  3. Vera
  4. Using PLEG to copy a sensor value to another
3 Posts 2 Posters 2.2k Views 2 Watching
  • dbemowskD
    dbemowskD
    So I am having trouble trying to do something with PLEG. I have an outside temp sensor which is on my OneWire network. I also have my MySensors thermostat bridge that will accept a value for the outside temp that will get displayed on the actual wall thermostat display. I just present a separate device for the outside temp as a place to set the value. I am trying to find a way to copy the value from the OneWire sensor to the thermostat outside temp device. It would be nice if I could do it any time the value changes, but I would also accept doing it say every minute. When I look at the options for the temp sensor, all I have is "if the temp goes above", "if the temp goes below" or "if the battery goes below". Because of this I am assuming that I will have to do it once a minute, but maybe someone knows how to do it on change of the value. My main thing is that I can't figure out how to copy the value over.
    • korttomaK
      korttomaK
      korttoma
      Just add LUA as a Logic Action triggered by a cyclic condition in PLEG
      Using Lua just get the value from the temp sensor variable and set the variable on the thermostat:
      local PipeTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 42)
      luup.variable_set("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature",PipeTemp,44)
      • Tomas
      dbemowskD 1 Reply Last reply
      • korttomaK korttoma
        dbemowskD
        dbemowskD
        @korttoma Perfect. This is what I came up with in the end, and I have it triggering every minute. I needed the number rounded to the nearest whole number as the thermostat will not display a decimal value for the outside temp.
        local CurrentTemp= luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 26)
        luup.variable_set("urn:upnp-org:serviceId:LcdText1", "LcdText", string.format("%.0f", CurrentTemp), 365)
        Thanks a million.
