  3. Presentation (S_*) and set, req (V_*) limitations
3 Posts 2 Posters 1.5k Views 2 Watching
  • Meshx86M
    Meshx86M
    Meshx86
    This sounds silly but it really annoys me.
    I switched from OpenHAB2 (using MQTT binding) to Home Assistant (using mysensors component) to read my Energy Meter (SDM220) which has a total of 14 variables that are read via Modbus RS-485 according to the manual.
    i do present both S_POWER and S_MULTIMETER, but i do not present the rest (frequency, phase angle, total Kvarh, etc) because there is not proper sensor type (V_*) to represent them.
    i've allocated the number 57-63 to send the rest of the data, but home assistant component is complaining that they're undefined in the dictionary.
    V_VAR1 - V_VAR5 are not enough for me, and i really don't want to break them to multiple child nodes, has anyone considered adding S_ENERGYMON (that would include all values -existing and non-existing- under it) ?
      I figured that sometimes you could just use some other variable types even if they are not specific for that value, it's a matter of trying 😁
      Btw, did you successfully connected to the meter using rs485?
      • Meshx86M
        Meshx86M
        Meshx86
        yea i ended up using V_VAR1 - V_VAR5, V_CUSTOM, V_TEXT and presenting both S_INFO and S_CUSTOM.
        i am currently reading it through Wemos D1 Mini + MAX RS485 converter (working without logic converter just fine).
