   MY_SPLASH_SCREEN_DISABLED
        #define   MY_RADIO_RFM69
        #define   MY_IS_RFM69HW
        #define   MY_RFM69_FREQUENCY RFM69_868MHZ
        • M mickecarlsson
          cat /proc/cpuinfo
          Hardware	: BCM2835
          Revision	: a02082
          make
          sudo make install
                - Added:
                  terminal.
                - Removed:
                - Replaced:
          pepsonP
          pepsonP
          pepson
          @mickecarlsson
          Hi
          But you run gateway on 2.3.0 and node on 2.2.0 without NEW DRIVER and it was working ?
          Even though the gateway has a different version and nodes have a different ?
          All people tell that gateway and nodes must have the same version ?
          M 1 Reply Last reply
            There have been versions in the past that were not backward compatible, but usually it is not necessary to have same version on gw and nodes
              pepsonP
              pepsonP
              pepson
              @gohan
              Ok thanks
              • pepsonP pepson
                @mickecarlsson
                Hi
                mickecarlsson
                @pepson
                Yes, I run gateway 2.30 and nodes on 2.20 without new driver. No probems.
                • pepsonP
                  pepsonP
                  pepson
                  Today i installed Gateway on RPI3 with version 2.3.0 but node has 2.2.0 with NEW_DRIVER and still is problem with communication.
                  After come back to home i test it with change version on node to 2.2.0 without NEW_DRIVER.
                  I give you and info...
                  But tell me on what RPI you have run gateway version 2.3.0 ?
                  I have RPI3 version B.
                    mickecarlsson
                    @mickecarlsson said in RFM69 new driver delay:
                    > cat /proc/cpuinfo
                    > Hardware	: BCM2835
                    > Revision	: a02082
                    Type as above and check the last entries, my RPi is revision a02082
                    Se here for more info:
                    Raspberry Pi revision codes
                    • M mickecarlsson
                      > cat /proc/cpuinfo
                      > Hardware	: BCM2835
                      > Revision	: a02082
                      pepsonP
                      pepsonP
                      pepson
                      wrote on last edited by pepson
                      #30
                      @mickecarlsson
                      It is the same hardware and rev.
                      Ok i done test...
                      On Gateway on RPI3 i have installed MySensors 2.3.0
                      On node i installed version 2.2.0
                      One with NEW_DRIVER. Communication with gateway sometimes is ok but still with problem lost communication.
                      Second test installed on node 2.2.0 without NEW_DRIVER and it no working. No communicate with gateway.
                      Not working NODE. Any reaction to control relay.
                      For me only all working when i have MySensors 2.2.0 also on Gateway and also on node with NEW DRIVER option.
                      #define RFM69_868MH
                      #define MY_RFM69_NEW_DRIVER
                      other
                        mickecarlsson
                        What kind of antenna do you have on the RPi for the radio? And what kind of antenna do you have on the node?
                        • M mickecarlsson
                          pepsonP
                          pepsonP
                          pepson
                          @mickecarlsson
                          I have a wire length if I remember 82mm.
                            mickecarlsson
                            Just a hunch, add 4 mm to it so that it is 86 mm instead..
                            And the power supply for the RPi must be able to provide at leat 1.5 A at 5Volt. Dont go for a cheap powersupply, it wont cope with the power drain from the ROi.
                            • M mickecarlsson
                              pepsonP
                              pepsonP
                              pepson
                              @mickecarlsson
                              Hi
                              my bug lenght antenna is 86mm. Sorry.
                              Power for RPI is very good and original raspberry manufacturer provide about 2,5A
                              After my tests only on MySensors 2.2.0 on Gateway and on Nodes 2.2.0 with NEW_DRIVER all works ok.
                              In other like gateway 2.3.0 and node 2.2.0 or 2.3.0 with NEW_DRIVER or without NEW_DRIVER not working correct.
                              • K
                                K
                                kimot
                                This post is deleted!
                                • pepsonP pepson
                                  @mickecarlsson
                                  Hi
                                  pepsonP
                                  pepsonP
                                  pepson
                                  @kimot
                                  I dont must use NEW_DRIVER, but when i write sketch to my node without option NEW_DRIVER, it no working. I tested some combination...mix. Gateway 2.3.0 or 2.2.0 with node 2.2.0 and 2.3.0 and Only with NEW_DRIVER works ok and only on 2.2.0 on node and gateway.
                                  This is my sketch.
                                  //#define MY_RFM69_FREQUENCY RFM69_868MHZ
                                  #define RFM69_868MH
                                  #define MY_REPEATER_FEATURE
                                  //#define MY_RFM69_CSMA_LIMIT_DBM (-85)
                                  // uncomment if we want to manually assign an ID
                                  #define MY_NODE_ID 1
                                  #include <Bounce2.h>
                                  #define BUTTON_UP_PIN 3  // Arduino Digital I/O pin number for up button
                                  #define BUTTON_DOWN_PIN 4  // Arduino Digital I/O pin number for down button
                                  //#define BUTTON_STOP_PIN 5  // Arduino Digital I/O pin number for stop button
                                  //#define RELAY_DIR_PIN 6  // Arduino Digital I/O pin number for direction relay
                                  //#define RELAY_POWER_PIN 7  // Arduino Digital I/O pin number for power relay
                                  #define RELAY_UP_PIN 5
                                  #define RELAY_DOWN_PIN 6
                                  #define RELAY_ON 0
                                  #define RELAY_OFF 1
                                  //#define RELAY_DOWN 1
                                  //#define RELAY_UP 0
                                  #define DIRECTION_DOWN 0
                                  #define DIRECTION_UP 1
                                  #define SKETCH_NAME "Roleta w sypialni"
                                  #define SKETCH_VER "2.2"
                                  #define CHILD_ID_COVER 0   // sensor Id of the sensor child
                                  #define STATE_UP 100 // 100 is open - up
                                  #define STATE_DOWN 0 // 0 is closed - down
                                  //#define CHILD_ID_CALIBRATE 1   // sensor Id of the sensor child to calibrate
                                  #define CHILD_ID_SET 1   // sensor Id of the sensor child to init the roll time
                                  #define PRESENT_MESSAGE "Rolety dla Home Assistant"
                                  const int LEVELS = 100; //the number of levels
                                  float rollTime = 20.0; //the overall rolling time of the shutter
                                  const bool IS_ACK = false; //is to acknowlage
                                  static bool initial_state_sent = false;//for hass we need at list one state send at begining
                                  // debouncing parameters
                                  int value = 0;
                                  int oldValueUp = 0;
                                  int oldValueDown = 0;
                                  int oldValueStop = 0;
                                  //static unsigned long last_interrupt_time_up = 0;
                                  //static unsigned long last_interrupt_time_down = 0;
                                  //static unsigned long debounce_time = 200;
                                  Bounce debouncerUp = Bounce();
                                  Bounce debouncerDown = Bounce();
                                  Bounce debouncerStop = Bounce();
                                  // shutter position parameters
                                  float timeOneLevel = rollTime / LEVELS;
                                  int requestedShutterLevel = 0;
                                  int currentShutterLevel = 0;
                                  unsigned long lastLevelTime = 0;
                                  bool isMoving = false;
                                  int directionUpDown;
                                  bool calibrateDown;
                                  bool calibrateUp;
                                  unsigned long calibrationStartTime;
                                  float calibrationTime = 5.0;
                                  bool calibratedDown;
                                  bool calibratedUp;
                                  enum CoverState {
                                    STOP,
                                    UP, // Window covering. Up.
                                    DOWN, // Window covering. Down.
                                  static int coverState = STOP;
                                  MyMessage msgUp(CHILD_ID_COVER, V_UP);
                                  MyMessage msgDown(CHILD_ID_COVER, V_DOWN);
                                  MyMessage msgStop(CHILD_ID_COVER, V_STOP);
                                  MyMessage msgPercentage(CHILD_ID_COVER, V_PERCENTAGE);
                                  //MyMessage msgCode(CHILD_ID_SET, V_IR_SEND);
                                  void sendState() {
                                    // Send current state and status to gateway.
                                  //  send(msgUp.set(coverState == UP));
                                  //  send(msgDown.set(coverState == DOWN));
                                  //  send(msgStop.set(coverState == STOP));
                                    send(msgPercentage.set(currentShutterLevel));
                                  void shuttersUp(void) {
                                    #ifdef MY_DEBUG
                                    Serial.println("Shutters going up");
                                    if (digitalRead(RELAY_DOWN_PIN) == RELAY_ON) {
                                      digitalWrite(RELAY_DOWN_PIN, RELAY_OFF);
                                      wait(50);
                                    digitalWrite(RELAY_UP_PIN, RELAY_ON);
                                    directionUpDown = DIRECTION_UP;
                                    isMoving = true;
                                    coverState = UP;
                                    sendState();
                                  void shuttersDown(void) {
                                    #ifdef MY_DEBUG
                                    Serial.println("Shutters going down");
                                    if (digitalRead(RELAY_UP_PIN) == RELAY_ON) {
                                      digitalWrite(RELAY_UP_PIN, RELAY_OFF);
                                      wait(50);
                                    digitalWrite(RELAY_DOWN_PIN, RELAY_ON);
                                    directionUpDown = DIRECTION_DOWN;
                                    isMoving = true;
                                    coverState = DOWN;
                                    sendState();
                                  void shuttersHalt(void) {
                                  #ifdef MY_DEBUG
                                    Serial.println("Shutters halted");
                                    isMoving = false;
                                    requestedShutterLevel = currentShutterLevel;
                                  #ifdef MY_DEBUG
                                    Serial.println("saving state to: ");
                                    Serial.println(String(currentShutterLevel));
                                    saveState(CHILD_ID_COVER, currentShutterLevel);
                                    coverState = STOP;
                                    sendState();
                                  void changeShuttersLevel(int level) {
                                    int dir = (level > currentShutterLevel) ? DIRECTION_UP : DIRECTION_DOWN;
                                    if (isMoving && dir != directionUpDown) {
                                      shuttersHalt();
                                    requestedShutterLevel = level;
                                  void initShutters() {
                                  #ifdef MY_DEBUG
                                    Serial.println("Init Cover");
                                    shuttersUp();
                                    wait((rollTime + timeOneLevel * LEVELS) * 1000);
                                    currentShutterLevel = STATE_UP;
                                  #ifdef MY_DEBUG
                                    Serial.println("recieved incomming message");
                                    Serial.println("Recieved message for sensor: ");
                                    Serial.println(String(message.sensor));
                                    Serial.println("Recieved message with type: ");
                                    Serial.println(String(message.type));
                                    if (message.sensor == CHILD_ID_COVER) {
                                      switch (message.type) {
                                        case V_UP:
                                          //Serial.println(", New status: V_UP");
                                          changeShuttersLevel(STATE_UP);
                                          //state = UP;
                                          //sendState();
                                          break;
                                        case V_DOWN:
                                          //Serial.println(", New status: V_DOWN");
                                          changeShuttersLevel(STATE_DOWN);
                                          //state = DOWN;
                                          //sendState();
                                          break;
                                        case V_STOP:
                                          //Serial.println(", New status: V_STOP");
                                          shuttersHalt();
                                          //state = IDLE;
                                          //sendState();
                                          break;
                                        case V_PERCENTAGE:
                                          //Serial.println(", New status: V_PERCENTAGE");
                                          //          if (!initial_state_sent) {
                                          //            #ifdef MY_DEBUG
                                          //            Serial.println("Receiving initial value from controller");
                                          //            #endif
                                          //            initial_state_sent = true;
                                          int per = message.getInt();
                                          if (per > STATE_UP) {
                                            per = STATE_UP;
                                          changeShuttersLevel(per);
                                          //InitShutters(message.getInt());//send value < 0 or > 100 to calibrate
                                          //sendState();
                                          break;
                                  else if (message.sensor ==  CHILD_ID_SET) {
                                      if (message.type == V_VAR1) {
                                        #ifdef MY_DEBUG
                                        Serial.println(", New status: V_VAR1, with payload: ");
                                        String strRollTime = message.getString();
                                        rollTime = strRollTime.toFloat();
                                        #ifdef MY_DEBUG
                                        Serial.println("rolltime value: ");
                                        Serial.println(String(rollTime));
                                        saveState(CHILD_ID_SET, rollTime);
                                  #ifdef MY_DEBUG
                                    Serial.println("exiting incoming message");
                                    return;
                                  void before() {
                                    // Setup the button
                                    pinMode(BUTTON_UP_PIN, INPUT_PULLUP);
                                    // Activate internal pull-up
                                  //  digitalWrite(BUTTON_UP_PIN, HIGH);
                                    //  attachInterrupt(digitalPinToInterrupt(BUTTON_UP_PIN), upButtonPress, FALLING);
                                    pinMode(BUTTON_DOWN_PIN, INPUT_PULLUP);
                                  //  digitalWrite(BUTTON_DOWN_PIN, HIGH);
                                    //  attachInterrupt(digitalPinToInterrupt(BUTTON_DOWN_PIN), downButtonPress, FALLING);
                                  //  pinMode(BUTTON_STOP_PIN, INPUT_PULLUP);
                                  //  digitalWrite(BUTTON_STOP_PIN, HIGH);
                                    debouncerUp.attach(BUTTON_UP_PIN);
                                    debouncerUp.interval(5);
                                    debouncerDown.attach(BUTTON_DOWN_PIN);
                                    debouncerDown.interval(5);
                                  //  debouncerStop.attach(BUTTON_STOP_PIN);
                                  //  debouncerStop.interval(5);
                                    pinMode(RELAY_UP_PIN, OUTPUT);
                                    pinMode(RELAY_DOWN_PIN, OUTPUT);
                                  void presentation() {
                                    sendSketchInfo(SKETCH_NAME, SKETCH_VER);
                                    present(CHILD_ID_COVER, S_COVER, PRESENT_MESSAGE, IS_ACK);
                                    // present(CHILD_ID_SET, S_CUSTOM);
                                  void setup(void) {
                                    //set up roll time if the saved value is not 255
                                    #ifdef MY_DEBUG
                                    Serial.println("getting rolltime from eeprom: ");
                                    float tmpRollTime = loadState(CHILD_ID_SET);
                                    if (tmpRollTime != 0xff) {
                                      rollTime = tmpRollTime;
                                    #ifdef MY_DEBUG
                                    int state = loadState(CHILD_ID_COVER);
                                    #ifdef MY_DEBUG
                                    Serial.println("getting state from eeprom: ");
                                    Serial.println(String(state));
                                  //  if (state == 0xff) {
                                  //    initShutters();
                                  //  } else {
                                      currentShutterLevel = state;
                                      requestedShutterLevel = state;
                                  void loop(void) {
                                  #ifdef MY_DEBUG
                                      sendState();
                                     // send(msgCode.set('20.0'));
                                      //    #ifdef MY_DEBUG
                                      //    Serial.println("Requesting initial value from controller");
                                      //    #endif
                                      //    request(CHILD_ID_COVER, V_PERCENTAGE);
                                      //    wait(2000, C_SET, V_PERCENTAGE);
                                    debouncerUp.update();
                                    value = debouncerUp.read();
                                    if (value == 0 && value != oldValueUp) {
                                      if(isMoving){
                                        shuttersHalt();
                                      else{
                                      calibrateUp = false;
                                      calibratedUp = false;
                                      //state = UP;
                                      //sendState();
                                    oldValueUp = value;
                                    debouncerDown.update();
                                    value = debouncerDown.read();
                                    if (value == 0 && value != oldValueDown) {
                                      if(isMoving){
                                        shuttersHalt();
                                      else{
                                      calibrateDown = false;
                                      calibratedDown = false;
                                      //state = DOWN;
                                      //sendState();
                                    oldValueDown = value;
                                  /*  debouncerStop.update();
                                    value = debouncerStop.read();
                                    if (value == 0 && value != oldValueStop) {
                                      shuttersHalt();
                                      //state = IDLE;
                                      //sendState();
                                    oldValueStop = value;
                                    if(currentShutterLevel != 100)
                                    if(currentShutterLevel != 0)
                                    if (isMoving)
                                      unsigned long _now = millis();
                                      if (_now - lastLevelTime >= timeOneLevel * 1000) {
                                        if (directionUpDown == DIRECTION_UP) {
                                          currentShutterLevel += 1;
                                        } else {
                                          currentShutterLevel -= 1;
                                        currentShutterLevel = constrain(currentShutterLevel, 0, 100);
                                        #ifdef MY_DEBUG
                                        Serial.println(String(requestedShutterLevel));
                                        lastLevelTime = millis();
                                      if (currentShutterLevel == requestedShutterLevel)
                                        if(currentShutterLevel == 0 && !calibratedDown)
                                          if(calibrateDown == false)
                                            calibrateDown = true;
                                            calibrationStartTime = _now;
                                          else
                                            if(calibratedDown == false)
                                              if (_now - calibrationStartTime >= calibrationTime * 1000)
                                               calibratedDown = true;
                                        else if (currentShutterLevel == 100 && !calibratedUp)
                                          if(calibrateUp == false)
                                            calibrateUp = true;
                                          else
                                            if(calibratedUp == false)
                                               calibratedUp = true;
                                        else
                                          shuttersHalt();
                                    else
                                      if (requestedShutterLevel != currentShutterLevel)
                                        if (requestedShutterLevel > currentShutterLevel) {
                                          shuttersUp();
                                        else {
                                          shuttersDown();
                                  • pepsonP pepson
                                    @kimot
                                    This is my sketch.
                                    #define RFM69_868MH
                                    #define RELAY_ON 0
                                    #define RELAY_OFF 1
                                    int value = 0;
                                    int oldValueUp = 0;
                                    bool calibrateDown;
                                    bool calibrateUp;
                                    bool calibratedUp;
                                    enum CoverState {
                                      STOP,
                                    void sendState() {
                                      #ifdef MY_DEBUG
                                        wait(50);
                                      isMoving = true;
                                      coverState = UP;
                                      sendState();
                                      #ifdef MY_DEBUG
                                        wait(50);
                                      isMoving = true;
                                      coverState = DOWN;
                                      sendState();
                                    #ifdef MY_DEBUG
                                      isMoving = false;
                                    #ifdef MY_DEBUG
                                      coverState = STOP;
                                      sendState();
                                        shuttersHalt();
                                    #ifdef MY_DEBUG
                                      shuttersUp();
                                    #ifdef MY_DEBUG
                                          case V_UP:
                                            //state = UP;
                                            //sendState();
                                            break;
                                          case V_DOWN:
                                            //state = DOWN;
                                            //sendState();
                                            break;
                                          case V_STOP:
                                            shuttersHalt();
                                            //state = IDLE;
                                            //sendState();
                                            break;
                                          case V_PERCENTAGE:
                                            //            #ifdef MY_DEBUG
                                            //            #endif
                                              per = STATE_UP;
                                            //sendState();
                                            break;
                                          #ifdef MY_DEBUG
                                          #ifdef MY_DEBUG
                                    #ifdef MY_DEBUG
                                      return;
                                    void before() {
                                      // Setup the button
                                    void setup(void) {
                                      #ifdef MY_DEBUG
                                      #ifdef MY_DEBUG
                                      #ifdef MY_DEBUG
                                    //    initShutters();
                                    //  } else {
                                    void loop(void) {
                                    #ifdef MY_DEBUG
                                        sendState();
                                        //    #ifdef MY_DEBUG
                                        //    #endif
                                        if(isMoving){
                                          shuttersHalt();
                                        else{
                                        //state = UP;
                                        //sendState();
                                      oldValueUp = value;
                                        if(isMoving){
                                          shuttersHalt();
                                        else{
                                        //state = DOWN;
                                        //sendState();
                                        shuttersHalt();
                                        //state = IDLE;
                                        //sendState();
                                      if (isMoving)
                                          } else {
                                          #ifdef MY_DEBUG
                                            else
                                              calibrateUp = true;
                                            else
                                          else
                                            shuttersHalt();
                                      else
                                            shuttersUp();
                                          else {
                                            shuttersDown();
                                    pepsonP
                                    pepsonP
                                    pepson
                                    And is any chance to run gateway on RPI3 but on old default driver not with NEW DRIVER ?
                                    Anybody has any solution for my problem with communication on version 2.3.0 ?
                                      mickecarlsson
                                      #38
                                      I just checked all my nodes:
                                      1. Garage - measures temperature/humidity and power usage - uses NEW_DRIVER, Arduino UNO, powered all times.
                                      2. Storage - measures temperature/humidity and power usage - uses NEW_DRIVER, Arduino UNO powered all times.
                                      3. Greenhouse - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
                                      4. Patio - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
                                      5. Bedroom - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
                                      6. Kitchen area - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
                                      My nodes are within 40 meters from the gateway.
                                      I will no reprogram the node 4 and 5 to use the new driver to see if that makes any difference.
                                      Node 1 and 2 are the nodes farthest away from the gateway, there is one brick wall and three wood walls between the node and the gateway.
                                      • M mickecarlsson
                                        pepsonP
                                        pepsonP
                                        pepson
                                        #39
                                        @mickecarlsson
                                        Please also for all points give info what version MySensors use and if you can upload your sketches for all point.
                                        And Gateway has on RPI3 with version 2.3.0 ? By Serial or ethernet ? And tell me with what controller you use it ? I use with Home Assistant.
                                        And BTW tell me how long Arduino Mini Pro work for you on battery and what battery you use ... and show your project... Did you remove LED from Arduino to save power battery ?
                                        In Sketch you measure % power from battery ? And send to controller ? What controller you use ?
                                        • scalzS
                                          scalzS
                                          wrote on last edited by scalz
                                          #40
                                          @pepson @mickecarlsson
                                          in theory, if I remember well, length of antenna should be:
                                          • 86mm for 868mhz
                                          • 82mm for 915Mhz
                                            Better check which frequency you can use where you live.
                                          Also this is in ideal world, it depends on:
                                          • antenna material
                                          • gnd plane size
                                          • etc
                                          So when you want to tune your network, you could use a good, 868mhz for example, antenna on gateway (from a reliable supplier, as there are also a lot of unmatched antenna around).
                                          Then you can try to tune emprically, by checking rssi vs length. Add length or cut, and check. If you need more or less length is dependant on above factors.
                                          As already said, we don't recommand mixing new driver with older.. As packet has not the same format.
                                          No eta for fixing rfm69 if issues, too busy for the moment, but we'll try asap.
