  3. Sensor for Vallox DigitSE RS485 ventilation system with integration into FHEM.
rs485valloxfhem
36 Posts 12 Posters 27.2k Views 12 Watching
  • SkjallS Offline
    SkjallS Offline
    Skjall
    wrote on last edited by Skjall
    #21
    No, the Windows PC was only for testing and verifying that the RS485 Connection workes well.
    My preferred solution would be this stick at the Raspberry Pi which is running the FHEM. Therefor I'd need a module to read the stream and interpret it in the FHEM format. Problem: I've never written a module. It would be possible somehow.. in some month. ;)
    The alternate solution would be your mysensor system. Especially because its running and tested. Problem: The Hardware. I have no experience in arduino and absolutly no idea how to build such a board. Thats why I thought I could plug the stick to an arduino and make it magicly work. ;)
    EDIT: Ok. It is easier than I thought to write this module. I'm working on it and the main functions should be finished this week. I'll publish it, if it is ready for testing.
    HeinzH 1 Reply Last reply
    • SkjallS Skjall
      HeinzH Offline
      HeinzH Offline
      Heinz
      Ah ok I see. Probably you can get some help in the fhem forum. I also thought about doing this using a raspi... you could use the library to write a standalone exe which reads the serial stuff from usb and sets the values in fhem using the webinterface.
      • B Offline
        B Offline
        boehrian
        Hello, Thank you for this Tool. I have rebuild it but I get no Data in Fhem and the serial Monitor from Arduino. Can every one help me?
        0_1488198457149_upload-35f8091f-da2a-4c43-ab73-7574f41a77b4
        This is the output from serial Monitor.
        • HeinzH Offline
          HeinzH Offline
          Heinz
          here is my output:
          Opening port
          Port open
          Starting repeater (RNNRA-, 2.0.0)
          TSM:INIT
          TSM:RADIO:OK
          TSP:ASSIGNID:OK (ID=100)
          TSM:FPAR
          TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSP:MSG:READ 1-1-100 s=255,c=3,t=8,pt=1,l=1,sg=0:1
          TSP:MSG:FPAR RES (ID=1, dist=1)
          TSP:MSG:PAR OK (ID=1, dist=2)
          TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
          TSP:MSG:PAR OK (ID=0, dist=1)
          TSP:MSG:READ 104-104-100 s=255,c=3,t=8,pt=1,l=1,sg=0:1
          TSP:MSG:FPAR RES (ID=104, dist=1)
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=100)
          TSM:UPL
          TSP:PING:SEND (dest=0)
          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
          TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
          TSP:MSG:PONG RECV (hops=1)
          TSP:CHKUPL:OK
          TSM:UPL:OK
          TSM:READY
          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
          !TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
          TSP:MSG:READ 0-0-100 s=255,c=3,t=6,pt=0,l=1,sg=0:M
          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=ok:Vallox Digit SE
          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:2.5
          TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=3,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=4,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=5,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=6,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=7,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=8,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=9,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=10,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=11,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=12,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=13,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=14,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=15,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=24,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=25,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=26,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=27,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=28,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=29,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=30,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=31,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=32,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=33,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=34,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=35,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=36,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=37,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=38,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=39,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=40,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=41,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=42,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=43,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=44,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=45,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=46,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=47,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=48,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          TSP:MSG:SEND 100-100-0-0 s=49,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
          Started cyclic update timer.
          Request registration...
          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
          TSP:MSG:READ 0-0-100 s=255,c=3,t=27,pt=1,l=1,sg=0:1
          Node registration=1
          Init complete, id=100, parent=0, distance=1, registration=1
          Dropped 0
          Received telegram from 21->11 command=0 arg=A3
          Received telegram from 11->21 command=A3 arg=29
          Property 200 changed 41
          Power state 1
          TSP:MSG:SEND 100-100-0-0 s=8,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:1
          CO2 adjust state 0
          TSP:MSG:SEND 100-100-0-0 s=9,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
          Humidity adjust state 0
          TSP:MSG:SEND 100-100-0-0 s=10,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
          Heating state 1
          TSP:MSG:SEND 100-100-0-0 s=11,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:1
          Filter guard indicator 0
          TSP:MSG:SEND 100-100-0-0 s=12,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=ok:0
          Heating indicator 1
          TSP:MSG:SEND 100-100-0-0 s=13,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=ok:1
          Fault indicator 0
          TSP:MSG:SEND 100-100-0-0 s=14,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=ok:0
          Serivce reminder indicator 0
          TSP:MSG:SEND 100-100-0-0 s=15,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=ok:0
          Received telegram from 21->11 command=0 arg=29
          Received telegram from 11->21 command=29 arg=1
          Received telegram from 21->11 command=0 arg=35
          Received telegram from 11->21 command=35 arg=9D
          Temp incomming 19
          TSP:MSG:SEND 100-100-0-0 s=4,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=ok:19
          Received telegram from 21->11 command=0 arg=71
          Received telegram from 11->21 command=71 arg=0
          This is the output of the mysensors 2.0 version which can be downloaded from
          https://github.com/windkh/mysensors/tree/master/ValloxSensor
          I wonder why your node has id=0.
          • B Offline
            B Offline
            boehrian
            Hi, my output ist now:
            0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
            3 TSM:INIT
            4 TSF:WUR:MS=0
            12 TSM:INIT:TSP OK
            13 TSF:SID:OK,ID=42
            15 TSM:FPAR
            52 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2059 !TSM:FPAR:NO REPLY
            2061 TSM:FPAR
            2098 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            4105 !TSM:FPAR:NO REPLY
            4107 TSM:FPAR
            4143 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            6151 !TSM:FPAR:NO REPLY
            6153 TSM:FPAR
            6189 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            8197 !TSM:FPAR:FAIL
            8198 TSM:FAIL:CNT=1
            8200 TSM:FAIL:PDT
            18203 TSM:FAIL:RE-INIT
            18205 TSM:INIT
            18212 TSM:INIT:TSP OK
            18214 TSF:SID:OK,ID=42
            18216 TSM:FPAR
            18253 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            20261 !TSM:FPAR:NO REPLY
            20263 TSM:FPAR
            20300 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            22307 !TSM:FPAR:NO REPLY
            22309 TSM:FPAR
            22346 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            24353 !TSM:FPAR:NO REPLY
            24355 TSM:FPAR
            24392 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            I get no reply from the Vallox.
            Is your original Vallox controller online
            • HeinzH Offline
              HeinzH Offline
              Heinz
              wrote on last edited by Heinz
              #26
              The "no reply" message is from the mysensors library, but I don't know what it means.
              The line "started cyclic update timer" indicates that the sensor initialized successfully, but it is missing in your output.
              My latest code is online at
              https://github.com/windkh/valloxserial/blob/master/examples/mysensors/ValloxSensor.ino
              • hekH Offline
                hekH Offline
                Use the log parser to help you interpret the log.
                • HeinzH Heinz
                  For those who want to have the FHEM files here they are:
                  _MYSENSOR_Vallox.cfg
                  simply place the file in FHEM's subfolder FHEM and include it your fhem.cfg:
                  include ./FHEM/_MYSENSOR_Vallox.cfg
                  And here are the plot files which have to be placed in the subfolder www\gplot
                  SVG_FileLog_Vallox_6.gplot
                  SVG_FileLog_Vallox_5.gplot
                  SVG_FileLog_Vallox_4.gplot
                  SVG_FileLog_Vallox_3.gplot
                  SVG_FileLog_Vallox_2.gplot
                  SVG_FileLog_Vallox_1.gplot
                  You will likely have to adapt the room and group names, and of course the german names, sorry for that.
                  ausbremenA Offline
                  ausbremenA Offline
                  ausbremen
                  @heinz
                  Hi Heinz, the SVG_FileLog_Vallox_#.gplot files are empty ...probably the link is dead...could you reup them? Or could you send them tio me?
                  Thanks, Holger
                  • HeinzH Heinz
                    ausbremenA Offline
                    ausbremenA Offline
                    ausbremen
                    @heinz
                    Sorry...everything is fine with the gplot files...it was my fault trying to look at them with the crimpson editor...instead of FHEM gplot
                    • C Offline
                      C Offline
                      captaindork
                      Hello Heinz, all,
                      first of all thank you for sharing your work in this thread!
                      I have not to much skills around programming and arduino, but was however able to build this and integrate my Vallox 90 SE into ioBroker. Absolutely Great!
                      You mentioned the bypass damper above and I see you have visualized it in fhem. I found the Value to set the Threshold temp for this (31), however I wonder where you got the actual bypass position from. Which Value shows if its open or closed?
                      I do not want to control it, i just would like to log the Position Status to see when it happens.
                      Thanks a lot i feel blind :)
                      • C captaindork
                        Hello Heinz, all,
                        HeinzH Offline
                        HeinzH Offline
                        Heinz
                        Hi @captaindork
                        sorry for delay,.... the position of the damper (which is the bypass) is indicated through a single bit of the multi purpose IO-Port 2. The library defines that as property 38 DamperMotorPositionProperty.
                        In the mysensors example it is published as
                        const uint8_t DAMPER_MOTOR_POSITION = 42;
                        The value is either 1 or 0.
                        I mapped it in FHEM as follows
                        attr MYSENSOR_Vallox mapReading_DamperMotorPosition 42 value1
                        define MYSENSOR_Vallox_DamperMotorPosition dummy
                        attr MYSENSOR_Vallox_DamperMotorPosition alias WRG-Bypass
                        attr MYSENSOR_Vallox_DamperMotorPosition devStateIcon 1:rc_GREEN 0:rc_BLANK
                        attr MYSENSOR_Vallox_DamperMotorPosition event-on-update-reading state
                        attr MYSENSOR_Vallox_DamperMotorPosition group Status
                        attr MYSENSOR_Vallox_DamperMotorPosition icon vent_bypass
                        attr MYSENSOR_Vallox_DamperMotorPosition room Lüftung
                        attr MYSENSOR_Vallox_DamperMotorPosition sortby 3
                        define MYSENSOR_Vallox_DamperMotorPosition_Notify notify MYSENSOR_Vallox:DamperMotorPosition:.* { my $d = sprintf ("%.0f", ReadingsVal("MYSENSOR_Vallox","DamperMotorPosition", 0));; fhem("set MYSENSOR_Vallox_DamperMotorPosition $d");;}
                        define MYSENSOR_Vallox_DamperMotorPosition_Notify2 at +*00:01:00 { my $d = sprintf "%.0f", ReadingsVal("MYSENSOR_Vallox","DamperMotorPosition", 0);; fhem("set MYSENSOR_Vallox_DamperMotorPosition $d");;}
                        • R Offline
                          R Offline
                          RHead
                          Hi.
                          Can you make exact parts list for this setup.
                          • HeinzH Offline
                            HeinzH Offline
                            Heinz
                            Ok ... after my holidays.
                            • HeinzH Offline
                              HeinzH Offline
                              Heinz
                              Well basically the part list is very simple
                              1x Arduino Mega 2560
                              1x NRF24L01+
                              1x Pushbutton
                              2x MAX485 Module TTL Switch Module (one for sender, one for receiver)
                              (e.g. https://protosupplies.com/product/max485-ttl-to-rs-485-interface-module/)
                              The 1x Resistor 120Ohms is only neccessary if not already mounted on the MAX485 Module. It depends on what module
                              you bought. So have a look at the layout and check if there is a 120Ohms resistor mounted between pins A and B.
                              The module (https://protosupplies.com/product/max485-ttl-to-rs-485-interface-module/) already contains that resistor.
                              Optionally you can add a capacitor between + and - to stabilize the voltage level if your power supply is a weak one.
                              Anyone will do like 10uF, 100uF...
                              • HeinzH Offline
                                HeinzH Offline
                                Heinz
                                Note that you can make use of any MAX485 module that is suitable for the arduino (5V). Basically they are all the same except for a few minor tweaks like LEDs or other non relevant stuff.
                                • MasMatM Offline
                                  MasMatM Offline
                                  MasMat
                                  I found this old thread and since I have a Vallox machine it's interesting. RS485 is new to me but MySensors isn't.
                                  Can I have a node like this described by Heinz parallel with the "mickey mouse"-display? Using the display's connector? Or is it one or the other?
                                  I'd feel better having both (manual display&buttons and connection to MySensors=>Domoticz, in my case).
