  3. Can I have multiple sleep/interrupt events in the one sketch?
3 Posts 2 Posters 1.6k Views 3 Watching
  • G
    G
    gadgetman
    wrote on last edited by gadgetman
    I have a prototype battery relay node working, where using smart sleep I am able to turn on a relay (currently just a connected LED) and off from the controller, with a lag in actuation equal to the smart sleep duration.
    What I would now like to do is to introduce a secondary function where the node is able to turn the relay off after a preset period if no off command is received from the controller. Is this possible by introducing another sleep timer? If so how could I do this (as opposed to having a controller rule send the off command).
    Here's my quick and dirty test sketch - hacked from the relay node example.
    // #define MY_REPEATER_FEATURE
    #define MY_SMART_SLEEP_WAIT_DURATION_MS 1000
    //#define RELAY_1  3  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define LEDpin 5
    //#define NUMBER_OF_RELAYS 1 // Total number of attached relays
    //#define RELAY_ON 1  // GPIO value to write to turn on attached relay
    #define LED_ON 1
    //#define RELAY_OFF 0 // GPIO value to write to turn off attached relay
    #define LED_OFF 0
    #define VMIN 1.9 // Battery monitor lower level. Vmin_radio=1.9V
    #define VMAX 3.0 // " " " high level. Vmin<Vmax<=3.44
    int BATTERY_SENSE_PIN = A1;  // select the input pin for the battery sense point
    int oldBatteryPcnt = 0;
    #define child 1
    void before()
        //for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
        pinMode(LEDpin, OUTPUT);
        digitalWrite(LEDpin, loadState(LEDpin)?LED_ON:LED_OFF);
       analogReference(INTERNAL);     // use the 1.1 V internal reference for battery level measuring
         //  for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
         present(child, S_BINARY);
    // get the battery Voltage
    #ifdef MY_DEBUG
        Serial.println(sensorValue);
        float batteryV  = sensorValue * 0.003347095;
        int batteryPcnt = static_cast<int>(((batteryV-VMIN)/(VMAX-VMIN))*100);
    #ifdef MY_DEBUG
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
            // Power up radio after sleep
            oldBatteryPcnt = batteryPcnt;
      // Sleep for a while to save energy (using martsleep)
    smartSleep(UPDATE_INTERVAL);
      if (message.type==V_STATUS) {
        // Change relay state
        digitalWrite(LEDpin, message.getBool()?LED_ON:LED_OFF);
        // Store state in eeprom
        saveState(LEDpin, message.getBool());
        // Write some debug info
        Serial.print(message.sensor);
      you could count how many times you have ran the loop, if your turn off time is a multiple of sleeptime, when you receive a switch on command you just reset the counter.
      G 1 Reply Last reply
        G
        G
        gadgetman
        @gohan Lol you're absolutely right! I should have thought of that earlier - thanks!
