  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.6k Views 73 Watching
  • tekkaT tekka
    New version available with bug fixes 0.1.2.256:
    • "File not open" error fixed
    • Display errors fixed
    • Mac users: use wine to run program, no remapping of serial ports necessary - use e.g. /dev/ttyUSB0 in config window
    To update hit the update button or download here.
    AWIA
    AWIA
    AWI
    @tekka Hi, Chrome is blocking the download of the Windows GUI/Controller zip archive for being "harmfull". any clue?
    tekkaT 1 Reply Last reply
    • AWIA AWI
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      #38
      @AWI My guess is because of the upx-packed executable (MYSController.exe) in the archive being recognized as false positive.
      • ch3b7C ch3b7
        Any source code?
        tekkaT
        tekkaT
        tekka
        @ch3b7 said:
        Any source code?
        Yes, I will provide the source code in the nearest future.
        • D
          doblanch
          wrote on last edited by doblanch
          #40
          Hello team, thanks for the great job. This tool is very useful.
          however, I don't understand how the tool can snif. I guess, that I have to connect an arduino in serial ( I use the tool in a VM)... but with which sketch ? a gateway sketch...I think I missed something, but if somebody can elaborate a little bit. thanks
          • ch3b7C
            ch3b7C
            ch3b7
            You need upload the serialgateway sketch to the arduino connected with the nrf24 the n connect the usb to pc and select the correct com port in the program
              mvader
              " It works in connection with the modified optiboot/OTA bootloader mentioned in a previous post. "
              can someone link to that post? I couldn't find it
              • ch3b7C
                ch3b7C
                ch3b7
                You add ethernet support? Im add ethernet support in my program in .net its work good.
                • M mvader
                  tekkaT
                  tekkaT
                  tekka
                  @mvader this is the MYSBootloader from the library.
                  • tekkaT tekka
                    mvader
                    okay thanks!
                    • HeinzH
                      HeinzH
                      Heinz
                      @tekka cool software! btw the sorting of the child sensors in the tree could be optimized.
                      Right now the nodes are sorted like string instead of numbers:
                      0 - ...
                      1 - ...
                      10 -
                      11 -
                      2 -
                      21-
                      • tekkaT tekka
                        samppa
                        Chrome blocks the download since it is "malicious".
                        • S samppa
                          tekkaT
                          tekkaT
                          tekka
                          @samppa read my previous post::
                          I didn't face a warning with IE or Firefox, but indeed, Chrome reports it.
                          • HeinzH Heinz
                            0 - ...
                            1 - ...
                            10 -
                            11 -
                            2 -
                            21-
                            tekkaT
                            tekkaT
                            tekka
                            @Heinz thanks. I will add the number sorting in the next build.
                            • B
                              B
                              Baran
                              Greetings Tekka,
                              I am teaching myself programming while learning about the NRF24L01+ and various controllers and sensors. I have tried to download several free software controllers but yours is the only one that was straightforward enough for me to be successful. I have used it to monitor communication to and from my gateway but I am at a loss as to how to use your creation as a controller. It is the most wonderful tool for visualizing and debugging node-to-gateway communications because of the exceptional work you have done translating the command codes into real command words.
                              Is there a way to input data through your GUI or is it best used as an output device? If input is accepted, would you be so kind as to elaborate on the subject enough to get me moving?
                              Respectfully - Baran
                              • E
                                E
                                ericvdb
                                Right click on a node and click Send Msg:
                                upload-470b8000-35d1-49b5-8917-27fb9cf5934f
                                • B
                                  B
                                  Baran
                                  Thanks Eric - Way too cool!
                                  • D
                                    dzairo
                                    Hi.
                                    I try your project ..and find problem in my side..
                                    I use MCU with USB - UART converter what possible set speed max 38kBps .. is possible in your MYSController set lower speed ??
                                    I thinks that you now use 115200 ..
                                    regards.
                                    • D
                                      Dirk_H
                                      I'm looking some days into this topic, although I found not the time to test your very good looking software - The issue mentioned by dzairo would also be important for me. As I run my nodes at 8MHz I cannot use the default 115200kbps and use (also) 38kbps - so it would be important for me to change the BAUD rate too.
                                      Anyways - nice work!
                                      • D
                                        dzairo
                                        ... some other problem is if you want run MCU in 3.3V then not possible use higher frequency .. then all use internal 8 Mhz RC oscillator and maximum speed is 38k ..
                                        this is reason why use 38k ..
                                        best regards.
                                        • tekkaT
                                          tekkaT
                                          tekka
                                          @Dirk_H , @dzairo: yup, will include this option in the next update. Thanks for reporting.
