  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 514.7k Views 73 Watching
    Great, I'll add a link from the main site to your project.
    • daulagariD
      daulagariD
      daulagari
      @tekka : Thanks, things work now fine! :+1:
      • ch3b7C
        ch3b7C
        ch3b7
        Any source code?
        tekkaT 1 Reply Last reply
        • tekkaT tekka
          New version available with bug fixes 0.1.2.256:
          • "File not open" error fixed
          • Display errors fixed
          • Mac users: use wine to run program, no remapping of serial ports necessary - use e.g. /dev/ttyUSB0 in config window
          To update hit the update button or download here.
          AWIA
          AWIA
          AWI
          @tekka Hi, Chrome is blocking the download of the Windows GUI/Controller zip archive for being "harmfull". any clue?
          • AWIA AWI
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            #38
            @AWI My guess is because of the upx-packed executable (MYSController.exe) in the archive being recognized as false positive.
            • ch3b7C ch3b7
              Any source code?
              tekkaT
              tekkaT
              tekka
              @ch3b7 said:
              Any source code?
              Yes, I will provide the source code in the nearest future.
              • D
                doblanch
                wrote on last edited by doblanch
                #40
                Hello team, thanks for the great job. This tool is very useful.
                however, I don't understand how the tool can snif. I guess, that I have to connect an arduino in serial ( I use the tool in a VM)... but with which sketch ? a gateway sketch...I think I missed something, but if somebody can elaborate a little bit. thanks
                • ch3b7C
                  ch3b7C
                  ch3b7
                  You need upload the serialgateway sketch to the arduino connected with the nrf24 the n connect the usb to pc and select the correct com port in the program
                    mvader
                    " It works in connection with the modified optiboot/OTA bootloader mentioned in a previous post. "
                    can someone link to that post? I couldn't find it
                    • ch3b7C
                      ch3b7C
                      ch3b7
                      You add ethernet support? Im add ethernet support in my program in .net its work good.
                      • M mvader
                        tekkaT
                        tekkaT
                        tekka
                        @mvader this is the MYSBootloader from the library.
                        • tekkaT tekka
                          mvader
                          okay thanks!
                          • HeinzH
                            HeinzH
                            Heinz
                            @tekka cool software! btw the sorting of the child sensors in the tree could be optimized.
                            Right now the nodes are sorted like string instead of numbers:
                            0 - ...
                            1 - ...
                            10 -
                            11 -
                            2 -
                            21-
                            • tekkaT tekka
                              samppa
                              Chrome blocks the download since it is "malicious".
                              • S samppa
                                tekkaT
                                tekkaT
                                tekka
                                @samppa read my previous post::
                                I didn't face a warning with IE or Firefox, but indeed, Chrome reports it.
                                • HeinzH Heinz
                                  0 - ...
                                  1 - ...
                                  10 -
                                  11 -
                                  2 -
                                  21-
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Heinz thanks. I will add the number sorting in the next build.
                                  • B
                                    B
                                    Baran
                                    Greetings Tekka,
                                    I am teaching myself programming while learning about the NRF24L01+ and various controllers and sensors. I have tried to download several free software controllers but yours is the only one that was straightforward enough for me to be successful. I have used it to monitor communication to and from my gateway but I am at a loss as to how to use your creation as a controller. It is the most wonderful tool for visualizing and debugging node-to-gateway communications because of the exceptional work you have done translating the command codes into real command words.
                                    Is there a way to input data through your GUI or is it best used as an output device? If input is accepted, would you be so kind as to elaborate on the subject enough to get me moving?
                                    Respectfully - Baran
                                    • E
                                      E
                                      ericvdb
                                      Right click on a node and click Send Msg:
                                      upload-470b8000-35d1-49b5-8917-27fb9cf5934f
                                      • B
                                        B
                                        Baran
                                        Thanks Eric - Way too cool!
                                        • D
                                          dzairo
                                          Hi.
                                          I try your project ..and find problem in my side..
                                          I use MCU with USB - UART converter what possible set speed max 38kBps .. is possible in your MYSController set lower speed ??
                                          I thinks that you now use 115200 ..
                                          regards.
