  3. RFM69 new driver delay
67 Posts 10 Posters 17.7k Views 8 Watching
  • scalzS scalz
    @pepson @mickecarlsson
    in theory, if I remember well, length of antenna should be:
    • 86mm for 868mhz
    • 82mm for 915Mhz
      Better check which frequency you can use where you live.
    Also this is in ideal world, it depends on:
    • antenna material
    • gnd plane size
    • etc
    So when you want to tune your network, you could use a good, 868mhz for example, antenna on gateway (from a reliable supplier, as there are also a lot of unmatched antenna around).
    Then you can try to tune emprically, by checking rssi vs length. Add length or cut, and check. If you need more or less length is dependant on above factors.
    As already said, we don't recommand mixing new driver with older.. As packet has not the same format.
    No eta for fixing rfm69 if issues, too busy for the moment, but we'll try asap.
    pepsonP
    pepsonP
    pepson
    @scalz said in RFM69 new driver delay:
    Yes i have for my radio anntena 86mm.
    On nodes and gateway i am sure that i use freq 868MHz.
    Look on my command to build gateway and on my sketches node.
    On version 2.2.0 i use gateway (as people write by my command i use NEW DRIVER) and also on node also use NEW DRIVER and in this solution all works perfect with no problem.
    When i update gateway and node to 2.3.0 also with NEW DRIVER i have a problem that controll node and connection is no stabilish. In my Home Assistant sometimes i can controll relay but sometimes no reaction on click by Home Assistant. When use on node old driver (but on gateway NEW DRIVER) it is no working. Only on version 2.2.0 on gatewy and node all works perfect.
    Is any chance to build gateway on RPI3 with old driver to RFM69HW ? Because as people write in default building on gateway on RPI3 use NEW DRIVER and we can not change it.... It is true ?
    • scalzS
      scalzS
      wrote on last edited by scalz
      #42
      @pepson
      My comments about tuning antenna were general, it can be useful for optimizing your network.
      I already read what you said previously ;) It should be normal that new&old driver not working together (unless a recent change..).
      We'll take a look at which changes are incorrect. I'm using experimental local mysensors version, so I'm a bit off topic regarding official release and no time for debugging, for the moment, as like I said we'll try to check that asap.
      Regarding RPI, I'm not using it as gw (I prefer a lower power gw that i can place where i want) so I'm not sure. Take it with a pinch of salt but if i remember, old rfm69 driver spi functions etc are not adapted to linux (whereas new driver is)
      If 2.3 is blocking, do you need a particular fix in 2.3 ? Else you could stick to 2.2
        mickecarlsson
        wrote on last edited by mickecarlsson
        #43
        OK,
        Here goes what I have:
        Arduino Pro Mini, chinese clones. Regulator and led removed. Soldered on EasyPCB rev 9.
        Radio is RFM69 868 MHz with helicoil antenna on the nodes, 86 mm antenna on the Gateway
        Bootloader is from https://github.com/MCUdude/MiniCore
        The bootloader settings are:
        Board: ATmega328
        Bootloader: Yes
        Variant: 328P / 328PA
        BOD: 1.8v
        Clock: 1MHz internal
        Compiler LTO: Disabled (default)
        On the EasyPCB I have only soldered the radio, the antenna and the Arduino. No booster, no capacitors, no resistors.
        I have put a link on the REG and run the node on two AA batteries.
        The nodes only have one sensor, the BME280.
        The controller I use is Domoticz, latest version (I think).
        I have now reprogrammed some of the nodes to 2.30 and I use NEW_DRIVER.
        Gateway - 2.3.0
        Patio - 2.3.0
        Test-node - 2.3.0
        Kitchen - 2.3.0
        Bedroom - 2.3.0
        UV and LUX - 2.3.0
        No problems at all.
        However, I do not use the receive() function on my nodes.
        And I see that you use the REPEATER setting, if your node can reach the gateway the disable repeater.
        pepsonP 1 Reply Last reply
        • M mickecarlsson
          OK,
          Board: ATmega328
          Bootloader: Yes
          BOD: 1.8v
          Gateway - 2.3.0
          Patio - 2.3.0
          Test-node - 2.3.0
          Kitchen - 2.3.0
          Bedroom - 2.3.0
          UV and LUX - 2.3.0
          No problems at all.
          pepsonP
          pepsonP
          pepson
          wrote on last edited by pepson
          #44
          @mickecarlsson
          Tell me for what you change bootloader ? And i also have clone chine arduino pro mini... I also must change bootloader on this Arduino Pro Mini CLONE CHINA ? Because i dont change bootloader after buy...
          And if you can show also your antenna...and where you buy this antenna ? I try found on Aliexpres but not found.
          But i can not use REPEATER function to to increase the range from the gate - something like the MESH network ?
          And is any chance to you test my SKETCH with relay on your arduino ?
            mickecarlsson
            You don't ned to change bootloader, I do because I run on battery and it fits my need.
            I can't test your sketch as I don't have the necessary hardware to test it.
            How far apart are your nodes?
            My antenna is from AliExpress
            • M mickecarlsson
              pepsonP
              pepsonP
              pepson
              #46
              @mickecarlsson
              Now my node is very near my Gateway about 6meters. Because now i project my automation in my new home.
              But if you only have Arduino Pro Mini with Radio RFM69HW you can test my sketch. I think that you dont need 2xrelay to test it... Please...
              But for what is function REPEATER ? To increase range from Gateway to very far node ? Then the node with the repeater function extends the range?
              When come back to home i try build node without option REPEATER and try run this...
              Also can you give on priv info how upload this bootloader ? I can only write by ArduinoIDE or i must do other actions ?
                mickecarlsson
                You only need repeater fi you have a node far away that can’t reach the gateway, then you add repeater on a node nearer the gateway.
                See here: MySensors Network
                And if the node has repeater defined it must allways have power and no Sleep.
                Sorry, I can’t test the sketch.
                pepsonP 3 Replies Last reply
                • M mickecarlsson
                  pepsonP
                  pepsonP
                  pepson
                  #48
                  @mickecarlsson
                  Can you share me your all sketches ? Thanks
                  And tell me how you have connected Gateway to RPI3? By ethernet or by serial ? Because i see in your building Gateway that you dont use parameter ETHERNET on port 5003
                  And anybody has any contact to developer @tekka007 ?
                  This is info what show in debug on version 2.3.0 gateway and also node on version 2.3.0
                  pi@hassbian:~/MySensors $ sudo /usr/local/bin/mysgw
                  Jun 22 17:22:49 INFO  Starting gateway...
                  Jun 22 17:22:49 INFO  Protocol version - 2.3.0
                  Jun 22 17:22:49 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,VER=2.3.0
                  Jun 22 17:22:49 DEBUG TSF:LRT:OK
                  Jun 22 17:22:49 DEBUG TSM:INIT
                  Jun 22 17:22:49 DEBUG TSF:WUR:MS=0
                  Jun 22 17:22:49 DEBUG TSM:INIT:TSP OK
                  Jun 22 17:22:49 DEBUG TSM:INIT:GW MODE
                  Jun 22 17:22:49 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                  Jun 22 17:22:49 DEBUG MCO:REG:NOT NEEDED
                  Jun 22 17:22:49 DEBUG Listening for connections on 0.0.0.0:5003
                  Jun 22 17:22:49 DEBUG MCO:BGN:STP
                  Jun 22 17:22:49 DEBUG MCO:BGN:INIT OK,TSP=1
                  Jun 22 17:22:54 DEBUG TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  Jun 22 17:22:54 DEBUG TSF:MSG:BC
                  Jun 22 17:22:54 DEBUG TSF:MSG:FPAR REQ,ID=2
                  Jun 22 17:22:54 DEBUG TSF:CKU:OK,FCTRL
                  Jun 22 17:22:54 DEBUG TSF:MSG:GWL OK
                  Jun 22 17:22:54 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=O                 K:0
                  Jun 22 17:22:56 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  Jun 22 17:22:56 DEBUG TSF:MSG:PINGED,ID=2,HP=1
                  Jun 22 17:22:57 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=                 OK:1
                  Jun 22 17:22:57 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  Jun 22 17:22:58 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=                 OK:0100
                  Jun 22 17:22:59 DEBUG TSF:MSG:READ,2-2-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                  Jun 22 17:23:00 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  Jun 22 17:23:03 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=25,sg=0:1xRelay &                  Button-Sypialni
                  Jun 22 17:23:03 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=5,sg=0:2.2.0
                  Jun 22 17:23:04 DEBUG TSF:MSG:READ,2-2-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
                  Jun 22 17:23:05 DEBUG TSF:MSG:READ,2-2-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
                  Jun 22 17:23:05 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  Jun 22 17:23:06 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  Jun 22 17:23:07 DEBUG TSF:MSG:READ,2-2-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
                  Jun 22 17:23:08 DEBUG TSF:MSG:READ,2-2-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
                  Jun 22 17:23:08 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
                  Jun 22 17:23:09 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
                  M 1 Reply Last reply
                  • M mickecarlsson
                    pepsonP
                    pepsonP
                    pepson
                    @mickecarlsson I done next test.
                    Updated my Gateway on RPI3 to 2.3.0
                    Then also update my nodes to 2.3.0
                    One node which i use is to control Switch Relay. It works ok also with Repeater function and also without Repeater function.
                    Second node is to control cover by relay. It no working correct also with Reapeater and also without Repeater function. Status is not update in the same time. Sometimes no respod reaction on click button.
                    Below i see SWITCH releay SKETCH and also to Cover.
                    Please help me.
                    Also i need help to convert this sketch for Switch 1xRelay to Switch 2x Releay. ANybody can help me. ?
                       Relay with button sketch
                       modified to work with no uplink
                       to gateway and try to maintain sync to controller
                    #define MY_DEBUG                               // Enable debug prints to serial monitor
                    #define MY_RADIO_RFM69
                    #define MY_IS_RFM69HW
                    #define RFM69_868MH
                    #define MY_RFM69_NEW_DRIVER
                    // uncomment if we want to manually assign an ID
                    #define MY_NODE_ID 2                       // Node id defaults to AUTO (tries to fetch id from controller)
                    #define MY_TRANSPORT_WAIT_READY_MS 5000        //set how long to wait for transport ready in milliseconds
                    #define MY_REPEATER_FEATURE                    // Enabled repeater feature for this node
                    #include <Bounce2.h>
                    #define RELAY_PIN  5      // Arduino Digital I/O pin number for relay
                    #define BUTTON_PIN  3     // Arduino Digital I/O pin number for button
                    #define CHILD_ID 1        // Id of the sensor child
                    #define RELAY_ON 0
                    #define RELAY_OFF 1
                    Bounce debouncer = Bounce();
                    int oldValue = 0;
                    bool uplinkAvailable = true;
                    bool state = false;
                    bool requestState;
                    bool firstStart = true;
                    unsigned long uplinkCheckTime ;                // holder for uplink checks
                    unsigned long uplinkCheckPeriod = 30*1000;     // time between checks for uplink in milliseconds
                    unsigned long returnWait = 1000;               // how long to wait for return from controller in milliseconds.. adjust as needed
                    unsigned long oldTime = 0;
                    unsigned long newTime = 0;
                    MyMessage msg(CHILD_ID, V_STATUS);
                    void setup(){
                      pinMode(BUTTON_PIN, INPUT_PULLUP);           // Setup the button pin, Activate internal pull-up
                      debouncer.attach(BUTTON_PIN);                // After setting up the button, setup debouncer
                      debouncer.interval(5);
                      pinMode(RELAY_PIN, OUTPUT);                 // set relay pin in output mode
                      digitalWrite(RELAY_PIN, RELAY_OFF);         // Make sure relay is off when starting up
                      send(msg.set(RELAY_OFF), false);           // notify controller to show off state
                    void presentation()  {
                      sendSketchInfo("1xRelay & Button-Sypialnia", "2.2.0");
                      present(CHILD_ID, S_BINARY);
                    void loop(){
                      if (firstStart) {                            // this code is only run once at startup
                        Serial.println("First run started");
                        requestTime();                             // get time from controller
                        wait (returnWait);                         // delay to allow time to return
                        if (oldTime == 0){                         // check to see if there was a return from the time request
                          Serial.println("uplink not available");
                          uplinkAvailable = false;                 // no uplink established
                          uplinkCheckTime = millis();
                         else{
                          Serial.println("uplink available");
                          request( CHILD_ID, V_STATUS);            // get status of switch on controller
                          wait (returnWait);                       //wait needed to allow request to return from controller
                          Serial.print("controller state --- ");
                          Serial.println(requestState);
                          if (requestState != state) {             // check that controller is corectly showing the current relay state
                            send(msg.set(state), false);           // notify controller of current state
                      firstStart = false;                                          // set firstStart flag false to prevent code from running again
                      debouncer.update();
                      int value = debouncer.read();                               // Get the update value
                      if (value != oldValue && value == 0) {                      // check for new button push
                        state =  !state;                                          // Toggle the state
                        digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);    // switch the relay to the new state
                        requestTime();
                        if (oldTime != newTime){                                  // if times are different then uplink is available
                          oldTime = newTime;
                        else{                                                    // if times are the same no uplink is available
                          uplinkAvailable = false;                                // no uplink available, set flag false
                          uplinkCheckTime = millis();                             // start the timer from now
                      oldValue = value;
                      if (!uplinkAvailable && (millis() - uplinkCheckTime > uplinkCheckPeriod) ) {       // test to see if function should be called
                        uplinkCheck();        // call uplink checking function
                    /*-------------------start of functions--------------------------*/
                      if (message.type == V_STATUS) {                                   // check to see if incoming message is for a switch
                        switch (message.getCommand()) {                                 // message.getCommand will give us the command type of the incomming message
                          case C_SET:                                                   //message is a set command  from controller to update relay state
                            state = message.getBool();                                  // get the new state
                            digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);      // switch relay to new state
                            send(msg.set(state));
                            uplinkAvailable = true;                                     //  uplink established
                            /*---- Write some debug info----*/
                            Serial.print(message.sensor);
                            break;
                          case C_REQ:                                               // message is a returning request from controller
                            requestState = message.getBool();                       // update requestState with returning state
                            break;
                    void uplinkCheck() {
                        requestTime();
                        wait (returnWait);                       // wait for time return.. this may need to be varied for your system
                         Serial.println("uplink re-established");
                          send(msg.set(state), false);            // notify controller of current state no ack
                          oldTime = newTime;
                      uplinkCheckTime = millis();                // reset the checktime
                      Serial.println("uplinkchecktime reset");
                    void receiveTime(unsigned long time)
                      if (firstStart){
                        oldTime = time;
                        newTime = time;
                      else{
                      newTime = time;
                      Serial.print("time received---- " );
                      Serial.println(time);
                    • pepsonP pepson
                      Please help me.
                      #define RFM69_868MH
                      #define RELAY_ON 0
                      #define RELAY_OFF 1
                      int oldValue = 0;
                      bool state = false;
                      bool requestState;
                      void setup(){
                      void loop(){
                           else{
                        debouncer.update();
                          requestTime();
                            oldTime = newTime;
                        oldValue = value;
                              break;
                              break;
                          requestTime();
                            oldTime = newTime;
                        if (firstStart){
                          oldTime = time;
                          newTime = time;
                        else{
                        newTime = time;
                      pepsonP
                      pepsonP
                      pepson
                      //#define MY_RFM69_FREQUENCY RFM69_868MHZ
                      #define RFM69_868MH
                      // #define MY_REPEATER_FEATURE
                      //#define MY_RFM69_CSMA_LIMIT_DBM (-85)
                      #define MY_NODE_ID 1
                      #define BUTTON_UP_PIN 3  // Arduino Digital I/O pin number for up button
                      #define BUTTON_DOWN_PIN 4  // Arduino Digital I/O pin number for down button
                      //#define BUTTON_STOP_PIN 5  // Arduino Digital I/O pin number for stop button
                      //#define RELAY_DIR_PIN 6  // Arduino Digital I/O pin number for direction relay
                      //#define RELAY_POWER_PIN 7  // Arduino Digital I/O pin number for power relay
                      #define RELAY_UP_PIN 5
                      #define RELAY_DOWN_PIN 6
                      #define RELAY_ON 0
                      #define RELAY_OFF 1
                      //#define RELAY_DOWN 1
                      //#define RELAY_UP 0
                      #define DIRECTION_DOWN 0
                      #define DIRECTION_UP 1
                      #define SKETCH_NAME "Roleta w sypialni"
                      #define SKETCH_VER "2.3"
                      #define CHILD_ID_COVER 0   // sensor Id of the sensor child
                      #define STATE_UP 100 // 100 is open - up
                      #define STATE_DOWN 0 // 0 is closed - down
                      //#define CHILD_ID_CALIBRATE 1   // sensor Id of the sensor child to calibrate
                      #define CHILD_ID_SET 1   // sensor Id of the sensor child to init the roll time
                      #define PRESENT_MESSAGE "Rolety dla Home Assistant"
                      const int LEVELS = 100; //the number of levels
                      float rollTime = 20.0; //the overall rolling time of the shutter
                      const bool IS_ACK = false; //is to acknowlage
                      static bool initial_state_sent = false;//for hass we need at list one state send at begining
                      // debouncing parameters
                      int value = 0;
                      int oldValueUp = 0;
                      int oldValueDown = 0;
                      int oldValueStop = 0;
                      //static unsigned long last_interrupt_time_up = 0;
                      //static unsigned long last_interrupt_time_down = 0;
                      //static unsigned long debounce_time = 200;
                      Bounce debouncerUp = Bounce();
                      Bounce debouncerDown = Bounce();
                      Bounce debouncerStop = Bounce();
                      // shutter position parameters
                      float timeOneLevel = rollTime / LEVELS;
                      int requestedShutterLevel = 0;
                      int currentShutterLevel = 0;
                      unsigned long lastLevelTime = 0;
                      bool isMoving = false;
                      int directionUpDown;
                      bool calibrateDown;
                      bool calibrateUp;
                      unsigned long calibrationStartTime;
                      float calibrationTime = 5.0;
                      bool calibratedDown;
                      bool calibratedUp;
                      enum CoverState {
                        STOP,
                        UP, // Window covering. Up.
                        DOWN, // Window covering. Down.
                      static int coverState = STOP;
                      MyMessage msgUp(CHILD_ID_COVER, V_UP);
                      MyMessage msgDown(CHILD_ID_COVER, V_DOWN);
                      MyMessage msgStop(CHILD_ID_COVER, V_STOP);
                      MyMessage msgPercentage(CHILD_ID_COVER, V_PERCENTAGE);
                      //MyMessage msgCode(CHILD_ID_SET, V_IR_SEND);
                      void sendState() {
                        // Send current state and status to gateway.
                      //  send(msgUp.set(coverState == UP));
                      //  send(msgDown.set(coverState == DOWN));
                      //  send(msgStop.set(coverState == STOP));
                        send(msgPercentage.set(currentShutterLevel));
                      void shuttersUp(void) {
                        #ifdef MY_DEBUG
                        Serial.println("Shutters going up");
                        if (digitalRead(RELAY_DOWN_PIN) == RELAY_ON) {
                          digitalWrite(RELAY_DOWN_PIN, RELAY_OFF);
                          wait(50);
                        digitalWrite(RELAY_UP_PIN, RELAY_ON);
                        directionUpDown = DIRECTION_UP;
                        isMoving = true;
                        coverState = UP;
                        sendState();
                      void shuttersDown(void) {
                        #ifdef MY_DEBUG
                        Serial.println("Shutters going down");
                        if (digitalRead(RELAY_UP_PIN) == RELAY_ON) {
                          digitalWrite(RELAY_UP_PIN, RELAY_OFF);
                          wait(50);
                        digitalWrite(RELAY_DOWN_PIN, RELAY_ON);
                        directionUpDown = DIRECTION_DOWN;
                        isMoving = true;
                        coverState = DOWN;
                        sendState();
                      void shuttersHalt(void) {
                      #ifdef MY_DEBUG
                        Serial.println("Shutters halted");
                        isMoving = false;
                        requestedShutterLevel = currentShutterLevel;
                      #ifdef MY_DEBUG
                        Serial.println("saving state to: ");
                        Serial.println(String(currentShutterLevel));
                        saveState(CHILD_ID_COVER, currentShutterLevel);
                        coverState = STOP;
                        sendState();
                      void changeShuttersLevel(int level) {
                        int dir = (level > currentShutterLevel) ? DIRECTION_UP : DIRECTION_DOWN;
                        if (isMoving && dir != directionUpDown) {
                          shuttersHalt();
                        requestedShutterLevel = level;
                      void initShutters() {
                      #ifdef MY_DEBUG
                        Serial.println("Init Cover");
                        shuttersUp();
                        wait((rollTime + timeOneLevel * LEVELS) * 1000);
                        currentShutterLevel = STATE_UP;
                      #ifdef MY_DEBUG
                        Serial.println("recieved incomming message");
                        Serial.println("Recieved message for sensor: ");
                        Serial.println(String(message.sensor));
                        Serial.println("Recieved message with type: ");
                        Serial.println(String(message.type));
                        if (message.sensor == CHILD_ID_COVER) {
                          switch (message.type) {
                            case V_UP:
                              //Serial.println(", New status: V_UP");
                              changeShuttersLevel(STATE_UP);
                              //state = UP;
                              //sendState();
                              break;
                            case V_DOWN:
                              //Serial.println(", New status: V_DOWN");
                              changeShuttersLevel(STATE_DOWN);
                              //state = DOWN;
                              //sendState();
                              break;
                            case V_STOP:
                              //Serial.println(", New status: V_STOP");
                              shuttersHalt();
                              //state = IDLE;
                              //sendState();
                              break;
                            case V_PERCENTAGE:
                              //Serial.println(", New status: V_PERCENTAGE");
                              //          if (!initial_state_sent) {
                              //            #ifdef MY_DEBUG
                              //            Serial.println("Receiving initial value from controller");
                              //            #endif
                              //            initial_state_sent = true;
                              int per = message.getInt();
                              if (per > STATE_UP) {
                                per = STATE_UP;
                              changeShuttersLevel(per);
                              //InitShutters(message.getInt());//send value < 0 or > 100 to calibrate
                              //sendState();
                              break;
                      else if (message.sensor ==  CHILD_ID_SET) {
                          if (message.type == V_VAR1) {
                            #ifdef MY_DEBUG
                            Serial.println(", New status: V_VAR1, with payload: ");
                            String strRollTime = message.getString();
                            rollTime = strRollTime.toFloat();
                            #ifdef MY_DEBUG
                            Serial.println("rolltime value: ");
                            Serial.println(String(rollTime));
                            saveState(CHILD_ID_SET, rollTime);
                      #ifdef MY_DEBUG
                        Serial.println("exiting incoming message");
                        return;
                      void before() {
                        // Setup the button
                        pinMode(BUTTON_UP_PIN, INPUT_PULLUP);
                        // Activate internal pull-up
                      //  digitalWrite(BUTTON_UP_PIN, HIGH);
                        //  attachInterrupt(digitalPinToInterrupt(BUTTON_UP_PIN), upButtonPress, FALLING);
                        pinMode(BUTTON_DOWN_PIN, INPUT_PULLUP);
                      //  digitalWrite(BUTTON_DOWN_PIN, HIGH);
                        //  attachInterrupt(digitalPinToInterrupt(BUTTON_DOWN_PIN), downButtonPress, FALLING);
                      //  pinMode(BUTTON_STOP_PIN, INPUT_PULLUP);
                      //  digitalWrite(BUTTON_STOP_PIN, HIGH);
                        debouncerUp.attach(BUTTON_UP_PIN);
                        debouncerUp.interval(5);
                        debouncerDown.attach(BUTTON_DOWN_PIN);
                        debouncerDown.interval(5);
                      //  debouncerStop.attach(BUTTON_STOP_PIN);
                      //  debouncerStop.interval(5);
                        pinMode(RELAY_UP_PIN, OUTPUT);
                        pinMode(RELAY_DOWN_PIN, OUTPUT);
                        sendSketchInfo(SKETCH_NAME, SKETCH_VER);
                        present(CHILD_ID_COVER, S_COVER, PRESENT_MESSAGE, IS_ACK);
                        // present(CHILD_ID_SET, S_CUSTOM);
                      void setup(void) {
                        //set up roll time if the saved value is not 255
                        #ifdef MY_DEBUG
                        Serial.println("getting rolltime from eeprom: ");
                        float tmpRollTime = loadState(CHILD_ID_SET);
                        if (tmpRollTime != 0xff) {
                          rollTime = tmpRollTime;
                        #ifdef MY_DEBUG
                        int state = loadState(CHILD_ID_COVER);
                        #ifdef MY_DEBUG
                        Serial.println("getting state from eeprom: ");
                        Serial.println(String(state));
                      //  if (state == 0xff) {
                      //    initShutters();
                      //  } else {
                          currentShutterLevel = state;
                          requestedShutterLevel = state;
                      void loop(void) {
                      #ifdef MY_DEBUG
                          sendState();
                         // send(msgCode.set('20.0'));
                          //    #ifdef MY_DEBUG
                          //    Serial.println("Requesting initial value from controller");
                          //    #endif
                          //    request(CHILD_ID_COVER, V_PERCENTAGE);
                          //    wait(2000, C_SET, V_PERCENTAGE);
                        debouncerUp.update();
                        value = debouncerUp.read();
                        if (value == 0 && value != oldValueUp) {
                          if(isMoving){
                            shuttersHalt();
                          else{
                          calibrateUp = false;
                          calibratedUp = false;
                          //state = UP;
                          //sendState();
                        oldValueUp = value;
                        debouncerDown.update();
                        value = debouncerDown.read();
                        if (value == 0 && value != oldValueDown) {
                          if(isMoving){
                            shuttersHalt();
                          else{
                          calibrateDown = false;
                          calibratedDown = false;
                          //state = DOWN;
                          //sendState();
                        oldValueDown = value;
                      /*  debouncerStop.update();
                        value = debouncerStop.read();
                        if (value == 0 && value != oldValueStop) {
                          shuttersHalt();
                          //state = IDLE;
                          //sendState();
                        oldValueStop = value;
                        if(currentShutterLevel != 100)
                        if(currentShutterLevel != 0)
                        if (isMoving)
                          unsigned long _now = millis();
                          if (_now - lastLevelTime >= timeOneLevel * 1000) {
                            if (directionUpDown == DIRECTION_UP) {
                              currentShutterLevel += 1;
                            } else {
                              currentShutterLevel -= 1;
                            currentShutterLevel = constrain(currentShutterLevel, 0, 100);
                            #ifdef MY_DEBUG
                            Serial.println(String(requestedShutterLevel));
                            lastLevelTime = millis();
                          if (currentShutterLevel == requestedShutterLevel)
                            if(currentShutterLevel == 0 && !calibratedDown)
                              if(calibrateDown == false)
                                calibrateDown = true;
                                calibrationStartTime = _now;
                              else
                                if(calibratedDown == false)
                                  if (_now - calibrationStartTime >= calibrationTime * 1000)
                                   calibratedDown = true;
                            else if (currentShutterLevel == 100 && !calibratedUp)
                              if(calibrateUp == false)
                                calibrateUp = true;
                              else
                                if(calibratedUp == false)
                                   calibratedUp = true;
                            else
                              shuttersHalt();
                        else
                          if (requestedShutterLevel != currentShutterLevel)
                            if (requestedShutterLevel > currentShutterLevel) {
                              shuttersUp();
                            else {
                              shuttersDown();
                      • pepsonP pepson
                        #define RFM69_868MH
                        #define RELAY_ON 0
                        #define RELAY_OFF 1
                        int value = 0;
                        int oldValueUp = 0;
                        bool calibrateDown;
                        bool calibrateUp;
                        bool calibratedUp;
                        enum CoverState {
                          STOP,
                        void sendState() {
                          #ifdef MY_DEBUG
                            wait(50);
                          isMoving = true;
                          coverState = UP;
                          sendState();
                          #ifdef MY_DEBUG
                            wait(50);
                          isMoving = true;
                          coverState = DOWN;
                          sendState();
                        #ifdef MY_DEBUG
                          isMoving = false;
                        #ifdef MY_DEBUG
                          coverState = STOP;
                          sendState();
                            shuttersHalt();
                        #ifdef MY_DEBUG
                          shuttersUp();
                        #ifdef MY_DEBUG
                              case V_UP:
                                //state = UP;
                                //sendState();
                                break;
                              case V_DOWN:
                                //state = DOWN;
                                //sendState();
                                break;
                              case V_STOP:
                                shuttersHalt();
                                //state = IDLE;
                                //sendState();
                                break;
                              case V_PERCENTAGE:
                                //            #ifdef MY_DEBUG
                                //            #endif
                                  per = STATE_UP;
                                //sendState();
                                break;
                              #ifdef MY_DEBUG
                              #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                          return;
                        void before() {
                          // Setup the button
                        void setup(void) {
                          #ifdef MY_DEBUG
                          #ifdef MY_DEBUG
                          #ifdef MY_DEBUG
                        //    initShutters();
                        //  } else {
                        void loop(void) {
                        #ifdef MY_DEBUG
                            sendState();
                            //    #ifdef MY_DEBUG
                            //    #endif
                            if(isMoving){
                              shuttersHalt();
                            else{
                            //state = UP;
                            //sendState();
                          oldValueUp = value;
                            if(isMoving){
                              shuttersHalt();
                            else{
                            //state = DOWN;
                            //sendState();
                            shuttersHalt();
                            //state = IDLE;
                            //sendState();
                          if (isMoving)
                              } else {
                              #ifdef MY_DEBUG
                                else
                                  calibrateUp = true;
                                else
                              else
                                shuttersHalt();
                          else
                                shuttersUp();
                              else {
                                shuttersDown();
                        pepsonP
                        pepsonP
                        pepson
                        Finally
                        In my opinion on MySensors 2.2.0 all my sketches (switch relay and cover ) works better. With no problem. NO PROBLEM.
                        Cover works perfect and switch works perfect without any timeout and delay. ANd all node works without REPEATER.
                        My opinion is that in version 2.3.0 something not working correct with radio RFM69HW.
                        Maybe for sensors which send data from time to time is ok , but for cover which transfer data when cover is roll, it is problem... and gateway can not recived all data when node send position cover. Maybe developer read this thread and can do any changes to correct it.
                        scalzS S 2 Replies Last reply
                        • M mickecarlsson
                          pepsonP
                          pepsonP
                          pepson
                          @mickecarlsson
                          ANd tell me how you connect Gateway to your Domoticz Controller ? What path to usb or serial you setup in Domoticz ?
                          • pepsonP pepson
                            Finally
                            scalzS
                            scalzS
                            #53
                            @pepson said in RFM69 new driver delay:
                            Like I said, we will take a look as soon as we get time. For the moment, busy (at least on my side). And we're a few, using rfm69.
                            So if 2.2 fixes your issue, it can be a good idea.
                            • scalzS scalz
                              pepsonP
                              pepsonP
                              pepson
                              @scalz
                              Ok thanks. WAiting for info... and good info for me will be that problem with RFM69HW on version 2.3.0 will be resolve and i can update to this version. Now i must come back to version 2.2.0
                                If you don't need specific features in 2.3, then stick to 2.2 that works well.
                                • pepsonP pepson
                                  Finally
                                  sineverba
                                  Finally
                                  RFM69W / HW user here. I can confirm that V 2.3.0 on both nodes and PI has some broken. My nodes, stable for 3+ months, with new version they have issues. In detail, they cannot get ACK. In my sketch, I check for ACK when transmitting, to force the watchdog or no. NO ACK received (1 every 20/30) :(
                                  And my nodes are "perfect". LifePo4 or AA, someone feeded directly, RPI3 with 2.5a... And I repeat, no issues in 3+ months from switching from NRF to RFM.
                                    mickecarlsson
                                    This is my generic temperature/humidity/battery level sketch that I use. I have upgraded all my nodes and gateway to 2.3.0 yesterday and I don't have any issue whatsoever :-)
                                     * This is a sketch I use to measure temperature, humidity and battery level on
                                     * my Easy/Newbie PCB for MySensors (rev 9)
                                     * Hardware used:
                                     * Easy/Newbie PCB for MySensors
                                     * BME280 (I only use temperature and humidity, all code for barometic pressure removed)
                                    //#define MY_DEBUG
                                    #define   MY_SPLASH_SCREEN_DISABLED  // This saves a couple of bytes
                                    #include <Wire.h>       // Enables the Wire communication protocol.
                                    // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code,
                                    // written originally by Embedded Adventures.
                                    // https://github.com/embeddedadventures/BME280
                                    #include <BME280_MOD-1022.h>
                                    // Internal battery measurement https://github.com/Yveaux/arduino_vcc
                                    #include <Vcc.h>
                                    // Change all text variables here, no need to hunt them down in the sketch
                                    // For sendSketchInfo()
                                    #define SKETCH_NAME       "Generic Temeperature/Humidity"
                                    #define SKETCH_VERSION    "1.13"
                                    // For present()
                                    #define PRESENT_TEMP_TEXT "Temperature Generic"
                                    #define PRESENT_HUM_TEXT  "Humidity Generic"
                                    #define PRESENT_BAT_TEXT  "Batteri Test-3"
                                    // Battery measurements
                                    const float VccMin        = 1.8*1.0;  // Min Vcc level, in Volts. Example for 2xAA Alkaline.
                                    const float VccMax        = 2.0*1.5;  // Max Vcc level, in Volts. Example for 2xAA Alkaline.
                                    const float VccCorrection = 1.0/1.0;  // Measured Vcc by multimeter divided by reported Vcc
                                    Vcc vcc(VccCorrection);
                                    // VARIABLES YOU CAN CHANGE
                                    // Send temperature only if it has changed? 1 = Yes 0 = No.
                                    #define COMPARE_TEMP 0
                                    // Set this value to the minimum change in temperature to measure.
                                    // BME280 has +-0.5 degrees precision, so it really doesn't matter that much.
                                    float tempThreshold = 0.5;
                                    // Send temperature only if changed? 1 = Yes 0 = No.
                                    #define COMPARE_HUM 0
                                    // Set this value to the minimum change in humidity to measure.
                                    // BME280 has +-3% relative humidity precision, so it really doesn't matter that much.
                                    float humThreshold = 0.5;
                                    #define TEMP_CHILD_ID       1
                                    #define HUM_CHILD_ID        2
                                    #define VOLTAGE_CHILD_ID    3
                                    float lastTemperature = -1;   // Store previous measurement
                                    float lastHumidity =    -1;   // Stores the previous measurement
                                    bool reportRSSI = false;      // true = send RSSI to controller
                                    int sendBattery = 6;          // report battery level only after 6 loops = 6*4 minutes = 24 minutes
                                    // Placeholder for batteryloop, set to one above sendBattery so that we get a report on startup
                                    int batteryLoop = sendBattery + 1;
                                    // Time between send (in milliseconds), in this case, 4 minutes.
                                    unsigned long FOUR_MINUTE_SEND_FREQUENCY = 4 * 60000;
                                    // MYSENSORS COMMUNICATION VARIABLES
                                    MyMessage temperatureMsg(TEMP_CHILD_ID, V_TEMP);
                                    MyMessage humidityMsg(HUM_CHILD_ID, V_HUM);
                                    MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
                                    #ifdef MY_DEBUG
                                      Serial.begin(115200);
                                      Wire.begin(); // For the BME280 sensor
                                    #ifdef MY_DEBUG
                                      Serial.println(F("Starting ..."));
                                      // Present the sensors to the gateway and controller
                                      present(TEMP_CHILD_ID, S_TEMP, PRESENT_TEMP_TEXT);
                                      present(HUM_CHILD_ID, S_HUM, PRESENT_HUM_TEXT);
                                      present(VOLTAGE_CHILD_ID, S_MULTIMETER, PRESENT_BAT_TEXT);
                                    #ifdef MY_DEBUG
                                      Serial.println(F("Read BME280 and report it's values."));
                                      GetTemperatureHumidity();                 // Get temperature and humidity
                                      if(batteryLoop > sendBattery) {           // Is the batteryLoop higher than sendBattery?
                                    #ifdef MY_DEBUG
                                        Serial.println(F("Read the battery voltage and report it."));
                                        MeasureBattery();                      // Measure and report battery level
                                        batteryLoop = 0;                       // Reset batteryLoop count
                                    #ifdef MY_DEBUG
                                      Serial.print(F("Go to sleep for: "));
                                      Serial.print(FOUR_MINUTE_SEND_FREQUENCY / 60000);
                                      Serial.println(F(" minutes."));
                                      batteryLoop++;                           // Increase batteryLoop before we sleep.
                                      sleep(FOUR_MINUTE_SEND_FREQUENCY);       // Sleep for 4 minutes
                                    * GetTemperatureHumidity()
                                    * Routine for measuring temperature and humidity
                                    * Generic one that fits my need
                                    void GetTemperatureHumidity()
                                    #ifdef MY_DEBUG
                                      Serial.println("");
                                      Serial.println(F("BME280 - Requesting new data from sensor module."));
                                      BME280.readCompensationParams();            // Need to read the NVM compensation parameters.
                                      // Normal mode for regular automatic samples
                                      BME280.writeStandbyTime(tsb_0p5ms);         // tsb = 0.5ms
                                      BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient 16
                                      BME280.writeOversamplingPressure(os16x);    // pressure x16
                                      BME280.writeOversamplingTemperature(os8x);  // temperature x8
                                      BME280.writeOversamplingHumidity(os8x);     // humidity x8
                                      BME280.writeMode(smNormal);
                                    #ifdef MY_DEBUG
                                      Serial.println(F("Getting new values"));
                                      while (BME280.isMeasuring()) {              // Wait for BME280 to fininsh reading data
                                    #ifdef MY_DEBUG
                                        Serial.println("Measuring...");
                                        delay(50);
                                      Serial.println("Done!");
                                      // Read out the data - must do this before calling the getxxxxx routines
                                      BME280.readMeasurements();
                                      float temperature = BME280.getTemperatureMostAccurate();  // Get the temperature first.
                                      float humidity = BME280.getHumidityMostAccurate();        // Get the humidity.
                                    #ifdef MY_DEBUG
                                      Serial.print(F("BME280 - Temperature = "));
                                      Serial.print(temperature);
                                      Serial.println(" °C");
                                      Serial.print(F("BME280 - Humidity = "));
                                      Serial.print(humidity);
                                      Serial.println(F(" %"));
                                      // Now, let's send the measurements to the gateway.
                                      // Send temperature if the temperature difference bigger than the threshold
                                      if (COMPARE_TEMP == 1 && abs(temperature - lastTemperature) < tempThreshold) {
                                    #ifdef MY_DEBUG
                                        Serial.print(temperature - lastTemperature);
                                        Serial.println(F(" Temperature difference too small, don't send it to gateway."));
                                      } else {
                                    #ifdef MY_DEBUG
                                          Serial.println(F("Sending new temperature to the gateway."));
                                          send(temperatureMsg.set(temperature, 1));
                                          lastTemperature = temperature; // Save temperatures for compare in the next round.
                                      // Send humidity if the humidity difference is bigger than the threshold.
                                      if (COMPARE_TEMP == 1 && abs(humidity - lastHumidity) < humThreshold) {
                                    #ifdef MY_DEBUG
                                        Serial.print(humidity - lastHumidity);
                                        Serial.println(F(" Humidity difference too small, don't send it to the gateway."));
                                      } else {
                                    #ifdef MY_DEBUG
                                        Serial.println(F("BME280 - Sending the new humidity to the gateway."));
                                        send(humidityMsg.set(humidity, 1));
                                        lastHumidity = humidity; // Save new humidity to be able to compare in the next round.
                                    #ifdef MY_DEBUG
                                      Serial.println(F("BME280 - Measurement complete. Putting sensor to sleep."));
                                      BME280.writeMode(smSleep);  // set the BME280to sleep mode, save battery
                                    } // End of GetTemperatureHumidity
                                    * MeasureBattery()
                                    * Routine for measuring battery level
                                    * NOTE: You need to calibrate the measurement to get correct readings
                                    void MeasureBattery()
                                      float Vbat = vcc.Read_Volts();
                                      int batteryPercent = static_cast<int>(vcc.Read_Perc(VccMin, VccMax));
                                    #ifdef MY_DEBUG
                                      Serial.print(F("Battery percent: "));
                                      Serial.print(batteryPercent);
                                      Serial.println(" %");
                                      Serial.print(F("Battery Voltage: "));
                                      Serial.print(Vbat);
                                      Serial.println(F(" Volts"));
                                        sendBatteryLevel(batteryPercent);
                                        send(voltageMsg.set(Vbat,2)); //send battery in Volt 2 decimal places
                                    • pepsonP pepson
                                      @mickecarlsson
                                      mickecarlsson
                                      I use Ethernet to connect to my Domoticz.
                                      The reason that you don't see my configuration for ETHERNET or PORT is because they are default when you configure.
                                      If you look at the file Makefile.inc you will see the build options. In my case the file looks like this:
                                      SOC=BCM2837
                                      CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RFM69 -DMY_RFM69_NEW_DRIVER -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_RFM69_FREQUENCY=RFM69_868MHZ -DMY_IS_RFM69HW
                                      LDFLAGS=-pthread
                                      PREFIX=/usr/local
                                      CC=gcc
                                      CXX=g++
                                      BUILDDIR=build
                                      BINDIR=bin
                                      GATEWAY_DIR=/usr/local/bin
                                      INIT_SYSTEM=systemd
                                      SPI_DRIVER=BCM
                                      So in my case I have these defines:
                                      MY_RADIO_RFM69
                                      MY_RFM69_NEW_DRIVER
                                      MY_GATEWAY_LINUX
                                      MY_DEBUG
                                      LINUX_SPI_BCM
                                      MY_IS_RFM69HW
                                      • M mickecarlsson
                                         * Hardware used:
                                        //#define MY_DEBUG
                                        #include <Vcc.h>
                                        // For present()
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                          Serial.println("");
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                            delay(50);
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                          } else {
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                          } else {
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                        * MeasureBattery()
                                        #ifdef MY_DEBUG
                                          Serial.print(Vbat);
                                        pepsonP
                                        pepsonP
                                        pepson
                                        @mickecarlsson
                                        You dont have issue becuase temp/hum send data from time to time every defined time.
                                        My sketch with relay also looks that works ok.
                                        But problem is on sketch with relay to control covers. WHen cover roll node send still data and it is problem...
                                        This is my opinion.
                                        • M mickecarlsson
                                          SOC=BCM2837
                                          LDFLAGS=-pthread
                                          PREFIX=/usr/local
                                          CC=gcc
                                          CXX=g++
                                          BUILDDIR=build
                                          BINDIR=bin
                                          INIT_SYSTEM=systemd
                                          SPI_DRIVER=BCM
                                          MY_RADIO_RFM69
                                          MY_RFM69_NEW_DRIVER
                                          MY_GATEWAY_LINUX
                                          MY_DEBUG
                                          LINUX_SPI_BCM
                                          MY_IS_RFM69HW
                                          pepsonP
                                          pepsonP
                                          pepson
                                          #60
                                          @mickecarlsson said in RFM69 new driver delay:
                                          LDFLAGS=-pthread
                                          Tell me you have BME280 this :
                                          https://www.aliexpress.com/item/3In1-BME280-GY-BME280-Digital-Sensor-SPI-I2C-Humidity-Temperature-and-Barometric-Pressure-Sensor-Module-1/32847825408.html?spm=2114.search0104.3.1.6d76301deOqjBT&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10068_5722815_10342_10343_10340_5722915_10341_5722615_10696_10084_10083_10618_10304_10307_10820_10301_10821_5722715_10843_10059_306_100031_10103_10624_10623_10622_5722515_10621_10620,searchweb201603_1,ppcSwitch_5&algo_expid=8f90a51c-aded-4f24-a909-68e32bf05b4b-0&algo_pvid=8f90a51c-aded-4f24-a909-68e32bf05b4b&priceBeautifyAB=0
                                          My defined is the same:
                                          SOC=BCM2837
                                          CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RFM69 -DMY_RFM69_NEW_DRIVER -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_DEFAULT_TX_LED_PIN=18 -DMY_DEFAULT_RX_LED_PIN=16 -DMY_DEFAULT_ERR_LED_PIN=12 -DMY_PORT=5003 -DMY_IS_RFM69HW -DMY_RFM69_FREQUENCY=RFM69_868MHZ
                                          LDFLAGS=-pthread
                                          PREFIX=/usr/local
                                          CC=gcc
                                          CXX=g++
                                          BUILDDIR=build
                                          BINDIR=bin
                                          INIT_SYSTEM=systemd
                                          SPI_DRIVER=BCM
