  3. Combined motion sensor with battery monitor sketch
6 Posts 2 Posters 1.3k Views 2 Watching
  • G
    G
    grumpazoid
    I am using Domoticz with serial gateway. I have a motion sensor with voltage detect circuit.
    I have combined the motion and battery sketches and I can get a reading in Domoticz.
    However it only updates the battery reading when the motion sensor triggers.
    Maybe this is a Domoticz similar to another issue I am having https://forum.mysensors.org/topic/9967/detect-missing-unresponsive-sensor
    I'd be grateful if someone could see if my sketch seems ok.
    // Enable debug prints
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    // Initialize motion message
    // uint32_t SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
      analogReference(INTERNAL1V1);
    #else
      analogReference(INTERNAL);
      sendSketchInfo("Battery Meter", "1.0");
    	sendSketchInfo("Motion Sensor", "1.0");
    	present(CHILD_ID, S_MOTION);
    	// Read digital motion value
    	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
    	Serial.println(tripped);
    	send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
    	sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
      // get the battery Voltage
    #ifdef MY_DEBUG
      Serial.println(sensorValue);
    #ifdef MY_DEBUG
      float batteryV  = sensorValue * 0.003363075;
      Serial.print(batteryV);
      Serial.println(" V");
      Serial.print(batteryPcnt);
      Serial.println(" %");
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
    Raspberry Pi 3B - Domoticz + Node Red
    Arduino Pro Mini 3.3V - W5100 Ethernet, Nrf24
    Arduino Mega, RFLink 433Mhz
    Sonoff/ESP8266/Tasmota switches
    • G grumpazoid
      #else
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
      @grumpazoid the debug output from the node will show what the node is sending. From that it should be easy to determine if it is a sketch problem or a Domoticz problem.
      G 1 Reply Last reply
        G
        G
        grumpazoid
        @mfalkvidd Good point. You are right I can see a value relating to the battery being sent in the serial monitor.
        It is domoticz not updating "last seen" until it sees a "1" from the sensor.
        • G
          G
          grumpazoid
          Ok so what I have done is added in a child id to separately display the state of the battery.
          I followed the thread here https://forum.mysensors.org/topic/6048/reporting-battery-to-domoticz
          I now have a new item in the domoticz utility section that shows the current battery state and I can get a graph displayed.
          I have used :
          definitions: #define CHILD_ID_BATTERY 2
          MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
          in presentation: present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery level" );
          sending: send(msgbatt.set(batteryPcnt ,2)); //send battery in Volt 2 decimal places
          i don't really understand all of the above. if anyone can point me to an explanation that would be good.
          next step is to perform the correct calculation for my 18650 cell, but for now my brain hurts!!!
          • G grumpazoid
            I have used :
            @grumpazoid if you haven't already, check the section on presentation and sending data in the api documentation.
              G
              G
              grumpazoid
              @mfalkvidd That looks just what I'm after...Thanks
