  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 514.7k Views 73 Watching
  • D
    doblanch
    wrote on last edited by doblanch
    #40
    Hello team, thanks for the great job. This tool is very useful.
    however, I don't understand how the tool can snif. I guess, that I have to connect an arduino in serial ( I use the tool in a VM)... but with which sketch ? a gateway sketch...I think I missed something, but if somebody can elaborate a little bit. thanks
    • ch3b7C
      ch3b7C
      ch3b7
      You need upload the serialgateway sketch to the arduino connected with the nrf24 the n connect the usb to pc and select the correct com port in the program
        mvader
        " It works in connection with the modified optiboot/OTA bootloader mentioned in a previous post. "
        can someone link to that post? I couldn't find it
        tekkaT 1 Reply Last reply
        • ch3b7C
          ch3b7C
          ch3b7
          You add ethernet support? Im add ethernet support in my program in .net its work good.
          • M mvader
            tekkaT
            tekkaT
            tekka
            @mvader this is the MYSBootloader from the library.
            • tekkaT tekka
              mvader
              okay thanks!
              • HeinzH
                HeinzH
                Heinz
                @tekka cool software! btw the sorting of the child sensors in the tree could be optimized.
                Right now the nodes are sorted like string instead of numbers:
                0 - ...
                1 - ...
                10 -
                11 -
                2 -
                21-
                • tekkaT tekka
                  New version available with bug fixes 0.1.2.256:
                  • "File not open" error fixed
                  • Display errors fixed
                  • Mac users: use wine to run program, no remapping of serial ports necessary - use e.g. /dev/ttyUSB0 in config window
                  To update hit the update button or download here.
                  samppa
                  Chrome blocks the download since it is "malicious".
                  • S samppa
                    tekkaT
                    tekkaT
                    tekka
                    @samppa read my previous post::
                    @AWI My guess is because of the upx-packed executable (MYSController.exe) in the archive being recognized as false positive.
                    I didn't face a warning with IE or Firefox, but indeed, Chrome reports it.
                    • HeinzH Heinz
                      0 - ...
                      1 - ...
                      10 -
                      11 -
                      2 -
                      21-
                      tekkaT
                      tekkaT
                      tekka
                      @Heinz thanks. I will add the number sorting in the next build.
                      • B
                        B
                        Baran
                        Greetings Tekka,
                        I am teaching myself programming while learning about the NRF24L01+ and various controllers and sensors. I have tried to download several free software controllers but yours is the only one that was straightforward enough for me to be successful. I have used it to monitor communication to and from my gateway but I am at a loss as to how to use your creation as a controller. It is the most wonderful tool for visualizing and debugging node-to-gateway communications because of the exceptional work you have done translating the command codes into real command words.
                        Is there a way to input data through your GUI or is it best used as an output device? If input is accepted, would you be so kind as to elaborate on the subject enough to get me moving?
                        Respectfully - Baran
                        • E
                          E
                          ericvdb
                          Right click on a node and click Send Msg:
                          upload-470b8000-35d1-49b5-8917-27fb9cf5934f
                          • B
                            B
                            Baran
                            Thanks Eric - Way too cool!
                            • D
                              dzairo
                              Hi.
                              I try your project ..and find problem in my side..
                              I use MCU with USB - UART converter what possible set speed max 38kBps .. is possible in your MYSController set lower speed ??
                              I thinks that you now use 115200 ..
                              regards.
                              • D
                                Dirk_H
                                I'm looking some days into this topic, although I found not the time to test your very good looking software - The issue mentioned by dzairo would also be important for me. As I run my nodes at 8MHz I cannot use the default 115200kbps and use (also) 38kbps - so it would be important for me to change the BAUD rate too.
                                Anyways - nice work!
                                • D
                                  dzairo
                                  ... some other problem is if you want run MCU in 3.3V then not possible use higher frequency .. then all use internal 8 Mhz RC oscillator and maximum speed is 38k ..
                                  this is reason why use 38k ..
                                  best regards.
                                  • tekkaT
                                    tekkaT
                                    tekka
                                    @Dirk_H , @dzairo: yup, will include this option in the next update. Thanks for reporting.
                                    • T
                                      therik
                                      Thank you for this excellent work. I look forward to using it in my network. I just have a couple questions regarding setting up the GUI. I've read through this thread several times, but still have a couple of gaps in my understanding.
                                      1. Is the gateway that interfaces with the GUI an additional gateway which listens to, and sends node messages and updates? That is, additional to one that is interfaced with the controller (in my case a serial gateway connected to a Vera controller)?
                                      2. If my the answer to my first question is, yes, it is an additional gateway, is the code defining the operation different such that is does not interfere with the 'true' gateway? Or is the code the same (standard serial gateway sketch) but simply does not interfere?
                                      3. Do the nodes require the MYSBootloader in order to show up in the 'messages' tab, or will 'messages' tab show all node traffic regardless of bootloader? Of course for over the air (OTA) sketch updates it needs the MYSBootloader.
                                      4. Are these the correct steps to setup operation:
                                      a) download and extract the files.
                                      'b) place the bootloader folder into /arduino/hardware path such that the MYSBootloader and the associated boards show up in the 'tools->boards' menu.
                                      c) connect an Arduino with the gateway sketch to a computer using a USB cable (for the serial connection).
                                      d) run MYSController.exe (on windows) and select the COM port of the serial gateway in the configuration.
                                      e) hit connect and node traffic will show up in the 'messages' tab.
                                      If this is correct (and now that I write it down) it seems pretty straightforward, but I didn't see it explicitly described elsewhere. Sorry to be such a beginner, and thanks for straightening me out if I'm incorrect in any step.
                                      • T therik
                                        tekkaT
                                        tekkaT
                                        tekka
                                        No, but certainly a good idea to look into.
                                        No, the MYSBootloader is required for OTA updates with MYSController or compatible controllers.
                                        Yes, that's pretty much it. Copying the bootloader directory is only needed for updating to MYSBootloader via ISP.
                                        • tekkaT tekka
                                          tekkaT
                                          tekkaT
                                          tekka
                                          wrote on last edited by tekka
                                          #59
                                          @Dirk_H , @dzairo BAUD option included in the latest release. Update via software or here.
