  3. FHEM
  4. Inlcusionmode crashes FHEM
Scheduled Pinned Locked Moved FHEM
2 Posts 2 Posters 3.3k Views 2 Watching
  • K
    K
    Komaandy
    Hello, i have a strange problem.
    I have a lot nodes working properly, but when trying to connect another node ( i tried several) it crashes FHEM.
    These nodes i want to connect have been working, but due to a new Gateway i needed to reconnect all of them.
    So, 10 out of 14 are connecting just fine, but as i said, there are some nodes that crash the system when i enable autoinclusion and power the node on.
    Any suggestions ?
    I already installed FHEM on a new machine and restored from a backup, but the problem persists
    KR
    Komaandy
    • rejoe2R
      rejoe2R
      rejoe2
      Sounds really strange, but the info you provide imo is to limited to expect any helpful answer.
      If FHEM is crashing "reliably", you should analyse the FHEM log (and perhaps try to get an extended log) or start FHEM in a special debugging mode and try to reproduce the problem.
      (May not solve the underlying problem, but) why are you not just changing the DEF of your original GW to point to the new one?
      Additional questions you may answer:
      • What type of GW did you use and are you now using?
      • Controller Hard- & Software (Pi or decent Linux machine, Windows server, VM...???)
      • Does FHEM also crash, if you try to autocreate the problematic Node not as #11, but as the first?
      • How often died you save your config in the process of including nodes? Did you monitor memory usage?
      • If crashing FHEM is related to a "special" node: What is different in this sketch?
