  3. Delay/Sleep RPi Gateway With Sensors
3 Posts 2 Posters 953 Views 2 Watching
  • G
    G
    Geoff
    Hi All,
    I've put together a RPi MQTT gateway and attached a BME280 sensor to it, which is working well.
    My question is, will calling delay() or sleep() in loop() in "examples_linux/mysgw.cpp" for the RPi attached sensors have an impact on the function of the gateway?
    If it was a remote node it would be okay to delay or sleep for 5 minutes and then send another round of data, but how is the RPi Gateway handling loop()? Is it running on a separate thread/process from the main gateway process?
    Thanks, and thanks for a great system, really enjoying using it!
    Geoff
    • G Geoff
      Hi All,
      Geoff
      @geoff yes, calling delay or sleep will stop all processing. Use wait.
      Edit: calling sleep will actually return immediately with return value MY_SLEEP_NOT_POSSIBLE so you can call it, but nothing will happen.
      G 1 Reply Last reply
        G
        G
        Geoff
        @mfalkvidd Thanks for the assistance!
