  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • scalzS scalz
    @NeverDie
    too bad! perhaps it's just power supply regulator or a fet which died?? or maybe one of the drivers, just ideas.. I don't know this board.
    Saying this because that was the first things I checked on my 3d printer Ramps board
    • changed ldo (on arduino mega) because I didn't trust clones..
    • a few fets for better rdson (on the Ramps board). then there was no more heat..
    • and of course I calibrated the steppers drivers
    Edit: argh, i misread it's non responsive..then mcu maybe.
    NeverDieN
    NeverDieN
    #421
    @scalz said in CNC PCB milling:
    @NeverDie
    It's receiving power, because the red LED lights up when I connect to it. The atmega328p also appears to be receiving the characters I send to it, because there's an LED that lights very briefly when I do that. However, I'm not seeing that it is sending any characters back, and I'm guessing there would be yet another LED which would indicate that if there were. So, I'm guessing most likely the mcu is dead. I wouldn't be surprised if it got some kind of electrostatic shock when probing, since the probing circuit appears to be wired directly to one of its pins. Also, I was attaching the probe immediately prior to its dying. That makes it a prime suspect in my mind. I don't want to over-react, but for the future I may try isolating that circuit with an opto-isolator or similar to hopefully prevent a recurrence. On the face of it, the present design seems like a heartache just waiting to happen.
    andrewA 1 Reply Last reply
    • E executivul
      @neverdie or you could just mill your own board since now you have the tools :ok_hand:
      dbemowskD
      dbemowskD
      @executivul said in CNC PCB milling:
      Not if it's broke he doesn't.
      • ben999B
        ben999B
        ben999
        That's the original designer of that shield :
        https://blog.protoneer.co.nz/arduino-cnc-shield/
        • NeverDieN NeverDie
          @NeverDie
          andrewA
          andrewA
          andrew
          @neverdie interesting.
          the LEDs are driven by the communication line itself, so if you send a character on serial to the board, then basically your data will flash the MCU's RX LED, not the MCU.
          there should be no problem at all with the touch probe solution/circuit. it equals to a simple button sensing on a common arduino's pin, it cannot cause the MCU's death, if you are connecting everything properly.
          • NeverDieN
            NeverDieN
            #425
            Once I find my dragon, I'll burn a new atmega328p with the grbl 1.1 and replace the suspect atmega328p. Hopefully it will work then. If not, then I'm guessing it's the the usb-to-serial chip gone bad. Anyhow, one way or another I'll get to the bottom of it. And if I don't, a replacement board is on its way.
              andrewA
              andrewA
              andrew
              wrote on last edited by andrew
              #426
              @neverdie don't stick to you missing dragon programmer. use an arduino as an isp programmer instead. also, if you burn the bootloader, next time you can use the usb connector for update.
              NeverDieN 1 Reply Last reply
              • andrewA andrew
                NeverDieN
                NeverDieN
                #427
                @andrew I found my dragon. What fuse settings should I use? I'm tenatively planning to use Arduino pro mini settings.
                • NeverDieN
                  NeverDieN
                  I extracted the atmega328p chip that was on the woodpecker and attempted to read it. Fail. Normal voltage is 5v on a fresh chip, but it was reading only 4.8v. Also, it got quite hot. So, I think it is defective.
                  • NeverDieN
                    NeverDieN
                    #429
                    I've established that the GRBL1.1f firmware assumes it's running at 16Mhz. So, I guess I'll try the following fuse settings, typically used on a 16Mhz Pro Mini:
                    pro5v328.bootloader.low_fuses=0xFF  <<< same as 8 MHz
                    pro5v328.bootloader.high_fuses=0xDA <<< same as 8 MHz
                    pro5v328.bootloader.extended_fuses=0x05 <<< same as 8 MHz
                    BODLEVEL = 2V7
                    RSTDISBL = [ ]
                    DWEN = [ ]
                    SPIEN = [X]
                    WDTON = [ ]
                    EESAVE = [ ]
                    BOOTSZ = 1024W_3C00
                    BOOTRST = [X]
                    CKDIV8 = [ ]
                    CKOUT = [ ]
                    SUT_CKSEL = EXTXOSC_8MHZ_XX_16KCK_14CK_65MS
                    EXTENDED = 0x05 (valid)
                    HIGH = 0xDA (valid)
                    LOW = 0xFF (valid)
                    • NeverDieN
                      NeverDieN
                      #430
                      I soldered in the replacement atmega328p, after burning its firmware with GRBL 1.1f, and Bingo! That fixed it:
                      Grbl 1.1f ['$' for help]
                      Because of the upgraded firmware, I'm actually better off now than I was before. :)
                      • andrewA andrew
                        @neverdie I still use my default settings (see below). I re-applied these settings after I flashed the board to grbl 1.1f.
                        to be honest, after I found the right parameters for the PCB milling jobs I did not went further to fine tune the CNC settings, due to the lack of time. maybe later of the year, but currently I'm more than happy with the results.
                        $0=10 (step pulse, usec)
                        $1=25 (step idle delay, msec)
                        $2=0 (step port invert mask:00000000)
                        $3=5 (dir port invert mask:00000101)
                        $4=0 (step enable invert, bool)
                        $5=0 (limit pins invert, bool)
                        $6=0 (probe pin invert, bool)
                        $10=3 (status report mask:00000011)
                        $11=0.010 (junction deviation, mm)
                        $12=0.002 (arc tolerance, mm)
                        $13=0 (report inches, bool)
                        $20=0 (soft limits, bool)
                        $21=0 (hard limits, bool)
                        $22=0 (homing cycle, bool)
                        $23=0 (homing dir invert mask:00000000)
                        $24=25.000 (homing feed, mm/min)
                        $25=500.000 (homing seek, mm/min)
                        $26=250 (homing debounce, msec)
                        $27=1.000 (homing pull-off, mm)
                        $100=800.000 (x, step/mm)
                        $101=800.000 (y, step/mm)
                        $102=800.000 (z, step/mm)
                        $110=800.000 (x max rate, mm/min)
                        $111=800.000 (y max rate, mm/min)
                        $112=500.000 (z max rate, mm/min)
                        $120=10.000 (x accel, mm/sec^2)
                        $121=10.000 (y accel, mm/sec^2)
                        $122=10.000 (z accel, mm/sec^2)
                        $130=200.000 (x max travel, mm)
                        $131=200.000 (y max travel, mm)
                        $132=200.000 (z max travel, mm)```
                        NeverDieN
                        NeverDieN
                        #431
                        @andrew said in CNC PCB milling:
                        Looks as though GRBL1.1f has exposed some additional registers than GRBL0.9 did:
                        $0=10
                        $1=25
                        $2=0
                        $3=5
                        $4=0
                        $5=0
                        $6=0
                        $10=3
                        $11=0.010
                        $12=0.002
                        $13=0
                        $20=0
                        $21=0
                        $22=0
                        $23=0
                        $24=25.000
                        $25=500.000
                        $26=250
                        $27=1.000
                        $30=1000
                        $31=0
                        $32=0
                        $100=800.000
                        $101=800.000
                        $102=800.000
                        $110=800.000
                        $111=800.000
                        $112=500.000
                        $120=10.000
                        $121=10.000
                        $122=10.000
                        $130=200.000
                        $131=200.000
                        $132=200.000
                        namely, registers 30, 31, and 32. Not sure what their values should be, or if it even matters.
                        Interestingly, the stepper motors have a distinctly different sound to them when running Chilipeppr with GRBL1.1f (as contrasted with GRBL0.9).
                        • NeverDieN
                          NeverDieN
                          I am having a serious problem, though, which is that no matter whether I use Chilipeppr to jog the x-axis to the left or to the right, it always veers to the left. It never goes to the right. Y and Z seem to be working OK however.
                          rmtuckerR 1 Reply Last reply
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            wrote on last edited by rmtucker
                            #433
                            @neverdie
                            Is it working correctly if you just issue a G0 x10 then x-10?
                            did you switch to the jpadie workspace for v1.1?
                            sounds like you have a short on pin 5
                              $0=10
                              $1=25
                              $2=0
                              $3=5
                              $4=0
                              $5=0
                              $6=0
                              $10=3
                              $11=0.010
                              $12=0.002
                              $13=0
                              $20=0
                              $21=0
                              $22=0
                              $23=0
                              $24=25.000
                              $25=500.000
                              $26=250
                              $27=1.000
                              $30=1000
                              $31=0
                              $32=0
                              $100=800.000
                              $101=800.000
                              $102=800.000
                              $110=800.000
                              $111=800.000
                              $112=500.000
                              $120=10.000
                              $121=10.000
                              $122=10.000
                              $130=200.000
                              $131=200.000
                              $132=200.000
                              NeverDieN
                              NeverDieN
                              @neverdie said in CNC PCB milling:
                              I found out what they mean:
                              $30=1000.	Max spindle speed, RPM
                              $31=0.	Min spindle speed, RPM
                              $32=0	Laser mode, boolean
                              • rmtuckerR rmtucker
                                @neverdie
                                NeverDieN
                                NeverDieN
                                @rmtucker said in CNC PCB milling:
                                No, it goes left in both instances.
                                yes
                                  yes
                                  andrewA
                                  andrewA
                                  andrew
                                  @neverdie sorry, I'm abroad, with very limited availability, so cannot answer too quickly.
                                  based on the mentioned facts it seems to me, that the X axis direction pin is sticked to one position, maybe it has a solder bridge to another pin, or vcc / gnd directly.
                                  • andrewA andrew
                                    NeverDieN
                                    NeverDieN
                                    Thanks! You nailed it. It turns out the solder connection on the atmega328p pin corresponding to D5 just wasn't good enough. I resoldered it, and now the X-axis works in both directions. :)
                                    • NeverDieN
                                      NeverDieN
                                      I'm receiving this error message now:
                                      However, it's not obvious how to delete the files it's referring to. Anyone know how?
                                        @neverdie I haven't tried it, but if you are using Chrome you should be able to give ChiliPeppr unlimited storage through https://developer.chrome.com/extensions/declare_permissions
                                        • NeverDieN
                                          NeverDieN
                                          #440
                                          Great news! Grbl1.1f makes all the difference. I tried milling at 6 mil separation using the upgraded grbl1.1f, and it works!
                                          There's a huge difference between being able to evolve a single PCB design to perfect it rather than having to work on a "dumbed down" design (for a CNC or some other DIY etching process) before being able to get "the real deal" from a PCB fabricator. So, I'm very relieved that the first option now seems possible. :)
                                          andrewA 2 Replies Last reply
