  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.6k Views 73 Watching
  • balloonguyB balloonguy
    @tekka thanks for the quick response - i have tried the {http://goo.gl/9DCWNo} with no luck, all i get is a "this page is not available" message. I have tried with different browsers and different pc's - still the same response.
    BTW- Merry Christmas.
    R
    R
    robosensor
    @balloonguy just tried this link. Everything is working, MYSController.zip file with md5 checksum dfe98f9e7ed6e1c3d5c418a862c23ee0 is downloaded.
    • D
      D
      drock1985
      Hi @tekka
      When editing/adding items to the firmware_config.csv file, what should go in the types column? Could you please explain it?
      Thanks,
      My Projects
      2 Door Chime Sensor
      Washing Machine Monitor
      tekkaT 1 Reply Last reply
      • D drock1985
        Hi @tekka
        Thanks,
        tekkaT
        tekkaT
        tekka
        The type field is intended for defining a FW type, e.g. a node with a DHT humidity/temperature sensor may be FW type 1, whereas a node with a different sensor FW type 2 and so on...
        • P
          P
          p0lar
          Now that I have sensors that have the correct bootloader I have been able to upload firmware a few times. But now that I have made changed to the sketch and copied the new hex file over I even bumped the version tag in the file. I can't get it to flash. Nothing I do makes it upload the new code? Thoughts?
          N tekkaT 2 Replies Last reply
          • P p0lar
            N
            N
            niccodemi
            @p0lar are you still able to remotely reboot node?
            • P p0lar
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              #326
              @p0lar Please provide MYSController log with DEBUG enabled for further troubleshooting.
              • P
                P
                p0lar
                Yes I can reboot the node. trying to upload dallastemp to it.
                MySensors_20160102-104854.log
                • P p0lar
                  tekkaT
                  tekkaT
                  tekka
                  @p0lar I do not see any DEBUG nor bootloader messages. Can you update the GW sketch with DEBUG enabled? Also, what bootloader did you flash?
                  • P
                    P
                    p0lar
                    Its turned on in MySensors.h and reuploaded
                    MyConfig.h
                    • P
                      P
                      p0lar
                      But i dont see anything. UNO ethernet GW with SoftSPI enabled
                      • P
                        P
                        p0lar
                        Bootloader on the sensors is the one from your firmware directory. on the GW its the standard arduino one... do I need yours on the GW?
                        • P p0lar
                          tekkaT
                          tekkaT
                          tekka
                          @p0lar No, GW should have normal (i.e. Arduino) bootloader. However, without DEBUG output it's gonna be hard to diagnose what's wrong - can you double-check your settings and re-upload the GW sketch just to be on the safe side.
                          Also, I'd like to see the log during a manual reset (not remote reboot) of your node.
                          • P
                            P
                            p0lar
                            Thanks. Ill check that when I get back into town end of this week.
                            • S
                              stebra
                              Hi @tekka,
                              tried now some evenings to change node-id / clear the eeprom. No luck. FW update works always. After reading the bootloader code I expected myscontroller to send a invalid fwrequestresponse packet with special crc for the bootloader commands. Never showed up in the log.
                              Myscontroller .282 on Win xp and msbootloader 1.1 on nano. 47uF on nrf. No transmission errors.
                              Any ideas where to look next ? Maybe .278 will do the trick ?
                              Thanks for your efforts ,
                              stebra
                              • S stebra
                                Hi @tekka,
                                stebra
                                tekkaT
                                tekkaT
                                tekka
                                @stebra please post the myscontroller log with gw DEBUG enabled that shows OTA update and ID reassign request.
                                • S
                                  stebra
                                  MySensors_20160110-115615_stebra.log
                                  hi tekka,
                                  here is the log. Contains:
                                  [2016-01-10 12:02:26.390 Info] INFO *** Logging START *** // stebra : succesful reboot of node 6 via myscontroller
                                  [2016-01-10 12:02:59.000 Info] INFO *** Logging START *** // stebra : succesful FW update of node 6 via myscontroller
                                  [2016-01-10 12:05:35.109 Info] INFO *** Logging START *** // stebra : ID reassign attempt of node 6 to node 12 via myscontroller
                                  [2016-01-10 12:05:48.328 Info] INFO Send FW info to node 6: type=1E, version=1, blocks=0x0448, CRC=0xA87A // here the behaviour is unexpected for me
                                  [2016-01-10 12:06:37.437 Info] INFO *** Logging START *** // stebra: Clear eeprom attempt on node 6
                                  [2016-01-10 12:06:44.812 Info] INFO Send FW info to node 6: type=1E, version=1, blocks=0x0448, CRC=0xA87A // here the behaviour is unexpected for me
                                  thank you for having a look..
                                  • S
                                    stebra
                                    and also a ss for another reassign attempt node 6--> 12.
                                    FIRMWARE_CONFIG_REQUEST is not answered from myscontroller. therefore no reassign of node id.
                                    • D
                                      D
                                      dakipro
                                      wrote on last edited by dakipro
                                      #338
                                      Maybe I should open a new topic for this, but I cannot flash bootloader, I always get
                                      Arduino: 1.6.7 (Windows 10), Board: "ATmega328 internal 8Mhz with MYSBootloader"
                                      ***failed;
                                      avrdude: verification error, first mismatch at byte 0x0000
                                      0x3f != 0xff
                                      avrdude: verification error; content mismatch
                                      Error while burning bootloader.
                                      Here is the verbose message
                                      C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM4 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:i -Ulock:w:0xFF:m
                                      Reading | ################################################## | 100% 0.01s
                                      avrdude: verifying ...
                                      avrdude: 1 bytes of lock verified
                                      avrdude: reading input file "0x06"
                                      avrdude: writing efuse (1 bytes):
                                      Writing | ################################################## | 100% 0.01s
                                      avrdude: 1 bytes of efuse written
                                      avrdude: verifying efuse memory against 0x06:
                                      avrdude: load data efuse data from input file 0x06:
                                      avrdude: input file 0x06 contains 1 bytes
                                      avrdude: reading on-chip efuse data:
                                      avrdude: 1 bytes of efuse verified
                                      avrdude: reading input file "0xDA"
                                      avrdude: writing hfuse (1 bytes):
                                      avrdude: 1 bytes of hfuse written
                                      avrdude: verifying hfuse memory against 0xDA:
                                      avrdude: load data hfuse data from input file 0xDA:
                                      avrdude: input file 0xDA contains 1 bytes
                                      avrdude: reading on-chip hfuse data:
                                      avrdude: 1 bytes of hfuse verified
                                      avrdude: reading input file "0xE2"
                                      avrdude: writing lfuse (1 bytes):
                                      avrdude: 1 bytes of lfuse written
                                      avrdude: verifying lfuse memory against 0xE2:
                                      avrdude: load data lfuse data from input file 0xE2:
                                      avrdude: input file 0xE2 contains 1 bytes
                                      avrdude: reading on-chip lfuse data:
                                      avrdude: 1 bytes of lfuse verified
                                      avrdude done.  Thank you.
                                      avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
                                               Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                                               Copyright (c) 2007-2009 Joerg Wunsch
                                               System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
                                               Using Port                    : COM4
                                               Using Programmer              : stk500v1
                                               Overriding Baud Rate          : 19200
                                               AVR Part                      : ATmega328P
                                               Chip Erase delay              : 9000 us
                                               PAGEL                         : PD7
                                               BS2                           : PC2
                                               RESET disposition             : dedicated
                                               RETRY pulse                   : SCK
                                               serial program mode           : yes
                                               parallel program mode         : yes
                                               Timeout                       : 200
                                               StabDelay                     : 100
                                               CmdexeDelay                   : 25
                                               SyncLoops                     : 32
                                               ByteDelay                     : 0
                                               PollIndex                     : 3
                                               PollValue                     : 0x53
                                               Memory Detail                 :
        Block Poll               Page                       Polled
                                                 Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                                                 eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
                                                 flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
                                                 lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                                 hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                                 efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                                 lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                                 calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                                                 signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                                               Programmer Type : STK500
                                               Description     : Atmel STK500 Version 1.x firmware
                                               Hardware Version: 2
                                               Firmware Version: 1.18
                                               Topcard         : Unknown
                                               Vtarget         : 0.0 V
                                               Varef           : 0.0 V
                                               Oscillator      : Off
                                               SCK period      : 0.1 us
                                      avrdude: AVR device initialized and ready to accept instructions
                                      Reading | ################################################## | 100% 0.02s
                                      avrdude: Device signature = 0x1e950f
                                      avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
                                               To disable this feature, specify the -D option.
                                      avrdude: erasing chip
                                      avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex"
                                      avrdude: writing flash (32722 bytes):
                                      Writing | ################################################## | 100% 0.00s
                                      avrdude: 32722 bytes of flash written
                                      avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:
                                      avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:
                                      avrdude: input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex contains 32722 bytes
                                      avrdude: reading on-chip flash data:
                                      Reading | ################################################## | 100% -0.00s
                                      avrdude: 32722 bytes of flash verified
                                      avrdude: reading input file "0xFF"
                                      avrdude: writing lock (1 bytes):
                                      Writing |  ***failed;
                                      ################################################## | 100% 0.07s
                                      avrdude: 1 bytes of lock written
                                      avrdude: verifying lock memory against 0xFF:
                                      avrdude: load data lock data from input file 0xFF:
                                      avrdude: input file 0xFF contains 1 bytes
                                      avrdude: reading on-chip lock data:
                                               0x3f != 0xff
                                      I get same message with both 3.3v and 5v pro mini that is linked in the store.
                                      I am using Funduino uno as a ips, and I can flash blink f.eks. using uno as isp, but I cannot flash bootloader. This is the step 6 from the instructions that is failing. Any ideas how to fix this? I would really like OTA as my network is slowly growing.
                                      Thanks for any tips!
                                      • D
                                        D
                                        dakipro
                                        I think I have flashed MYSBootloader finaly, after ~6hours of trying and reading (persistent guy :) )
                                        The instructions are for the older version I guess, right board should be copied from MYSController/bootloader/boards.txt, not from this topic post#75. Now I am trying to figure how to flash the sketch, but I guess that is explained somewhere on the topic
                                        • D
                                          D
                                          dakipro
                                          Just one more question, I didn't find it answered on the topic (maybe too tired), but:
                                          I have existing network with ethernet gateway and some nodes, and all is working fine. To make it OTA update-able, I need to
                                          1. i upload ethernet gateway to the Arduino Nano, then flash MYSBootloader on it,
                                          2. upload some sketch (which?) on Arduino Mini nodes, and then flash MYSBootloader on it, and then I can program it OTA?
                                          3. Or something else?
                                          Or did I miss the point completely? :(
