  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.8k Views 73 Watching
  • ch3b7C
    ch3b7C
    ch3b7
    Any source code?
    tekkaT 1 Reply Last reply
    • tekkaT tekka
      New version available with bug fixes 0.1.2.256:
      • "File not open" error fixed
      • Display errors fixed
      • Mac users: use wine to run program, no remapping of serial ports necessary - use e.g. /dev/ttyUSB0 in config window
      To update hit the update button or download here.
      AWIA
      AWIA
      AWI
      @tekka Hi, Chrome is blocking the download of the Windows GUI/Controller zip archive for being "harmfull". any clue?
      • AWIA AWI
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        #38
        @AWI My guess is because of the upx-packed executable (MYSController.exe) in the archive being recognized as false positive.
        • ch3b7C ch3b7
          Any source code?
          tekkaT
          tekkaT
          tekka
          @ch3b7 said:
          Any source code?
          Yes, I will provide the source code in the nearest future.
          • D
            doblanch
            wrote on last edited by doblanch
            #40
            Hello team, thanks for the great job. This tool is very useful.
            however, I don't understand how the tool can snif. I guess, that I have to connect an arduino in serial ( I use the tool in a VM)... but with which sketch ? a gateway sketch...I think I missed something, but if somebody can elaborate a little bit. thanks
            • ch3b7C
              ch3b7C
              ch3b7
              You need upload the serialgateway sketch to the arduino connected with the nrf24 the n connect the usb to pc and select the correct com port in the program
                mvader
                " It works in connection with the modified optiboot/OTA bootloader mentioned in a previous post. "
                can someone link to that post? I couldn't find it
                • ch3b7C
                  ch3b7C
                  ch3b7
                  You add ethernet support? Im add ethernet support in my program in .net its work good.
                  • M mvader
                    tekkaT
                    tekkaT
                    tekka
                    @mvader this is the MYSBootloader from the library.
                    • tekkaT tekka
                      mvader
                      okay thanks!
                      • HeinzH
                        HeinzH
                        Heinz
                        @tekka cool software! btw the sorting of the child sensors in the tree could be optimized.
                        Right now the nodes are sorted like string instead of numbers:
                        0 - ...
                        1 - ...
                        10 -
                        11 -
                        2 -
                        21-
                        • tekkaT tekka
                          samppa
                          Chrome blocks the download since it is "malicious".
                          • S samppa
                            tekkaT
                            tekkaT
                            tekka
                            @samppa read my previous post::
                            I didn't face a warning with IE or Firefox, but indeed, Chrome reports it.
                            • HeinzH Heinz
                              0 - ...
                              1 - ...
                              10 -
                              11 -
                              2 -
                              21-
                              tekkaT
                              tekkaT
                              tekka
                              @Heinz thanks. I will add the number sorting in the next build.
                              • B
                                B
                                Baran
                                Greetings Tekka,
                                I am teaching myself programming while learning about the NRF24L01+ and various controllers and sensors. I have tried to download several free software controllers but yours is the only one that was straightforward enough for me to be successful. I have used it to monitor communication to and from my gateway but I am at a loss as to how to use your creation as a controller. It is the most wonderful tool for visualizing and debugging node-to-gateway communications because of the exceptional work you have done translating the command codes into real command words.
                                Is there a way to input data through your GUI or is it best used as an output device? If input is accepted, would you be so kind as to elaborate on the subject enough to get me moving?
                                Respectfully - Baran
                                • E
                                  E
                                  ericvdb
                                  Right click on a node and click Send Msg:
                                  upload-470b8000-35d1-49b5-8917-27fb9cf5934f
                                  • B
                                    B
                                    Baran
                                    Thanks Eric - Way too cool!
                                    • D
                                      dzairo
                                      Hi.
                                      I try your project ..and find problem in my side..
                                      I use MCU with USB - UART converter what possible set speed max 38kBps .. is possible in your MYSController set lower speed ??
                                      I thinks that you now use 115200 ..
                                      regards.
                                      • D
                                        Dirk_H
                                        I'm looking some days into this topic, although I found not the time to test your very good looking software - The issue mentioned by dzairo would also be important for me. As I run my nodes at 8MHz I cannot use the default 115200kbps and use (also) 38kbps - so it would be important for me to change the BAUD rate too.
                                        Anyways - nice work!
                                        • D
                                          dzairo
                                          ... some other problem is if you want run MCU in 3.3V then not possible use higher frequency .. then all use internal 8 Mhz RC oscillator and maximum speed is 38k ..
                                          this is reason why use 38k ..
                                          best regards.
