  3. RS485 to Ethernet Gateway
2 Posts 2 Posters 1.4k Views 2 Watching
  • kduinoK
    kduinoK
    kduino
    wrote on last edited by kduino
    after getting the prototypes working (I dont know why but the ready to use bricks of max485 are not working, the bare ones do) I like to attach the gateway via ethernet to my controller. I am using the Arduino Ethernet Shield v1 from HanRun HR911105A 16/02.
    Unfortunately I dont get any ethernet connection.
    This is how I modified my code. Any ideas what went wrong?
    Appreciate any suggestions...
    Thanks kduino
    //#define MY_RADIO_NRF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    // Enable RS485 transport layer
    #define MY_RS485
    // Define this to enables DE-pin management on defined pin
    #define MY_RS485_DE_PIN A8
    // Set RS485 baud rate to use
    #define MY_RS485_BAUD_RATE 9600
    // Enable this if RS485 is connected to a hardware serial port
    #define MY_RS485_HWSERIAL Serial1
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    //#define MY_IP_ADDRESS 192, 168, 178, 45
    #define MY_IP_RENEWAL_INTERVAL 60000
    #define MY_PORT 5003
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 91
    #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xFE
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    • kduinoK kduino
      Thanks kduino
      #define MY_RS485
      #define MY_SOFTSPI
      @kduino the debug output will probably provide useful information.
