  3. How to add another relay
hello1.0 for int sensor1sorry for the question
4 Posts 3 Posters 1.2k Views 3 Watching
  • A
    A
    Alexandre
    Sorry for the question, I still do not understand much programming.
    How to add more relay in the code below:
    #define MY_REPEATER_FEATURE
    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before()
        for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
            pinMode(pin, OUTPUT);
            present(sensor, S_BINARY);
        if (message.type==V_STATUS) {
            // Change relay state
            digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
            // Store state in eeprom
            // Write some debug info
            Serial.print(message.sensor);
    I'm using an ESP8266.
    skywatchS 1 Reply Last reply
    • A Alexandre
      void before()
      skywatchS
      skywatchS
      skywatch
      @alexandre The code already supports more relays, so there is not much you need to do.
      1. Change the line #define NUMBER_OF_RELAYS 1 to #define NUMBER_OF_RELAYS 2/3/4 etc. Until you run out of pins!
      The rest of the code will automatically be handled within the 'for' loops.
        A caveat with esp8266: gpio 6 is not exposed externally, so a maximum of 2 relays can be used (gpio 4 and 5).
        Gpio 12, 13 and 14 can also be used but will require modification of the sketch.
        • A
          A
          Alexandre
          Thank you very much.
