  3. Wemos D1 mini GW + DHT22 + Relay shield
1 Posts 1 Posters 2.8k Views 1 Watching
  • R Offline
    R Offline
    rucnabrzda
    Hi I'm a newcomer, I need to help with my sketch. I try to run the temperature and humidity sensor for the relay. I only run DHT under Verou Plus for inclusion mode does not find a relay. anyone help me?
     * Version 1.0 - Henrik EKblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
     * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
     * LED purposes:
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
     * GND        GND
      * Inclusion mode button:
    #include <EEPROM.h>
    #include <DHT.h>
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "ZZZ"
    #define MY_ESP8266_PASSWORD "xxx"
    // Enable UDP communication
    //#define MY_USE_UDP
    //define MY_ESP8266_HOSTNAME "ESP8266-sensorNode1"
    #define MY_IP_ADDRESS 192,168,2,45
    #define MY_IP_GATEWAY_ADDRESS 192,168,2,1
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Led pins used if blinking feature is enabled above
    #if defined(MY_USE_UDP)
      #include <WiFiUDP.h>
    #else
      #include <ESP8266WiFi.h>
    //-------- DHT22 related definitions ----->>>
    #define DHTPIN 2
    #define DHTTYPE DHT22   // DHT 22  (AM2302)
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define RELAY_1 D3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_ON 1 // GPIO value to write to turn on attached relay
    float lastTemp;
    float lastHum;
    bool metric = true;
    float temperature;
    static const uint64_t UPDATE_INTERVAL = 15000;
    DHT dht(DHTPIN, DHTTYPE);
    //<<<----- DHT22 related definitions --------
    void before()
    pinMode(pin, OUTPUT);
       dht.begin();
    void presentation() {
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
       //sendSketchInfo("Relay", "1.0");
      present(sensor, S_BINARY);
      temperature = dht.readTemperature();
      wait(2000);
      Serial.print("Temperature:");
      Serial.println(temperature);
      if (isnan(temperature)) {
        lastTemp = temperature;
        // Reset no updates counter
      float humidity = dht.readHumidity();
      wait(2000);
      Serial.print("Humidity:");
      Serial.println(humidity);
      if (isnan(humidity)) {
        lastHum = humidity;
        send(msgHum.set(humidity, 1));}
    if (message.type==V_STATUS) {
    // Change relay state
    // Store state in eeprom
    // Write some debug info
    Serial.print(message.sensor);
    Serial.println(message.getBool());}
      wait(UPDATE_INTERVAL);
