  3. Home Assistant
  4. How to connect my ethernet gateway to hass?
2 Posts 2 Posters 1.7k Views 2 Watching
  • N
    N
    nerukam
    I have built the ethernet gateway using an Arduino and a wiz5100 ethernet board. I can ping the board on its configured IP address from my computer.
    I have HASS running in a container locally (to test it out).
    The gateway has no sensors yet, but I'd expect it to be visible in HASS before I can add any sensors.
    How do I get HASS and the ethernet gateway to know about each other?
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      No mysensors devices will be visible in home assistant until they are presented and send their first values to home assistant. So only having a gateway without sensors will not generate any mysensors entities in home assistant.
      You can read more about presenting your mysensors devices to home assistant here:
      https://home-assistant.io/components/mysensors/#presentation
