  3. (homeassistant) mysensors.notify does nothing, (alternatives?)
8 Posts 4 Posters 1.6k Views 3 Watching
  • Z Offline
    Z Offline
    zen85
    wrote on last edited by zen85
    I cant get mysensors.notify to work...
    in my configuration.yaml i put this:
    input_boolean:
      baum_fx_twinkle:
        initial: off
    and in my automations.yaml i have this.
    - alias: 'send scene to map'
      trigger:
        platform: state
        entity_id: input_boolean.baum_fx_twinkle
        to: 'on'
      action:
        service: notify.mysensors
        data:
          message: twinkle
          target: 'lalelu 111 2'
    it works when i use MYSController with type c_set, subtype V_TEXT settings. but whenever i try to press the switch it does nothing... also there is nothing logged in MYSController.
    Same when i try to use the call-service-page in my homeassistant backend... just nothing - not even an error...
    does anyone have an idea? I checked for correct IDs and everything and in MYSController it definetly works... but homeassistant is very reluctant to do anything...
    • Z Offline
      Z Offline
      zen85
      or does anybody have an alternative?
      i just want to send a V_TEXT to a node via the dashboard.
      • alowhumA Offline
        alowhumA Offline
        alowhum
        Maybe add 'home assistant' to the topic title?
        Z 1 Reply Last reply
        • alowhumA alowhum
          Z Offline
          Z Offline
          zen85
          @alowhum
          good idea. thx.
          • Z Offline
            Z Offline
            zen85
            let me ask differently again:
            did anybody get this:
            https://www.home-assistant.io/components/notify.mysensors/
            to work? i find no useful example and have the suspicion that it just doesnt work anymore since all the forumentries seem old and outdated?
            • Z Offline
              Z Offline
              zen85
              sorry for spamming my own thread... i just want to keep updates coming in while debugging... i got it to the point where the homeassistant log tells me: "Unable to find service notify/mysensors".
              but apparently there is no known solution to do this. i even unplugged and restarted everything. i am hitting a dead end here...
              • J Offline
                J Offline
                jmg138
                I have the same issue after settinf an automation under HA ( "Unable to find service notify/mysensor")
                Do you find a workaround?
                • Dmitry CherkasD Offline
                  Dmitry Cherkas
                  I faced same issue and was able to solve it by doing a proper presentation of S_INFO widget, as described in sample sketch: https://www.home-assistant.io/integrations/notify.mysensors/
                  The error message is quite misleading.
