  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • dbemowskD
    dbemowskD
    @NeverDie Just have to say, I have been following this thread for a while now and you have come a long way with this. Great job.
    • NeverDieN
      NeverDieN
      Another good thing for people to know is that you can leave a single-sided blank PCB installed in the CNC and then, as the need arises, cut out additional modules from it:
      For instance, this morning I cut this module carrier out of the above, already used, copper clad PCB:
      So, for simple small things, it's a handy arrangement, and the incremental cost is negligible.
      • NeverDieN NeverDie
        zboblamontZ
        zboblamontZ
        zboblamont
        @neverdie Perhaps a clearer explanation ?
        • NeverDieN
          NeverDieN
          #464
          One problem I've run into though is that the foil traces can sometimes lift up in the course of ordinary soldering. For instance, the traces connecting the second to the right pin on the Fanstel module seems to have utterly disappeared, leaving that pin unconnected:
          Maybe it's the quality of the blank PCB? I just don't know.
          dbemowskD 1 Reply Last reply
            dbemowskD
            dbemowskD
            @neverdie It looks like you could potentially make those traces just a touch wider looking at the receiving end of the module. Woulld that be an option?
            NeverDieN 1 Reply Last reply
            • dbemowskD dbemowsk
              NeverDieN
              NeverDieN
              @dbemowsk said in CNC PCB milling:
              Maybe: I'll try a 10 degree bit and tighter autoleveling to see if that gives wider traces.
                dbemowskD
                dbemowskD
                @neverdie i say that because in your previous pic of the board it looked like that trace was a bit narrow. Because of that it probably couldn't take the heat.
                • NeverDieN
                  NeverDieN
                  It's funny, because I redid the soldering using an altogether new board, and it failed in exactly the same place:
                  This time, though, you can actually see the copper trace has curled up away from the board.
                    dbemowskD
                    dbemowskD
                    @neverdie It is quite odd that that one did it and some of the others didn't on that side of the board. Looking at your previous image, the pads and traces on the side marked in green look noticeably larger than the ones marked in red. Look at the ones marked with the blue arrow. It looks like those should, or at least could be the same size. Your thru hole pads on the left for the breakout headers also look smaller than the ones on the right. Shouldn't the two sides be a mirror image of each other?
                      NeverDieN
                      NeverDieN
                      @dbemowsk It's because the left side of the board is higher than the righthand side, and apparently the autoleveling isn't working all that precisely.
                        dbemowskD
                        dbemowskD
                        @neverdie I can see that the left side looks like it cut deeper, which would cause that. I still think it is the thin traces though. Can you do any manual leveling of the bed? If so, I would attempt that. My Anet A8 3D printer, though not a CNC, is all manual leveling and I do have to check it from time to time.
                          NeverDieN
                          NeverDieN
                          #472
                          I suppose I could shim under the sacrifice board with slips of paper to get the right height.
                          I would have thought that the autoleveling would have accurately compensated though. Not sure why it isn't, especially if I'm autoleveling at 2mm spacing. Maybe this is an area where a future version of the GRBL driver will get it right.
                          E dbemowskD andrewA 3 Replies Last reply
                            E
                            E
                            executivul
                            wrote on last edited by executivul
                            #473
                            @neverdie cnc milling auto leveling is not like 3d printing bed leveling.
                            In 3d printing the firmware probes the bed, stores the values and automagically compensates at every move.
                            In cnc milling the host control software asks the grbl to move and probe each point, then it modifies the gcode accordingly and sends that gcode to the controller which in turn just moves in the xyz coordinate system.
                            Now, are you sure your gcode is updated to reflect the leveling?
                            Normal flatcam gcode has a few Z-0.1 moves, the rest are only G1X...Y... (without Z) and autoleveled gcode has almost every move with z, like G1X...Y...Z.... Chilipeppr also adds some comments at the end of the lines like "new Z" or "Z mod".
                            If you run the autoleveling probing but do not hit "send autoleveled gcode to workspace" in CP or "apply height map" in OpenCNCPilot the probing is useless.
                              dbemowskD
                              dbemowskD
                              @neverdie I just wasn't sure if your CNC had any way of manually leveling the bed. My 3D printer has screws in the 4 corners of the bed for me to manually level. I have been sticking to manual leveling on it because I have heard of people that have switched to auto-leveling that have had a number of problems. Maybe you need to switch to a different type of auto-leveling sensor.
                              E 1 Reply Last reply
                              • E executivul
                                dbemowskD
                                dbemowskD
                                @executivul Interesting. I did not know this. That is quite different.
                                  E
                                  E
                                  executivul
                                  #476
                                  What firmware? BEST sensor ever = piezo sensor. I get 3 micron accuracy and repeatability. I use it on Marlin 1.1.8 with UBL on a corexy printer and also on a Smoothie delta.
                                  dbemowskD 2 Replies Last reply
                                  • E executivul
                                    dbemowskD
                                    dbemowskD
                                    @executivul I don't have a sensor yet. If I was going to switch to one I would have to flash a different firmware on my board. It is a newer version of Marlin.
                                      E
                                      E
                                      executivul
                                      #478
                                      Marlin=Arduino (usually Mega2560). So UBL. What type of printer?
                                      • E executivul
                                        dbemowskD
                                        dbemowskD
                                        @executivul I do manual leveling and I rarely have to level the bed itself.
                                          andrewA
                                          andrewA
                                          andrew
                                          @neverdie for pcb milling a small height difference across the board's area could result in a big negative effect if autoleveling is not performed properly.
                                          I would double check your autoleveling process, on the other hand, you could also try to use bed flattening with a bigger endmill tool first, then place the pcb to the flattened area. this could help you to eliminate or decrease the cnc assembly or the sacrificial board caused roughness.
                                          for further details please see the following link:
                                          http://flatcam.org/manual/procedures.html#bed-flattening
