  3. OpenHAB
  4. Ethernet GW vs MQTT
Ethernet GW vs MQTT
10 Posts 8 Posters 4.9k Views 6 Watching
  • S Offline
    Soloam
    Hello all, from your point of view whats is the best approach? To use OpenHab2.2 with a MySensors MQTT GW or a Ethernet GW? And way?
    Currently I have my system working with MQTT, but I'm considering switching to Ethernet, one less layer to go wrong (The MQTT Broker) and the ability to use the Biding with OpenHab and FOTA with Myscontroller.
    ร 1 Reply Last reply
      Ethernet for ease of use and configuration, it works with myscontroller.
      MQTT for better security, you can still use FOTA with MyController, once data is published to MQTT you can do lot's of things.
      X 1 Reply Last reply
        X Offline
        X Offline
        xefil
        @gohan said in Ethernet GW vs MQTT:
        Hello (again ;-) )
        Why is MQTT better for security?
        Thanks,
        simon
          First you can set username and password, second the gateway is connecting to a broker while ethernet is accepting incoming connections in clear text and no security of any kind ; also if you are accepting connections it is more likely to have a security risk than only outgoing connections
            X Offline
            X Offline
            xefil
            Thanks!
            • D Offline
              diogoc
              It is possible to have both of them in a ESP8266 gateway?
              I want to use MQTT to control the nodes but I need too the ethernet to update FOTA nodes with Myscontroller.
              • D diogoc
                rozpruwaczR Offline
                rozpruwaczR Offline
                rozpruwacz
                @diogoc AFAIK no. I'm using mqtt with MyController (not Myscontroller) and it works great.
                • S Soloam
                  ร Offline
                  ร Offline
                  รอเรือ
                  wrote on last edited by รอเรือ
                  @soloam said in Ethernet GW vs MQTT:
                  MySensors MQTT GW
                  I would vote for MQTT serial gateway but there is no option for that. That's what I use for openHAB 2.3. Works like a charm. I'm not dependent of any special MySensors binding for openHAB. MQTT is the way to go! Serial binding is for people who doesn't like to spend time debugging hardware issues.
                  • G Offline
                    G Offline
                    Guillermo Schimmel
                    MQTT is the way to go. No special mysensors binding, pure old mqtt.
                    Easy to troubleshoot and diagnostic, compatible, etc.
                    • alowhumA Offline
                      alowhumA Offline
                      alowhum
                      Actually, in my experience plain old MQTT is difficult to connect to. There is a Git issue to create (also) an MQTT output that is simplified or follows standards.
                      https://github.com/mysensors/MySensors/issues/1212
