  3. My experiences with MySensors
32 Posts 13 Posters 6.5k Views 9 Watching
  • zboblamontZ zboblamont
    @neverdie You're not related to my erstwhile Ham contact are you? :joy:
    I believe you missed the point that it is not purely a power issue, TX/RX is a combo of frequency, noise, and pre-amp/antenna gain, environment, etc, etc..
    I've no idea what the default setting is for my 433MHz RFM69s, perhaps when I update the system and the nodes I might be able to advise. They are standard devices not the high power version, all using 2dB whips, none have failed to communicate to date. I do have an HW version, it's still in it's antistatic bag...
    I can track my wifi signal outside the house to about 5m, my Nodes are well beyond that. I could add gain to the wireless router to try matching the performance but the question remains why?
    @zboblamont
    The problem is that, assuming FCC compliance, the allowed uses for the 433Mhz band in the USA are pretty limiting for narrowband communications.
      Of course, if it were just for me to decide, I'd recommend all beginners start with LoRa, because if you can't find a way to be happy with the LoRa radio module (which, incidently, can also do everything an rfm69 module can do), you probably can't be happy with anything.
      Is LoRa even supported by mysensors as yet? It's been a long while since I last checked.
      tekkaT
      tekkaT
      tekka
      @neverdie said in My experiences with MySensors:
      Yes, we support RFM95 radios and various LoRa settings: https://www.mysensors.org/apidocs-beta/group__RFM95SettingGrpPub.html
        @zboblamont
        zboblamontZ
        zboblamontZ
        zboblamont
        @neverdie No knowledge of FCC 433MHz restrictions, in the EU it is limited also, from vague memory on %age TX and probably ERP as it is a shared band. But you would need to be pumping a shedload of data for these constraints to take effect, and crucially it suffers none of the frequency crowding issues or penetration constraints of 2.4GHz.
          mickecarlsson
          wrote on last edited by mickecarlsson
          I started out with NRF 2.4 MHz radios for my 8 nodes MySensors and Domoticz. As I also install WiFi networks for customers and have access to our equipment at work I did a measurement at home because I could not get a reliable network.
          First measurement revealed that my DECT wireless phone occupied the same channel that was the default for the NRF radios. And that my neighbors run their WiFi occupying all other channels. Equipment used was Ekahau.
          I tried to tweak the channels but no avail.
          So, I bought new radios, RFM833, and that was the end of my troubles. For two year now my eight nodes have not skipped a beat. I measure temperature, humidity, light (lux), UV and radioactivity.
          And all my WiFi at home is at 5GHz as the 2.4 was exhausted.
          I have about 40 NRF radios in a box with no use for them.
          • tbowmoT
            tbowmoT
            tbowmo
            Perhaps I should make a 433Mhz transmitter, with a 1kW (60dBm) pa on it (which is the limit of my ham license) ;)
            The problem with higher power output on the radio side, also consumes more power from the (battery) supply.. In case of battery operated sensors I'm always aiming for the lowest possible current draw, which is with non-lna devices.
            Luckily I live in the country side, so the 2g4 band is not that crowded, and so my nrf24 is good enough. I tried to use rfm69 as well, but never got the range above 50cm, so I ditched those radios again. And yes, I added decoupling capacitors etc. all over the thing..
            • tbowmoT tbowmo
              Sergio RiusS
              Sergio RiusS
              Sergio Rius
              @tbowmo You see, it's a lottery.
              I also live in the countryside, and also having problems.
              What about ble capabilities of the nrf52? Some claim that a Bluetooth network works.
              I really doubt it, it was the most affected band by the microwave, when I analyzed interference.
              Bs:
              • Adaptive signal power
              • Low level checksum error control and retry
              • Channel analysis and automatic selection
              • Double channel / twin radio gw 😓
              • Nrf52 ble advertising/handshake and then regular 2.4g transmission? 😱
              scalzS 1 Reply Last reply
              • Sergio RiusS Sergio Rius
                Bs:
                #22
                @sergio-rius said in My experiences with MySensors:
                Bs:
                duh, it looks like a subset of feature list we studied for gateways we designed (Janus, Halo) ;)
                Still,
                  Available for RFM modules only, csma as well. Whereas nrf24 has no true rssi feedback..
                  Afaik it's available for rfm69, no ideas for nrf24 I don't remember
                • Channel analysis and automatic selection.
                  We know this, actually it's not really hard to do. It doesn't protect against potential unfortunate jamming of course, or when 2.4ghz is crowded, but it's good start for a network.
                  No dual channel on same band, or freq hoping planned for the moment afaik. For the moment, only local dualrf pocs
                  doable with non arduino environment only, so for the moment it's out of MySensors scope.
                BLE is using freq hoping if not wrong, so in theory it might be "more resistant" to interferences than non-freq hoping protocols (depends on their strategies for reliable packet delivery). Freq hoping may imply change on hw too, for precise timing etc
                that's why I'm saying old tech may get limited at some points, this implies clocks and mcus, radio etc.. By limited I mean, like a subset of features available for less powerful mcu etc. But it's too soon for saying, we miss time too..
                Always suprised when someone reports rfm69 poor range..sounds crazy to me, but I guess it was a problem with sw (like the old rfm69 lib, a good test is to use radioheadlib/lowpowerlab libs for checking link, then you know if it's sw or hw) or hw (like sometimes you can receive the wrong freq for a module etc). no idea, pity!
                  Well, unfortunately I cannot agree with the stories of success.
                  It's ok that a tool works for someone, but it can't be so weak that things like radio clones, track shapes or cap variations renders something unusable. And still did not mention interference or houses construction materials. All things that should be tested. WiFi/mobile interference should not be a problem, everyone has em.
                  Just only think that if Chinese manufacturers are making these clones in that volumes, and they are sold, it's because they took a look at the original and made a product profile with what specs are acceptable for the expected application and clones are the result. I mean that perhaps mysensors expected to much from them.
                  I guess everyone already knows that I only had problems trying to use mysensors, and now I have a defeating gw problem while using original radios all around. I have nrf52s in the box for testing but I'm so defeated, that I have no strength to try them.
                  I've ordered parts for making a good ole rj45 gw, but I'm already working in a custom base sketch for moving to esp+mqtt.
                  My influx data is full of "holes"
                  Now I'm thinking in the fact that my gw started to make this more or less after the installation of a Google home and a echo Dot, for testing. It already seems paranoia.
                  P
                  P
                  pichaty
                  Banned
                  wrote on last edited by pichaty
                  #23
                  • P pichaty
                    [[topic:post-is-deleted]]
                    Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    That is just the point I had in my mind. I'm convinced that mysensors is a great project and the work done here is golden, really. But I would like to know why the documentation always seems to recommend hardware that when you fail to implement, at some point someone tells you that it was expected.
                    That happened me again this week with the Ethernet gw. Following the documentation, hours and hours trying to make the module work, to share spi port, etc... and then someone tells me better getting a w5100. Then why is this board in the official docs? Let's take it out and put a warning.
                    The docs are full of pinout pics of nrf24. But if you use the search (for hours) you get plenty of posts from vip telling... Better going with rfm69.
                    I hope it's not the same with rfm69.
                    • B boozz
                      @rodaman
                      Although fully agree with @mickecarlsson and @tbowmo (I have been lucky with really cheap nrf24L01+ modules I think) and have a similar experience as @TheoL (MySensors works fine with nr24L01+ modules) I can state that mySensors is very much alive.
                      However, I'm interested in your Wemos setup.
                      I've got some questions from which I'm sure you can give me the right quidance:
                      I guess it used some bandwith in your Wifi network? can I use it similar as mySensors topology or even with mySensors libraries?
                      Can it be used with batteries (sleep modes and so on) for a long time?
                      thank you in advance for your values answers,
                      BR, Boozz
                      B
                      B
                      boozz
                      @rodaman: May I remind you of my questions:
                      @rodaman
                      BR, Boozz
                      Unfortunately no reaction from your side till today. In the meanwhile I've searched the internet for a ESP8266 or ESP32 mesh network as an alternative for the mySensors network. I cannot find a good working open source (read Arduino based) startpoint, so I'm wondering if you could direct me to a good starting point.
                      Boozz
                      K 1 Reply Last reply
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @Sergio-Rius
                        I've been away from the forum a couple of days.. But the W5100 is actually the one that is promoted around the site. It does however have a problem with sharing SPI port in some circumstances, as it doesn't let go of MISO (if I remember right).
                        For ENC28J60, it does say that you might run into trouble with memory, as it does have a larger memory footprint.
                        mysensors "store" : https://www.mysensors.org/store/ethernet
                        build instructions: https://www.mysensors.org/build/ethernet_gateway
                        • tbowmoT tbowmo
                          @Sergio-Rius
                          Sergio RiusS
                          Sergio RiusS
                          Sergio Rius
                          @tbowmo Thanks Thomas, I was trying to make an ENC28J60 module work with RF24 then RFM69, and I was getting crazy at it. Finally the module was a failed one. I'm so embarrased, as I was convinced I first tested the module on arrival, and I missed the point.
                          I've already ordered a W5100, but it may take weeks. :pensive:
                          tbowmoT 1 Reply Last reply
                            tbowmoT
                            tbowmoT
                            tbowmo
                            @sergio-rius
                            Just be aware that with W5100 you can probably not share the SPI bus, as there is a hardware limitation in the W5100 (depending on how the manufacturer has wired the chipselect lines)
                            • B boozz
                              @rodaman
                              BR, Boozz
                              Boozz
                              K
                              K
                              kimot
                              wrote on last edited by kimot
                              #29
                              @boozz
                              I am not user "roadman", but I am using MySensors and ESP8266 ( Wemos) so hopefully I can answer some of your questions.
                              I am using only one wifi access point (AP or router) in my home without problems.
                              But you can use one AP for your computers and TV and etc. and other for your sensors.
                              AP hw is cheap....
                              My house is 8x12 meters and wifi AP is in 2nd floor about in center of house.
                              It covers the entire house and very close ( 3m )out of house.
                              Near this wifi AP is RFM69 MySensors gateway, which covers up to the edge of my property 60 meters away.
                              ( may further )
                              MySensors is goot for nodes a far away in my garden and for nodes with low energy consumption and fast reaction when wake up.
                              When MySensors node is sleeping and then wake up, it immediately continues in program flow immediately from the place of "sleep" command.
                              Wemos, when sleeping an wake ups, reboots and must connect to AP, which takes 8s to 2s when we do some tweakings.
                              But Wemos is very user friendly.
                              You can use some "ready use" solutions like ESPeasy or Tasmota and configure your node trough its web page.
                              Configure means select which sensor connect to which pin, send value to which contrtoller etc.
                              Write some programs or scripts:
                              All without the need to compile a new program.
                              And you can send to your controller what you want, not just what is implemented in MySensors.
                              ( Using JSON API in my case with Domoticz )
                              And your controller can send anything to your node.
                              And for "MESH" topology.
                              Arduino "painlessMesh" library for ESPs exists.
                              But I think it is more easier to use more AP units - they are cheap ....
                              Sergio RiusS B 3 Replies Last reply
                              • K kimot
                                @boozz
                                AP hw is cheap....
                                ( may further )
                                Sergio RiusS
                                Sergio RiusS
                                Sergio Rius
                                @kimot said in My experiences with MySensors:
                                AP hw is cheap....
                                Or you can get a VLAN compliant Wifi access point, do the things as should be and implement a separate VLAN for your IoT devices and services.
                                If you buy, for example an ubiquity AP, you can configure as many SSIDs as you need, each one on it's own VLAN, and even you can specify that the IoT network should only be N-type increasing the range.
                                By using only one access point you also reduce radio interferences. Radio appliances are not perfectly made and cheap ones tend to be noisy and get worse with the age.
                                I'm not particulary an ubiquity fan, in fact I only have the ap_ac_pro one, but I'm so satisfied with it that I would recommend their switch+router solution. The web management is awesome.
                                For my adventures I prefer having an ordinary 10gb d-link switch and a custom opnsense router.
                                Range of the ap_ac_pro inside a 20m radius house with 25cms stone walls is just in the limit. Just one in the very center. A long range unit would cover anything, but mine is freaking fast. :ghost:
                                • K kimot
                                  @boozz
                                  AP hw is cheap....
                                  ( may further )
                                  B
                                  B
                                  boozz
                                  Ok, so if I do not misinterpret your words, it's better / easier to use mySensors for the tasks as specified above and use WEMOS / 8266 for other tasks. Some pretty distinct way of where and how to use it.
                                  Thanks a lot for the info provided. I appreciate that. I will give this a try sooner or later for sure.
                                  Up to now my experience with mySensors is positive. Yes, now and then the radio's give me some troubles, but that's part of it. Still a very inexpensive way to collect data and switch on the lights in my garden house, dim some LED's all over the house and get alarmed once the ground-water reaches a level so I have to watch out my basement isn't flooded.
                                  Booz
                                  • K kimot
                                    @boozz
                                    AP hw is cheap....
                                    ( may further )
                                    B
                                    B
                                    boozz
                                    WIll have a look at that too in the near future. Thanks for hinting me towards this.
                                    Boozz
